Error execcting a command from the tutorial
Good morning,
I try to reproduce the fist example of the fenicsx tutorial
I obtained the error message
AttributeError: module 'dolfinx.mesh' has no attribute 'exterior_facet_indices'
for the line
I use DOLFINx version: 0.4.1 based on GIT commit: unknown of GitHub - FEniCS/dolfinx: Next generation FEniCS problem solving environment
Here is the script I write
import numpy
from dolfinx import mesh
from dolfinx import fem
# Dolfinx version
print(f"DOLFINx version: {dolfinx.__version__} based on GIT commit: {dolfinx.git_commit_hash} of https://github.com/FEniCS/dolfinx/")
# mesh
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
# Spaces
# Boundary conditions
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
# Create facet to cell connectivity required to determine boundary facets
tdim = domain.topology.dim
fdim = tdim - 1
And here is the output produced by typing python3 poisson_02.py
DOLFINx version: 0.4.1 based on GIT commit: unknown of https://github.com/FEniCS/dolfinx/
  File "poisson_02.py", line 29, in <module>
Thank you
Xavier
Hi Xavier,
The tutorial is based of
DOLFINx version: 0.4.2.0 based on GIT commit: b983596ace0842230a442e10e49ffd4f27c34419 of https://github.com/FEniCS/dolfinx/
You can either upgrade to the latest version or try to see the corresponding tutorial under a previous commit,
Most likely this should be
boundary_facets = numpy.flatnonzero(mesh.compute_boundary_facets(domain.topology))
but I’d have to run this on a previous version to check.
Thank you,
Do you know how I can upgrade to the lasted version ?
I installed the fenicsx package this morning and I obtained the 0.4.1.0 release.
X
The easiest option would be to pull the latest docker image. Or if you are on linux then install from source.
Thank you.
The source are the newest release of dolfinx ?
The dolfinx/dolfinx docker image is built nightly.
I will release a new updated image with all tutorial dependencies tonight.
Installing from source you would clone the GitHub repository of DOLFINx, and can then checkout the version you would like to use.
See: An overview of the FEniCS Project — FEniCSx tutorial
for docker images compatible with the current release of the tutorial.
