AttributeError: 'Cell' object has no attribute 'name'
Hello everyone, I have an issue on my code.
Here is my input:
from dolfinx import mesh, fem, io, plot
from basix import ufl
from ufl import TrialFunction, TestFunction, dx, inner, grad, div
# Load the mesh
mesh_path = 'TTpath26x.xdmf'
with io.XDMFFile(MPI.COMM_WORLD, mesh_path, "r") as xdmf:
    domain_mesh = xdmf.read_mesh(name="Grid")
# Material properties definition
E = 2200  # Young's modulus for ABS in MPa
nu = 0.35  # Poisson's ratio for ABS
rho = 1040  # Density of ABS (kg/m^3)
g = 9.81  # Acceleration due to gravity (m/s^2)
mu = E / (2 * (1 + nu))
lambda_ = E * nu / ((1 + nu) * (1 - 2 * nu))
# Function spaces and test functions
element = ufl.element("Lagrange", domain_mesh.ufl_cell(), 1, shape=3)
V = fem.FunctionSpace(domain_mesh, element)
# Define boundary conditions
def boundary_bottom(x):
    return np.isclose(x[2], 0.01, atol=0.21)  # z = 0.01 to -0.20
def boundary_top(x):
    return np.isclose(x[2], 2.02, atol=0.01)  # z = 2.02
bc_bottom = fem.dirichletbc(value=np.array([0, 0, 0]), dofs=V.locate_dofs_geometrical(boundary_bottom), V=V)
bc_top = fem.dirichletbc(value=np.array([0, 0, -1000]), dofs=V.locate_dofs_geometrical(boundary_top), V=V)
# Force definition
f = fem.Constant(domain_mesh, (0, 0, -rho * g * 0.01**2))  # Gravitational force
# Weak formulation
a = (inner(grad(u), grad(v)) + lambda_ * div(u) * div(v)) * dx
L = inner(f, v) * dx
# Solve the problem
problem = fem.petsc.LinearProblem(a, L, bcs=[bc_bottom, bc_top])
u_solution = problem.solve()
# Visualize the solution and save to a file
fig = plt.figure()
plotting_mesh = plot.create_vtk_mesh(V)
p = plot.plot(u_solution, mesh=plotting_mesh)
plt.colorbar(p)
plt.savefig('simulation_result.png')  # File path
plt.close()
output of the code:
Traceback (most recent call last): File "/home/mtm/FEA_yeni2.py", line 22, in <module> element = ufl.element("Lagrange", domain_mesh.ufl_cell(), 1, shape=3) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/mtm/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/basix/ufl.py", line 1988, in element family = _basix.finite_element.string_to_family(family, cell.name) AttributeError: 'Cell' object has no attribute 'name'
I am new at FEA and Fenics. I couldn’t solve this error. What should I do to fix it?
This should be
element = ufl.element(“Lagrange”, domain_mesh.topology.cell_name(), 1, shape=3)
For further questions please encapsulate code with 3x` encapsulation
Thank you very much for your advice, it fixed the error. But now I am trying to fix this:
input: element = ufl.element("Lagrange", domain_mesh.topology.cell_name(), 1, shape=(3,)) V = fem.FunctionSpace(domain_mesh, element)
output:
‘’‘Traceback (most recent call last):
File “/home/mtm/FEA_yeni2.py”, line 23, in
TypeError: FunctionSpace.init() missing 1 required positional argument: ‘cppV’
FunctionSpace has been replaced by functionspace
Thaks to you and documentation I fixed all the errors. But I think there is a logic problem on my code. I want to fix my mesh in the z-axis between approximately 0.2 and -0.2 under gravity, and measure its deformation under a downward force of 1000 N from above (approximately from z = 3.02). However, when I look at the results in Paraview, I get the following outcome. No matter how much I increase the force, it does not deform. Did I make a mistake in the boundary conditions?
My final code:
import dolfinx.fem.petsc
# Load the mesh
mesh_path = 'Mesh_path26x.xdmf'
element = ufl.element('Lagrange', domain_mesh.topology.cell_name(), 1, shape=(3,))
V = fem.functionspace(domain_mesh, element)
    return np.isclose(x[2], 2.01, atol=0.01)  # z = 2.02
bc_bottom = fem.dirichletbc(np.array([0.0, 0.0, 0.0]), fem.locate_dofs_geometrical(V, boundary_bottom), V)
bc_top = fem.dirichletbc(np.array([0.0, 0.0, -10000000000.0]), fem.locate_dofs_geometrical(V, boundary_top), V)
# Force definition
# Weak formulation
# Solve the problem
# Save the solution to an XDMF file for visualization in ParaView
solution_path = 'solution.xdmf'
with io.XDMFFile(MPI.COMM_WORLD, solution_path, "w") as xdmf:
    xdmf.write_mesh(domain_mesh)
    xdmf.write_function(u_solution)
Paraview output:
