Automatic derivatives of piece-wise function
Hello all
I am working on a tricky situation here. I need to use FEniCS’s automatic derivative to get gradient of a piecewise function. Suppose u(x,y)\in[0,1] is a solution of a 2D problem (I’m just using random_fun to make an example), f(u) is a 3-piece function based on the local values of u and f is actually continuously differentiable (see figure).
from numpy import array, polyval, random
mesh = UnitSquareMesh(96, 96)
class random_fun(UserExpression):
    def __init__(self,  **kwargs):
        super().__init__(**kwargs)
    def eval(self, value, x):
        value[0] = random.rand()
    def value_shape(self):
        return ()
u = interpolate( random_fun(), V)
plt.figure()
fig=plot(u)
plt.colorbar(fig)
class f(UserExpression):
    def __init__(self, u_fun, **kwargs):
        self.u_fun = u_fun
        if self.u_fun(x) <= 0.25/2.:
            value[0] = self.u_fun(x)/0.25
        elif self.u_fun(x) >= 2.*0.25:
            value[0] = 1.
            value[0] = polyval(array([256./27., -128./9., 64./9., -5./27.]), self.u_fun(x))
        return ()
fu = project(f(u),V)
plt.figure()
fig=plot(fu)
plt.colorbar(fig)
du = TestFunction(V)
f_form = fu * dx
dfdu = derivative(f_form, u, du)
dfdu_fun = Function(V, assemble(dfdu))
plt.figure()
fig=plot(dfdu_fun)
plt.colorbar(fig)
I also tried to plot u, f(u), and \frac{df(u)}{du} to visualize and verify but wasn’t successful. I am using FEniCS version 2019.1.
My understanding of your question is as follows: you have a function F(x, y) = f(u(x, y)), where f(w) is a scalar function of a scalar input w, and f is defined as shown in the figure in your post. When you say you want to get the gradient of the function, do you mean that you want:
  1. The gradient, i.e. \nabla F = \frac{\partial F}{\partial x} \hat{i} + \frac{\partial F}{\partial y} \hat{j}
  2. The derivative F'(x, y) = f'(u(x, y)), where f'(w) = \frac{df(w)}{dw}
  3. The functional derivative (a.k.a. the Gateaux derivative) of the functional G, which it appears you are trying to calculate in your code (because of the use of derivative):
    dG(u; \delta u) = \lim_{\tau \rightarrow 0} {\frac{d}{d \tau} G(u + \tau \, \delta u)} \\ G(u) = \int_{[0, 1] \times [0, 1]} {f(u(x, y)) \, \mathrm{d}x}
  1. the functional derivative. I also wanted to figure out how to visualize the derivative to verify it being computed correctly
Have you looked into conditional to define f?
https://fenics.readthedocs.io/projects/ufl/en/latest/manual/form_language.html#conditional-operators
Looking into this now
What do you think about this?
        return ()
plt.figure()
fig=plot(u)
plt.colorbar(fig)
fu = conditional( u<= 0.25/2., u/0.25, conditional( u >= 2.*0.25, 1.,   256./27.*u**3. -128./9.*u**2. + 64./9.*u  -5./27.  )  )
plt.figure()
fig=plot(fu)
plt.colorbar(fig)
f_form = fu * dx
plt.figure()
fig=plot(dfdu_fun)
plt.colorbar(fig)
That appears to be correct. To test for correctness, I’d suggest using a small mesh (e.g. mesh = UnitSquareMesh(1, 1)), assembling (e.g. b = assemble(dfdu)) and checking the entries of the vector to see if they are correct for simple cases. E.g.
u.vector()[:] = 0.1      # df/du = 4 for all x
b = assemble(dfdu)
print(b[:])              # should give [2/3, 4/3, 4/3, 2/3]
u.vector()[:] = 0.75     # df/du = 0 for all x
b = assemble(dfdu)
print(b[:])              # should give [0., 0., 0., 0.]
u.vector()[:] = 0.25     # calculate m = df/du
b = assemble(dfdu)
print(b[:])              # should give [m / 6, m / 3, m / 3, m / 6]
