Axisymmetric Hertz Contact
Dear all,
I am trying to implement a Hertz contact in axisymmetric coordinates, following the technics described in this tutorial, while translating it into dolfinx v0.10.
Here is my code:
from dolfinx import mesh, fem
from ufl import tr, sym, grad, Identity, inner
from dolfinx import plot
import pyvista
# --- 1. MESH & MAPPING ---
N_r, N_z = 30, 30
R_domain, H = 1.0, 1.0
# Create simple rectangle
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0.0, -H], [R_domain, 0.0]], [N_r, N_z], cell_type=mesh.CellType.triangle)
def map_coordinates(x):
    y = np.zeros_like(x)
    # Jacobian is never zero
    y[:, 0] =R_domain*( 0.2 * x[:, 0]/R_domain + 0.8 * x[:, 0]**2/R_domain**2)
    y[:, 1] =-H*( -0.2 * x[:, 1]/H + 0.8 * x[:, 1]**2/H**2)
    return y
domain.geometry.x[:] = map_coordinates(domain.geometry.x)
# --- 2. FACET TAGGING ---
f_dim = domain.topology.dim - 1
def top(x): return np.isclose(x[1], 0.0)
def bottom(x): return np.isclose(x[1], -H)
def axis(x): return np.isclose(x[0], 0.0)
# Locate and tag
top_facets = mesh.locate_entities_boundary(domain, f_dim, top)
bottom_facets = mesh.locate_entities_boundary(domain, f_dim, bottom)
axis_facets = mesh.locate_entities_boundary(domain, f_dim, axis)
# Combine into meshtags (avoiding duplicates)
indices = np.hstack([top_facets, bottom_facets, axis_facets])
values = np.hstack([np.full(len(top_facets), 1, np.int32),np.full(len(bottom_facets), 2, np.int32),np.full(len(axis_facets), 3, np.int32)])
# Sort indices for meshtags
sorted_idx = np.argsort(indices)
facet_tags = mesh.meshtags(domain, f_dim, indices[sorted_idx], values[sorted_idx])
print(np.unique(facet_tags.values))
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
# --- 3. SPACES & BCs ---
V = fem.functionspace(domain, ("CG", 1, (2,)))
u = fem.Function(V)
du = ufl.TrialFunction(V)
u_ = ufl.TestFunction(V)
# Ur = 0 on axis (ID 3)
bc_axis = fem.dirichletbc(fem.Constant(domain, 0.0), axis_facets, V.sub(0))
# Uz = 0 on bottom (ID 2)
bc_bottom = fem.dirichletbc(fem.Constant(domain, 0.0), bottom_facets, V.sub(1))
bcs = [bc_axis, bc_bottom]
# --- 4. AXISYMMETRIC PHYSICS ---
E, nu = 10.0, 0.3
mu = fem.Constant(domain, E / (2*(1+nu)))
lmbda = fem.Constant(domain, E*nu / ((1+nu)*(1-2*nu)))
# --- Mesh Size Calculation ---
# 1. Get the topological dimension
tdim = domain.topology.dim
# 2. Get the indices of all local cells
num_cells = domain.topology.index_map(tdim).size_local
cells = np.arange(num_cells, dtype=np.int32)
# 3. Call the .h() method on the OBJECT (domain)
h_values = domain.h(tdim, cells)
# 4. Now compute the average
avg_h = np.mean(h_values)
# Scaled Penalty: E / avg_h ensures numerical stability
pen_float = 1e5 * float(E) / avg_h
pen = fem.Constant(domain, pen_float)
print('penalty=',pen_float)
R_ind = 0.5
x_c = ufl.SpatialCoordinate(domain)
# Numerical safety for r=0
r = x_c[0]
r_safe = ufl.conditional(r > 1e-10, r, 1e-10)
d_ind = fem.Constant(domain, 0.05)
obstacle = -d_ind + (r_safe**2)/(2*R_ind)
def eps_axi(v): return sym(grad(v))
def eps_theta(v): return v[0] / r_safe
def div_axi(v): return tr(eps_axi(v)) + eps_theta(v)
def sigma_axi(v): return lmbda * div_axi(v) * Identity(2) + 2 * mu * eps_axi(v)
def sigma_theta(v): return lmbda * div_axi(v) + 2 * mu * eps_theta(v)
# --- 5. VARIATIONAL FORM ---
#Contact
penetration = ufl.max_value(0, -obstacle + u[1])
#Energy
Pi_int = 0.5*(inner(sigma_axi(u), eps_axi(u)) + sigma_theta(u) * eps_theta(u)) * 2.0 * np.pi*r_safe * ufl.dx
Pi_con = 0.5 * pen * penetration**2 * 2*np.pi*r_safe * ds(1)
Pi = Pi_int + Pi_con
F = ufl.derivative(Pi, u, u_)
J = ufl.derivative(F, u, du)
# --- 1. Update the Constant ---
d_target = 0.05
n_steps = 10
d_increments = np.linspace(0, d_target, n_steps + 1)[1:]
#d_increments = [0]
# --- 2. Robust Solver Options ---
petsc_opts = {
    "ksp_type": "preonly",
    "pc_type": "lu",
    "snes_type": "newtonls",
    "snes_linesearch_type": "bt",
    "snes_max_it": 50,
    "snes_atol": 1e-8,
    "snes_rtol": 1e-8,
problem = NonlinearProblem(F, u, bcs=bcs, J=J, petsc_options_prefix="hertzcontact_", petsc_options=petsc_opts)
print(f"Starting indentation loop (Total target: {d_target})...")
for i, d_val in enumerate(d_increments):
    # Update the indentation depth constant
    d_ind.value = d_val
    print(f"\nStep {i+1}/{n_steps}: Indentation = {d_val:.4f}")
    try:
        n_iters, converged = problem.solve()
        if converged:
            print(f"  Converged in {n_iters} iterations.")
            print(f"  Warning: Step {i+1} did not converge!")
            break # Stop if we lose convergence
    except Exception as e:
        print(f"  Critical Failure: {e}")
        break
There should be an error in the code but I can’t find it.
Besides, I don’t understand the following errors I get:
corrupted double-linked list (not small)
Aborted (core dumped)
And
[0]PETSC ERROR: or see FAQ — PETSc 3.24.3 documentation and FAQ — PETSc 3.24.3 documentation
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
It seems also that the Spyder kernel “is dying” during each simulation.
The previous errors are gotten from running the code in the terminal.
I am using dolfinx 0.10.
Thank you in advance
So here the solution.
I had to rewrite the boundary conditions as follows:
facets_axis = mesh.locate_entities_boundary(domain, fdim, axis)
facets_bottom = mesh.locate_entities_boundary(domain, fdim, bottom)
# Locate dofs (IMPORTANT tuple syntax)
dofs_axis = fem.locate_dofs_topological(V.sub(0), fdim, facets_axis)
dofs_bottom = fem.locate_dofs_topological(V.sub(1), fdim, facets_bottom)
bc_axis = fem.dirichletbc(fem.Constant(domain, default_scalar_type(0.0)), dofs_axis, V.sub(0))
bc_bottom = fem.dirichletbc(fem.Constant(domain,default_scalar_type(0.0)), dofs_bottom, V.sub(1))
meaning using the dofs and not directly the boundaries
