Biharmonic equation
I am trying to run the tutorials: Biharmonic equation.
the code is following:
Optimization options for the form compiler
parameters[“form_compiler”][“cpp_optimize”] = True
parameters[“form_compiler”][“optimize”] = True
Create mesh and define function space
mesh = UnitSquareMesh (32, 32)
V = FunctionSpace(mesh, “CG”, 2)
Define Dirichlet boundary
class DirichletBoundary(SubDomain):
return on_boundary
class Source(Expression):
def eval(self, values, x):
values[0] = 4.0pi**4sin(pi*x[0])sin(pix[1])
Define boundary condition
u0 = Constant(0.0)
bc = DirichletBC(V, u0, DirichletBoundary())
Define trial and test functions
Define normal component, mesh size and right-hand side
h = CellSize(mesh)
h_avg = (h(’+’) + h(’-’))/2.0
f = Source()
Penalty parameter
alpha = Constant(8.0)
Define bilinear form
a = inner(div(grad(u)), div(grad(v)))*dx \
  • inner(avg(div(grad(u))), jump(grad(v), n))*dS \
  • inner(jump(grad(u), n), avg(div(grad(v))))*dS \
  • alpha(’+’)/h_avg*inner(jump(grad(u),n), jump(grad(v),n))*dS
Define linear form
L = fvdx
Solve variational problem
solve(a == L, u, bc)
Save solution to file
file = File(“biharmonic.pvd”)
file << u
Plot solution
plot(u, interactive=True)
The above doesn’t work. Can somebody help me?
Thanks in advance!
Try this:
parameters['form_compiler']['cpp_optimize'] = True
parameters['form_compiler']['optimize'] = True
mesh = UnitSquareMesh(32, 32)
V = FunctionSpace(mesh, 'CG', 2)
# Define Dirichlet boundary
        return on_boundary
class Source(UserExpression):
        values[0] = 4.0*pi**4*sin(pi*x[0])*sin(pi*x[1])
        return values
    def value_shape(self):
        return ()
# Define boundary condition
u0 = Constant(0.0)
# Define normal component, mesh size and right-hand side
h = CellDiameter(mesh)
h_avg = (h('+') + h('-'))/2.0
f = Source(degree=2)
# Penalty parameter
# Define bilinear form
  - inner(avg(div(grad(u))), jump(grad(v), n))*dS \
  - inner(jump(grad(u), n), avg(div(grad(v))))*dS \
  + alpha/h_avg*inner(jump(grad(u),n), jump(grad(v),n))*dS
# Define linear form
L = f*v*dx
# Solve variational problem
# Save solution to file
file = File("biharmonic.pvd")
file << u
# Plot solution
plot(u)
It looks like you pulled this example from an outdated version of the documentation. Here is the updated version for Dolfin 2019.1.0.
@Rudy It works! Thank you very much!
