Boundary conditions (all direction or only x)
HI ALL,
im setting a comined boundary conditions on a rode(direchlet and neumann)
for some reason i only set direchlet condition on x direction via para view it seems to be moving from the initial location and not staying in the same location , any idea why?
im using the code of the documantion of the hyperelastic material
when im setting the direclet condition on all on the directions its being clamped and not moving
attaching also screenshots of what i mean
import fenics as fe
import os
E1, E2, nu = 1e5, 6e5, 0.35
length, width, height = 1.0, 0.2, 0.2  # Dimensions of the rod
num_elements = 10  # Number of elements along each dimension
mesh = BoxMesh(Point(0, 0, 0), Point(length, width, height), num_elements, 4, 4)
#mesh = UnitCubeMesh(24, 16, 16)
class Omega_0(SubDomain):
        return x[0] <= 1/2 + DOLFIN_EPS
class Omega_1(SubDomain):
        return x[0] > 1/2 - DOLFIN_EPS
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
materials = MeshFunction('size_t', mesh, mesh.topology().dim())
materials.set_all(0)
subdomain_0.mark(materials, 1)
subdomain_1.mark(materials, 2)
# Boundary conditions
boundary_parts = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
left = AutoSubDomain(lambda x: near(x[0], 0))
right = AutoSubDomain(lambda x: near(x[0], 1))
left.mark(boundary_parts, 1)
right.mark(boundary_parts, 2)
bc1 = DirichletBC(V.sub(0), Constant(0), boundary_parts, 1)
#bc2 = DirichletBC(V.sub(1), Constant(0), boundary_parts, 1)
#bc3 = DirichletBC(V.sub(2), Constant(0), boundary_parts, 1)
bcs = [bc1]
neumann = Expression(("0.1*x[0]"), degree=1)
ds = Measure('ds', domain=mesh, subdomain_data=boundary_parts)
class K(fe.UserExpression):
    def __init__(self, materials, k_0, k_1, **kwargs):
        super().__init__(**kwargs)
        self.materials = materials
        self.k_0 = k_0
        self.k_1 = k_1
        if self.materials[cell.index] == 1:
            values[0] = self.k_0
            values[0] = self.k_1
    def value_shape(self):
        return ()
E_global = K(materials, E1, E2, degree=0)
DG = FunctionSpace(mesh, "DG", 2)
materials_function = Function(DG)
E_values = [E1, E2]
materials_function = project(E_global, DG)
MU1, LAMBDA1 = Constant(E1/(2*(1 + nu))), Constant(E1*nu/((1 + nu)*(1 - 2*nu)))
MU2, LAMBDA2 = Constant(E2/(2*(1 + nu))), Constant(E2*nu/((1 + nu)*(1 - 2*nu)))
class MUMU(fe.UserExpression):
    def __init__(self, materials, MU_0, MU_1, **kwargs):
        self.MU_0 = MU_0
        self.MU_1 = MU_1
            values[0] = self.MU_0
            values[0] = self.MU_1
        return ()
MU = MUMU(materials, MU1, MU2, degree=0)
class lamabada(fe.UserExpression):
    def __init__(self, materials, lam_0, lam_1, **kwargs):
        self.lam_0 = lam_0
        self.lam_1 = lam_1
            values[0] = self.lam_0
            values[0] = self.lam_1
        return ()
LAMBDA = lamabada(materials, LAMBDA1, LAMBDA2, degree=0)
# Define functions
du = TrialFunction(V)            # Incremental displacement
v = TestFunction(V)             # Test function
u = Function(V)                 # Displacement from previous iteration
B = Constant((0.0, 0.0, 0.0))  # Body force per unit volume
T = Constant((0.0, 0.0, 0.0))  # Traction force on the boundary
#u.vector()[:] = 0.0
# Define an initial guess as an Expression
initial_guess = Expression(("x[0]", "0", "0"), degree=1)
# Project or interpolate the initial guess onto u
u.interpolate(initial_guess)
# Kinematics
d = len(u)
I = Identity(d)             # Identity tensor
F = I + grad(u)             # Deformation gradient
C = F.T*F                   # Right Cauchy-Green tensor
CL = F*F.T
Ic = tr(C)
J = det(F)
# CS=  MU*(C-I)         # cauchy stress
# S= J*CS*inv(F).T
psi = (MU/2)*(Ic - 3) - MU*ln(J) + (LAMBDA/2)*(ln(J))**2
# Total potential energy
Pi = psi*dx - dot(B, u)*dx - neumann * dot(n, u)*ds(2)
# Compute first variation of Pi (directional derivative about u in the direction of v)
F = derivative(Pi, u, v)
# Compute Jacobian of F
Je = derivative(F, u, du)
# Solve variational problem
solver_parameters = {'newton_solver': {'maximum_iterations': 100,
                                       'absolute_tolerance': 1E-8,
                                       'relative_tolerance': 1E-7}}
solve(F == 0, u, bcs, J=Je, solver_parameters=solver_parameters)
# Deviatoric part
dev_stress = MU * (CL - I)
# Volumetric part
vol_stress = LAMBDA * ln(J) * I
sigma = (1/J) * (dev_stress + vol_stress)
S = FunctionSpace(mesh, "P", 1)  # Example function space
sigma_xx = project(sigma[0, 0], S)
points_of_interest = [(0.1, 0.1, 0.1), (0.5, 0.1, 0.1), (0.9, 0.1, 0.1)]  # Example points
for point in points_of_interest:
    try:
        sigma_xx_value = sigma_xx(point)
        print(f"sigma_xx at {point}: {sigma_xx_value}")
    except Exception as e:
        print(f"Could not evaluate sigma_xx at {point}: {e}")
# Save solution in VTK format
file = File("displacement.pvd");
file << u;
File("Materials.pvd")<< materials
vtkfile_subdomains = File('subdomains.pvd')
vtkfile_subdomains << materials
# Time-stepping loop
q = Constant(0.5)
dt = 0.25
dt = Constant(dt)
bF_magnitude = Constant(0.0)
t = 0
while t <= 5:
    t += float(dt)
    info("Time: {}".format(t))
    # Increase traction
    bF_magnitude.assign(100.0 * t)
    # Prepare to solve and solve
# Close files
materials_function.rename("materials", "")
u.rename("Displacement Vector", "")
beam_deflection_file = fe.XDMFFile("beam_deflection.xdmf")
beam_deflection_file.parameters["flush_output"] = True
beam_deflection_file.parameters["functions_share_mesh"] = True
beam_deflection_file.write(u, 0.0)
beam_deflection_file.write(materials_function, 0.0)
# Plot solution
plot(u)
# Close the XDMF files
beam_deflection_file.close()
clamped
withonlyxdirection
Honestly, this sentence is a mystery to me. Is there a typo “i only set direchlet” → “if I only set direchlet”?
What does it mean that you set the Dirichlet conditions via paraview? BCs are set in FEniCS, not in Paraview.
If you ask someone for help, It wouldn’t hurt to have the post written in a somewhat legible language.
What I understood from your question is that you only set constrain certain components (the x one, in particular) of the displacement field on the Dirichlet boundary. If that is indeed the case, then in principle the remaining components are free to move. If your plot is showing the mesh deformed by the displacement field, then the solution you see is compatible with the BCs you prescribed as long as the deformation on the Dirichlet boundary only occurs in the y and/or z direction.
hi,
what i meant to say is when i set direchlet conditions on the 3 component of x,y,z and then create and xdmf file and view it on paraview the rode seems to be clamped and the deformation is indeed showing on the y,z components only.
bcs = [bc1, bc2,bc3]
but if i change the direchlet condition to only on the x component and then export it to an xdmf file it seems to be moving completely from its original place like in the pic i attached
bcs = [bc1]
so what i wanted to ask is there is something wrong with how i define my boundary condition or it seems to be an expected behavior ?
btw, sorry for my “legible language”… i think there is a nicer way to say that my question is not clear enough
If you only constrain displacement in one component, you allow for several rigid motions, such as rotation around an axis, translation etc to be in your solution. You would then have to remove the nullspace from your solution.
where can i find some exp how to implement it ? how to remove the nullspace from the solution
See for instance Bitbucket
hi thanks for the reply
im trying to apply it on a nonlinear system(hyperplastic material), is it possible?
I think so, in the sense that you would need to apply it to the linear solver at every nonlinear iteration. However, I don’t have any example in mind that does that.
Maybe have a look at Welcome to Numerical tours of Computational Mechanics using FEniCS — Numerical tours of continuum mechanics using FEniCS master documentation if there is anything helpful.
thanks, went through it and also found an old doc of someone who was kind off trying to do the same as I.
im able to run my code with the addition of the nullspace but it does keep failing after few iterations , any idea what else can i change?
import fenics as fe
import os
def build_nullspace(V):
    x = Function(V).vector()
    nullspace_basis = [x.copy() for i in range(6)]
    V.sub(0).dofmap().set(nullspace_basis[0], 1.0)
    V.sub(1).dofmap().set(nullspace_basis[1], 1.0)
    V.sub(2).dofmap().set(nullspace_basis[2], 1.0)
    V.sub(0).set_x(nullspace_basis[3], -1.0, 1)
    V.sub(1).set_x(nullspace_basis[3],  1.0, 0)
    V.sub(0).set_x(nullspace_basis[4],  1.0, 2)
    V.sub(2).set_x(nullspace_basis[4], -1.0, 0)
    V.sub(1).set_x(nullspace_basis[5], -1.0, 2)
    V.sub(2).set_x(nullspace_basis[5],  1.0, 1)
    for x in nullspace_basis:
    	x.apply("insert")
    basis = VectorSpaceBasis(nullspace_basis)
    basis.orthonormalize()
    return basis
class Problem(NonlinearProblem):
    def __init__(self, J, J_pc, F, bcs):
        self.bilinear_form = J
        self.preconditioner_form = J_pc
        self.linear_form = F
        self.bcs = bcs
    def F(self, b, x):
        pass
    def J(self, A, x):
        pass
    def form(self, A, P, b, x):
        assemble(self.linear_form, tensor=b)
        assemble(self.bilinear_form, tensor=A)
        assemble(self.preconditioner_form, tensor=P)
        for bc in self.bcs:
            bc.apply(b, x)
            bc.apply(A)
            bc.apply(P)
        NS = build_nullspace(V)
        NS.orthogonalize(b)
class CustomSolver(NewtonSolver):
    def __init__(self):
        NewtonSolver.__init__(self, mesh.mpi_comm(),
                                  PETScKrylovSolver(), PETScFactory.instance())
    def solver_setup(self, A, P, problem, iteration):
        self.linear_solver().set_operators(A, P)
        as_backend_type(A).set_nullspace(NS)
        PETScOptions.set("ksp_type", "minres")
        PETScOptions.set("pc_type", "hypre")
        PETScOptions.set("ksp_view")
        self.linear_solver().set_from_options()
E1, E2, nu = 1, 10, 0.2
mesh = BoxMesh(Point(0, 0, 0), Point(length, width, height), num_elements, 5, 5)
#bcs = [bc1, bc2,bc3]
bcs=[bc1]
neumann = Expression(("0.1"), degree=0)
        self.k_0 = k_0
        self.k_1 = k_1
        return ()
E_values = [E1, E2]
        self.MU_0 = MU_0
        self.MU_1 = MU_1
        return ()
        self.lam_0 = lam_0
        self.lam_1 = lam_1
        return ()
# Define functions
#D=5e5*length**3/12(1-nu**2)
#initial_guess = Expression(("x[0]", "x[0]", "x[0]"), degree=2)
initial_guess = Expression(("amplitude*sin(pi*x[0]/length)", "0", "0"), degree=2, amplitude=0.1, length=length)
#initial_guess = Expression(("0.2/1.234", "x[0]", "x[0]"), degree=1)
# Kinematics
d = len(u)
CL = F*F.T                  # left cauchy-green tensor
Ic = tr(C)
J = det(F)
# S= J*CS*inv(F).T
J_pc = inner(grad(du), grad(v))*dx
problem=Problem(Je,J_pc, F, bcs)
custom_solver = CustomSolver()
custom_solver.solve(problem, u.vector())
# Deviatoric part
# Volumetric part
    try:
file << u;
q = Constant(0.5)
dt = 0.25
dt = Constant(dt)
t = 0
while t <= 5:
    t += float(dt)
    # Increase traction
# Close files
# Plot solution
plot(u)
this is the error i get
File “/home/mirialex/PycharmProjects/hyperelastic_model/20_02_1.py”, line 240, in
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** Git changeset: ubuntu
