BoundaryMesh(mesh, "interior", True) is returning an empty set
In the below MWE, I have an annulus with inner radius 1 and outer radius 2. I introduced a mesh on the annulus. I want to extract the coordinates of the nodes that lie on the inner circle. But
is returning an empty set. According to me, the above command must return the nodal coordinates on the inner circle.
MWE:
from mshr import Circle, generate_mesh
from dolfin import Mesh, File, MeshFunction, Point, BoundaryMesh, SubDomain, plot, File
C1 = Circle(Point(0, 0),1)
C2 = Circle(Point(0, 0),2)
C_1 = C2 - C1
class b1(SubDomain):
      return near(x[0]**2 + x[1]**2, 1, eps=1e-3) and on_boundary
class b2(SubDomain):
      return near(x[0]**2 + x[1]**2, 4, eps=1e-3) and on_boundary
class s1(SubDomain):
        return x[0]**2 + x[1]**2 > 1 and x[0]**2 + x[1]**2 < 4
mesh = generate_mesh(C_1, 5)
surface_markers = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
b1().mark(boundary_markers, 1)
b2().mark(boundary_markers, 2)
s1().mark(surface_markers, 5)
dx = Measure('dx', domain=mesh, subdomain_data=surface_markers)
inner_nodes = BoundaryMesh(mesh, "interior", True)
boundary_coordinates = inner_nodes.coordinates()
print(len(boundary_coordinates))
print(boundary_coordinates)
I also tried the commands BoundaryMesh(mesh, "local", True). This returns all the coordinates of the nodes both on the inner and the outer boundaries of the annulus. So how can I extract the nodal coordinates of just the nodes on the inner circle?
Any suggestions would be very helpful.
I would strongly suggest using an exterior mesh generator such as gmsh to generate your meshes. Then you can tag interior boundaries in the mesh generation, and import them to dolfin as xml or XDMF.
I would also suggest you have a look at the documentation, as from it is clear that “interior” is not what you want to use: https://fenicsproject.org/olddocs/dolfin/latest/cpp/d3/dcc/classdolfin_1_1BoundaryMesh.html#a864bd8b53c0588ba2a077feb4d500973
( std::string ) The type of BoundaryMesh, which can be “exterior”, “interior” or “local”. “exterior” is the globally external boundary, “interior” is the inter-process mesh and “local” is the boundary of the local (this process) mesh.
Hi @dokken ,
I always use gmsh for creating the mesh. I created an in-script mesh just for the MWE to demonstrate the problem.
I usually import the msh file from gmsh to dolfin and create xdmf for the surface (using surface markers) and the boundaries (using boundary markers). But I am not sure how to extract the boundary nodes from the xdmf itself.
I tried to do it using a vertex_to_dof_map in the following example
Consider the same annulus created in gmsh, with the gmsh script:
SetFactory("OpenCASCADE");
Circle(1) = {0, 0, 0, 2, 0, 2*Pi};
Circle(2) = {0, 0, 0, 1, 0, 2*Pi};
Curve Loop(1) = {1};
Curve Loop(2) = {2};
Plane Surface(1) = {1, 2};
Curve Loop(3) = {1};
Physical Curve("C1", 1) = {2};
Physical Curve("C2", 2) = {1};
Physical Surface("S1", 3) = {1};
The Python script for extracting the inner boundary coordinates is:
from dolfin import Mesh, XDMFFile, File, MeshValueCollection, cpp
               "eliminate_zeros": True, \
               "precompute_ip_const": True}
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
msh = meshio.read("bndycoord.msh")  # Inner circle has 12 nodes. Outer circle has 23 nodes. Interior has 24 nodes
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
   infile.read(mesh)
ds_custom = Measure("ds", domain=mesh, subdomain_data=mf)
mvc1 = MeshValueCollection("size_t", mesh, mesh.topology().dim())
   infile.read(mesh)
   infile.read(mvc1)
sur_mesh = cpp.mesh.MeshFunctionSizet(mesh, mvc1)
mvc2 = MeshValueCollection("size_t", mesh, mesh.topology().dim()-1)
    infile.read(mvc2)
bnd_mesh = cpp.mesh.MeshFunctionSizet(mesh, mvc2)
File('boundary1.pvd')<<bnd_mesh
V = FunctionSpace(mesh,'P',1)
vx = project(Expression("x[0]",degree=1),V)
vy = project(Expression("x[1]",degree=1),V)
vz = project(Expression("x[2]",degree=1),V)
v2d = vertex_to_dof_map(V)
dofs =[]
cx=[]
cy=[]
cz=[]
for facet in facets(mesh):
    if bnd_mesh[facet.index()]==3: # The surface has the physical tag 3
        vertices = facet.entities(0)
        for vertex in vertices:
            dofs.append(v2d[vertex])
unique_dofs = np.array(list(set(dofs)),dtype=np.int32)
boundary_coords = V.tabulate_dof_coordinates()[unique_dofs]
for i, dof in enumerate(unique_dofs):
    print(vx.vector()[dof][0],vy.vector()[dof][0],vz.vector()[dof][0])
print('number of boundary coordinates =', len(vx.vector())) # Gives 59: all the mesh nodes
What should be different here in order to find just the node coordinates on the inner circle?
Also, suppose I have a solution u on the annulus. Is it possible to find the values of u at the nodes on the inner circle without explicitly plugging in the coordinates of the nodes on the inner circle?
Consider the following (using the mesh that you supplied above):
                           cell_type: cells}, cell_data={"name_to_read": [cell_data]})
    return out_mesh
msh = meshio.read("annulus.msh")
mesh = Mesh()
    infile.read(mesh)
mf.array()[mf.array() > 1e3] = 0
File('boundary.pvd') << mf
vx = project(Expression("x[0]", degree=1), V)
vy = project(Expression("x[1]", degree=1), V)
vz = project(Expression("x[2]", degree=1), V)
dofs = []
cx = []
cy = []
cz = []
    if mf[facet.index()] == 1:  # The inner circle has boundary 1
unique_dofs = np.array(list(set(dofs)), dtype=np.int32)
u = interpolate(Expression("x[0]", degree=1), V)
print(boundary_coords, boundary_coords.shape)
print(u.vector().get_local()[unique_dofs])
