Consider a doubly connected region, for example, an annulus with inner radius 1 and outer radius 2. After meshing the annulus, the coordinates of the nodes on the exterior and the interior boundary (collectively) can be found by
BoundaryMesh(mesh, "exterior", True)
I need to find the coordinates of the inner and the outer boundary nodes separately. I can do that easily for this simple geometry. But in case of a doubly connected region with general smooth analytic boundary curves, how to do it? I tried BoundaryMesh(mesh, "interior", True), but that didn’t work and returned a null set.
Consider the simple MWE:
from mshr import Circle, generate_mesh
from dolfin import Mesh, File, MeshFunction, Point, BoundaryMesh, SubDomain, plot, File
"eliminate_zeros": True, \
"precompute_ip_const": True}
C1 = Circle(Point(0, 0),1)
C2 = Circle(Point(0, 0),2)
C_1 = C2 - C1
class b1(SubDomain):
return near(x[0]**2 + x[1]**2, 1, eps=1e-3) and on_boundary
class b2(SubDomain):
return near(x[0]**2 + x[1]**2, 4, eps=1e-3) and on_boundary
class s1(SubDomain):
return x[0]**2 + x[1]**2 > 1 and x[0]**2 + x[1]**2 < 4
mesh = generate_mesh(C_1, 5)
boundary_nodes = BoundaryMesh(mesh, "exterior", True)
boundary_coordinates = boundary_nodes.coordinates()
n1 = len(boundary_coordinates)
print('number of nodes on the boundary =',n1)
print('outer nodes coordinates =', boundary_coordinates)
boundary_nodes_inner = BoundaryMesh(mesh, "interior", True)
boundary_coordinates_inner = boundary_nodes_inner.coordinates()
n2 = len(boundary_coordinates_inner)
print('number of nodes on the boundary =',n2)
print('inner nodes coordinates =', boundary_coordinates_inner)
