I’m trying to speed up an Expression by using C++ code, as suggested in the tutorial Using C++ code snippets to define subdomains .
A minimal example derived from this tutorial
cppcode = “”"
class K : public Expression
public:void eval(Array& values,
const Array& x,
const ufc::cell& cell) const
values[0] = k_0;
double k_0;};
“”"kappa = Expression(cppcode=cppcode, degree=0)
kappa.k_0 = 0
already returns the error (with Fenics 2019.1.0):
Must supply C++ code to Expression. You may want to use UserExpression
What am I missing here?
A similar question has been asked in Cpp-based Expression.
The answer suggest that the string should work as R-value to values[0]. I wouldn’t be happy with this, because I would need to load different values (like k_0) into the C++ class and return them depending on x.
Thanks & Regards,
Thomas
