I am trying to calculate volumetric flow rate at an internal boundary x=0.2. My velocity, pressure, etc. are correct, but I am getting an incorrect flow rate. Also, if I refine my mesh, the flow rate value changes.
from ufl_legacy import indices, Jacobian, Min
####### Domain and mesh setup #######
# Parameters defining domain geometry:
SOLID_LEFT = 0.45
SOLID_RIGHT = 0.55
SOLID_TOP = 0.5
OMEGA_H = 0.75
OMEGA_W = 1.0
REF_MARGIN = 0.1
# Define the mshr geometrical primitives for this domain:
r_Omega = Rectangle(Point(0,0),Point(OMEGA_W,OMEGA_H))
r_Omega_s = Rectangle(Point(SOLID_LEFT,0),
Point(SOLID_RIGHT,SOLID_TOP))
r_Omega_int = Rectangle(Point(0,0),
Point(0.2,OMEGA_H))
# Enumerate subdomain markers
FLUID_FLAG = 0
SOLID_FLAG = 1
INT_FLAG = 5
# Zero is the default flag, and does not need to be
# explicitly set for the fluid subdomain.
r_Omega.set_subdomain(SOLID_FLAG,r_Omega_s)
r_Omega.set_subdomain(INT_FLAG,r_Omega_int)
# Parameters defining refinement level:
N = 32
# Generate mesh of Omega, which will have a fitted
# subdomain for Omega_s.
mesh = generate_mesh(r_Omega, N)
# Mesh-derived quantities:
d = mesh.geometry().dim()
n_y = FacetNormal(mesh)
I = Identity(d)
# Marking internal boundary
boundaries = MeshFunction("size_t", mesh, d-1,0)
for f in facets(mesh): # For all edges in the mesh
p0 = Vertex(mesh, f.entities(0)[0]) # save the two ending points p0 and p1
p1 = Vertex(mesh, f.entities(0)[1])
if near(p0.x(0), 0.2, DOLFIN_EPS) and near(p1.x(0), 0.2, DOLFIN_EPS): # check if the points lie on the circle - if yes, put a label on this edge
boundaries[f] = 4
# Define surface integral
dS_int = Measure("dS", domain=mesh, subdomain_data=boundaries)
# Calculating Flow rate
# Here v is velocity. I am sure that the velocity field is correct
Q_surf = assemble((dot((v),n_y('+'))*dS_int(4)))
I also tried to visualize ‘boundaries’. They look correct.
Please correct me.
Thank you!
