@dokken, I sincerely apologize for reaching out to you once again, but is there any possibility you could assist me in resolving this issue? I reached out to the Hypermesh community and was advised that the problem might be related to the Gmsh file, but I haven’t yet received a response from the Gmsh community.
Please note that you are simply not reading in your facet tags correctly:
from pathlib import Path
cell_data = mesh.get_cell_data("nastran:ref", cell_type)
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells},
cell_data={"Region": [cell_data]})
return out_mesh
if MPI.COMM_WORLD.rank == 0:
filename = 'linear_elasticity_test.bdf'
msh = meshio.read(filename)
hex_mesh = create_mesh(msh, "hexahedron", False)
meshio.write("hex.xdmf", hex_mesh)
quad_mesh = create_mesh(msh, "quad", False)
meshio.write("quad.xdmf", quad_mesh)
MPI.COMM_WORLD.barrier()
filename_facets = 'quad.xdmf' # quad meshes to apply fixed boundary condition.
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "hex.xdmf", "r") as xdmf:
with dolfinx.io.XDMFFile(mesh.comm, filename_facets, "r") as xdmf:
facet_tags = xdmf.read_meshtags(mesh, name="Grid")
print(facet_tags.indices, facet_tags.values)
Reads facet_tags in for your hexahedral mesh.
The reason that you cannot read in the facet_tags on a grid based of facets, is that the “quad.xdmf” grid contains nodes that are not in the actual mesh, causing a right mess inside DOLFINx.
@dokken, thank you very much for your response. The solution you suggested worked perfectly, and the problem has been successfully resolved.
