Importing XMDF file into workspace file
Hey y’all. I am working on an indentation model with penalty formulation. I have had a Python file which included both the generation of the mesh with Gmsh and solving the problem out, but as the project continues it was evident to separate the mesh formation from the solving into different files, so that when changes in the mesh occur I don’t have to solve the entire problem again. I used the code below to extract and save the mesh into .h5 and .xmdf files, and it works great.
msh_data = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
gmsh.finalize()
domain = msh_data.mesh
cell_tags = msh_data.cell_tags
facet_tags = msh_data.facet_tags
gdim = domain.geometry.dim
cell_tags.name = "cell_tags"
facet_tags.name = "facet_tags"
with io.XDMFFile(domain.comm, "axisymmetric_mesh.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
# Saving Physical Groups
xdmf.write_meshtags(cell_tags, domain.geometry)
xdmf.write_meshtags(facet_tags, domain.geometry)
But an issue comes when I try to bring the mesh into my new file for solving. I have the code below:
#DOLFINX Imports
from dolfinx import mesh, fem, plot, io
with io.XDMFFile(MPI.COMM_WORLD, "axisymmetric_mesh.xdmf", "r") as xdmf:
#Read the mesh topology and geometry
domain = xdmf.read_mesh(name="mesh")
#Pulling saved tags
cell_tags = xdmf.read_meshtags(domain, name="cell_tags")
facet_tags = xdmf.read_meshtags(domain, name="facet_tags")
Specifically, I get the following error below:
mt = super().read_meshtags(mesh.\_cpp_object, name, attribute_name, xpath)
RuntimeError: Missing IndexMap in Topology. Maybe you need to create_entities(1).
Has anyone come across a similar issue, if so, how did you fix the issue? For reference I am using version 0.10.0 if Dolfinx and version 4.15.1 of Gmsh. Additionally, the mesh is set up correctly, because in the file where both mesh generation and solving occur together, there are no issues.
Hi, I think you need to create cell-facet connectivity before reading the facet tags. Try adding this between reading the mesh and reading the facet tags:
tdim = domain.topology.dim
fdim = tdim - 1
This worked perfectly. Thank you so much for the help!
