Cannot remove complex parts from form
Hello! I’m currently fighting my way around the lack of complex support in the stable FEniCS Project, and gratefully awaiting its inclusion in the next release. I am using UFL to construct a long variational form that is infeasible to separate into real and complex parts by hand so that I can solve them separately. I am using a combination of ufl.real(), ufl.imag() to split the real and imaginary parts. Since ufl.imag() returns a complex expression, I am trying to remove the Imag() node with remove_complex_nodes() in ufl.algorithms. However, remove_complex_nodes() does not accept complex expressions! I have replicated this with fenics 2019.1.0 in a docker image and a conda environment. Does anyone have a solution? I would be very grateful! Thank you.
p1 = TrialFunction(Q)
ufl.algorithms.remove_complex_nodes.remove_complex_nodes(1j*p1)
UFLException                              Traceback (most recent call last)
<ipython-input-18-09a33dfa5617> in <module>
      1 p1, p2 = TrialFunction(Q), TrialFunction(Q)
      2
----> 3 ufl.algorithms.remove_complex_nodes.remove_complex_nodes(p1+1j*p2)
/usr/local/lib/python3.6/dist-packages/ufl/algorithms/remove_complex_nodes.py in remove_complex_nodes(expr)
     35     support from the preprocessed form.
     36     """
---> 37     return map_integrand_dags(ComplexNodeRemoval(), expr)
/usr/local/lib/python3.6/dist-packages/ufl/algorithms/map_integrands.py in map_integrand_dags(function, form, only_integral_type, compress)
     56 def map_integrand_dags(function, form, only_integral_type=None, compress=True):
     57     return map_integrands(lambda expr: map_expr_dag(function, expr, compress),
---> 58                           form, only_integral_type)
/usr/local/lib/python3.6/dist-packages/ufl/algorithms/map_integrands.py in map_integrands(function, form, only_integral_type)
     49     elif isinstance(form, Expr):
     50         integrand = form
---> 51         return function(integrand)
     52     else:
     53         error("Expecting Form, Integral or Expr.")
/usr/local/lib/python3.6/dist-packages/ufl/algorithms/map_integrands.py in <lambda>(expr)
     55
---> 57     return map_integrands(lambda expr: map_expr_dag(function, expr, compress),
/usr/local/lib/python3.6/dist-packages/ufl/corealg/map_dag.py in map_expr_dag(function, expression, compress)
     35     Return the result of the final function call.
     36     """
---> 37     result, = map_expr_dags(function, [expression], compress=compress)
     38     return result
     39
/usr/local/lib/python3.6/dist-packages/ufl/corealg/map_dag.py in map_expr_dags(function, expressions, compress)
     84                 r = handlers[v._ufl_typecode_](v)
     85             else:
---> 86                 r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
     87
     88             # Optionally check if r is in rcache, a memory optimization
/usr/local/lib/python3.6/dist-packages/ufl/algorithms/remove_complex_nodes.py in terminal(self, t, *ops)
     24     def terminal(self, t, *ops):
     25         if isinstance(t, ComplexValue):
---> 26             error('Unexpected complex value in real expression.')
     27         else:
     28             return t
/usr/local/lib/python3.6/dist-packages/ufl/log.py in error(self, *message)
    170         "Write error message and raise an exception."
    171         self._log.error(*message)
--> 172         raise self._exception_type(self._format_raw(*message))
    173
    174     def begin(self, *message):
UFLException: Unexpected complex value in real expression.
Or, does anyone know of a different way to do this? Thank you!
