Can't compute infinity norm
I am trying to compute different norm types (L1, L2, Linf) and have been using the stokes flow demo as practice (link). I am using the bottom method of solving the problem (Non-Blocked Direct Solver) and when I go to compute the infinite norm of the velocity and pressure, I get this error
Invoked with types: dolfinx.cpp.fem.Function_float64, str
To compute the infinite norm I am using this line of code
norm_inf_u = la.norm(u, 'linf')
When looking at the DOLPHIN documentation they give an example with this same line (Dolphin norm documentation)
I have also found the DOLFINx documentation (DOLPHINx Norm documentation) and when I tried the line of code,
norm_inf_u = la.norm(u.x, type=2)
I get the following error
Invoked with types: dolfinx.cpp.la.Vector_float64, int
How do I compute different norms of the velocity and pressure field?
I am using FEniCSx version 0.8, installed on linux using anaconda.
Here is my code, I have tried to remove as much as possible from it
from dolfinx import fem, la
from dolfinx.fem import (
    Function,
    dirichletbc,
    form,
    functionspace,
    locate_dofs_topological,
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from ufl import div, dx, grad, inner
# Create mesh
msh = create_rectangle(
    MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])], [128, 128], CellType.triangle
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
    return np.isclose(x[0], 0.0) | np.isclose(x[0], 1.0) | np.isclose(x[1], 0.0)
# Function to mark the lid (y = 1)
def lid(x):
    return np.isclose(x[1], 1.0)
# Lid velocity
def lid_velocity_expression(x):
    return np.stack((np.ones(x.shape[1]), np.zeros(x.shape[1])))
P2 = element("Lagrange", msh.basix_cell(), 2, shape=(msh.geometry.dim,))
P1 = element("Lagrange", msh.basix_cell(), 1)
V, Q = functionspace(msh, P2), functionspace(msh, P1)
def mixed_direct():
    # Create the Taylot-Hood function space
    TH = mixed_element([P2, P1])
    W = functionspace(msh, TH)
    # No slip boundary condition
    W0 = W.sub(0)
    Q, _ = W0.collapse()
    noslip = Function(Q)
    facets = locate_entities_boundary(msh, 1, noslip_boundary)
    dofs = locate_dofs_topological((W0, Q), 1, facets)
    bc0 = dirichletbc(noslip, dofs, W0)
    # Driving velocity condition u = (1, 0) on top boundary (y = 1)
    lid_velocity = Function(Q)
    lid_velocity.interpolate(lid_velocity_expression)
    facets = locate_entities_boundary(msh, 1, lid)
    bc1 = dirichletbc(lid_velocity, dofs, W0)
    bcs = [bc0, bc1]
    (v, q) = ufl.TestFunctions(W)
    f = Function(Q)
    a = form((inner(grad(u), grad(v)) + inner(p, div(v)) + inner(div(u), q)) * dx)
    L = form(inner(f, v) * dx)
    # Assemble LHS matrix and RHS vector
    A = fem.petsc.assemble_matrix(a, bcs=bcs)
    b = fem.petsc.assemble_vector(L)
    fem.petsc.apply_lifting(b, [a], bcs=[bcs])
    # Set Dirichlet boundary condition values in the RHS
    fem.petsc.set_bc(b, bcs)
    # Create and configure solver
    ksp.setOperators(A)
    ksp.setType("preonly")
    # Configure MUMPS to handle pressure nullspace
    pc = ksp.getPC()
    pc.setType("lu")
    # Compute the solution
    U = Function(W)
    try:
        ksp.solve(b, U.x.petsc_vec)
    except PETSc.Error as e:
        if e.ierr == 92:
            print("The required PETSc solver/preconditioner is not available. Exiting.")
            print(e)
            exit(0)
            raise e
    u, p = U.sub(0).collapse(), U.sub(1).collapse()
    # Compute norms
    norm_u, norm_p = la.norm(u.x), la.norm(p.x)
    if MPI.COMM_WORLD.rank == 0:
        print(f"(D) Norm of velocity coefficient vector (monolithic, direct): {norm_u}")
        print(f"(D) Norm of pressure coefficient vector (monolithic, direct): {norm_p}")
    return norm_u, norm_u, u, p, U
# Solve using a non-blocked matrix and an LU solver
norm_u_3, norm_p_3, u, p, U = mixed_direct()
Try using dolfinx.la.Norm.linf.
Thank you for the quick response, I updated my code to have the following line
from dolfinx import *
norm_inf_u = dolfinx.la.Norm.linf(u.x)
And I get the following error
NameError: name 'dolfinx' is not defined
If I remove the dolfinx. from the line and instead use
norm_inf_u = la.Norm.linf(u.x)
TypeError: 'dolfinx.cpp.la.Norm' object is not callable
Something like
norm_inf_u = la.norm(u.x, type=dolfinx.la.Norm.linf)
Thank you for your help, your solution worked
