Challenges in reproducing phase-field fracture benchmark: Unphysical crack trajectory and mesh refinement behavior
Hi, every FEniCSx uesrs. I’m implementing an adaptive phase-field fracture model in FEniCSx (dolfinx), closely following the approach in Giri et al. (2025, Finite Elements in Analysis and Design). The benchmark is a 1×1 mm edge-cracked domain under uniaxial tension (Mode I). Despite matching the paper’s AMR criterion (φ ≥ 0.25, h ≥ l0/2), I observe two persistent issues:
1. Non-straight crack path — the crack deviates from the expected horizontal trajectory, producing a visibly jagged path with local wiggles.
2. Over-refinement — the refinement band is much wider than the crack itself, and the final mesh (~32,000 elements) is larger than the paper’s (~28,000), even though the initial mesh (3,700 triangles, lc = 0.025) matches.
What I’ve ruled out so far:
  • Mesh anisotropy from gmsh Delaunay (tried Frontal-Delaunay with Mesh.Algorithm = 6, identical results)
  • Convergence tolerance (tol = 1e-5, standard)
  • History variable projection after refinement (using interpolate_nonmatching)
Related details:
# Material & model
E = 210.0, nu = 0.3, Gc = 2.7e-3, l0 = 0.01  # kN/mm², mm
# AMR criterion (from the paper)
if max(phi_per_cell) >= 0.25 and h_cell > l0 / 2.0:
    refine cell
# BCs: bottom fully fixed (u_x = u_y = 0), top prescribed u_y
# Staggered scheme, P1 elements, ATS sub-stepping
About Load-displacement :
Peak load ~720 N at u ≈ 0.0061 mm, roughly consistent with the paper, but the post-peak softening is noisy with frequent ATS rejections.
Suspicions:
  • Bottom BC: fully fixed (u_x = 0) prevents Poisson contraction. Could this distort the stress field near the crack tip?
  • Edge-bisection refinement creating anisotropic refinement patterns?
  • Something else in the staggered scheme or history variable update?
Has anyone encountered similar issues with jagged crack paths in dolfinx phase-field simulations? Any advice on debugging or fixing this would be greatly appreciated. I’m happy to share the full code.
The current problem is that the program always yields the crack propagation path of type i and type ii fracture composites. I don’t know where the issue lies.
What’s more annoying is that new users are unable to upload pictures, so I can’t show you the problem I encountered.
I would suggest that you add the code so people can reproduce the issue.
This is due to some historical issues we have had with bots posting pornography and other unsuitable content on the forum.
Sorry, there is a problem with the code that I just uploaded. Please take a look at the following one.
def generate_initial_mesh(L=1.0, W=1.0, a=0.5, lc=lc_initial):
    Symmetric mesh via OCC copy+mirror+fragment.
    Bottom half mirrored about y=W/2, then fragmented for shared interface.
    Guaranteed node symmetry above/below y=0.5.
    from dolfinx.io.gmsh import model_to_mesh
    gmsh.option.setNumber("General.Terminal", 0)
    gmsh.model.add("symmetric_mirror")
    eps = 1e-6
    y_mid = W / 2.0
    # 1. Bottom half rectangle [0,L] x [0, y_mid]
    s_bottom = gmsh.model.occ.addRectangle(0, 0, 0, L, y_mid)
    gmsh.model.occ.synchronize()
    # 2. Copy + mirror about y=y_mid
    copied = gmsh.model.occ.copy([(2, s_bottom)])
    gmsh.model.occ.mirror(copied, 0, 1, 0, -y_mid)
    # 3. Fragment to merge overlapping curves on y=y_mid
    s_top = copied[0][1]
    gmsh.model.occ.fragment([(2, s_bottom)], [(2, s_top)])
    # 4. Identify boundaries via bounding box
    all_surfaces = gmsh.model.getEntities(2)
    bottom_curves = gmsh.model.getEntitiesInBoundingBox(
        -eps, -eps, -eps, L+eps, eps, eps, 1)
    right_curves = gmsh.model.getEntitiesInBoundingBox(
        L-eps, -eps, -eps, L+eps, W+eps, eps, 1)
    top_curves = gmsh.model.getEntitiesInBoundingBox(
        -eps, W-eps, -eps, L+eps, W+eps, eps, 1)
    left_all = gmsh.model.getEntitiesInBoundingBox(
        -eps, -eps, -eps, eps, W+eps, eps, 1)
    # Crack: all curves on y=y_mid (interface), used for physical group
    crack_curves = gmsh.model.getEntitiesInBoundingBox(
        -eps, y_mid-eps, -eps, L+eps, y_mid+eps, eps, 1)
    # Filter left curves: exclude interface curves
    left_curves = []
    for dim, tag in left_all:
        bbox = gmsh.model.getBoundingBox(dim, tag)
        my = (bbox[1] + bbox[4]) / 2
        if abs(my - y_mid) > eps * 10:
            left_curves.append((dim, tag))
    # 5. Physical groups
    gmsh.model.addPhysicalGroup(
        2, [s[1] for s in all_surfaces], TAG_DOMAIN, name="Domain")
        1, [c[1] for c in bottom_curves], TAG_BOTTOM, name="Bottom")
        1, [c[1] for c in right_curves], TAG_RIGHT, name="Right")
        1, [c[1] for c in top_curves], TAG_TOP, name="Top")
        1, [c[1] for c in left_curves], TAG_LEFT, name="Left")
        1, [c[1] for c in crack_curves], TAG_CRACK, name="Crack")
    # 6. Uniform mesh size
    gmsh.option.setNumber("Mesh.MeshSizeMin", lc)
    gmsh.option.setNumber("Mesh.MeshSizeMax", lc)
    gmsh.model.mesh.generate(2)
    mesh_data = model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
    domain, cell_tags, facet_tags = mesh_data.mesh, mesh_data.cell_tags, mesh_data.facet_tags
    gmsh.finalize()
    return domain, facet_tags
def setup_problem(domain, facet_tags):
    V_u = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
    V_phi = fem.functionspace(domain, ("Lagrange", 1))
    u = fem.Function(V_u, name="Displacement")
    phi = fem.Function(V_phi, name="PhaseField")
    phi_old = fem.Function(V_phi)
    H = fem.Function(V_phi, name="History")
    E = fem.Constant(domain, default_scalar_type(E_val))
    nu = fem.Constant(domain, default_scalar_type(nu_val))
    gc = fem.Constant(domain, default_scalar_type(gc_val))
    l0 = fem.Constant(domain, default_scalar_type(l0_val))
    k_res = fem.Constant(domain, default_scalar_type(1e-6))
    lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
    mu = E / (2.0 * (1.0 + nu))
    def eps(u_): return ufl.sym(ufl.grad(u_))
    def psi_plus(u_):
        e = eps(u_)
        tr_e = ufl.tr(e)
        det_e = ufl.det(e)
        gap = ufl.sqrt(ufl.max_value((tr_e / 2.0)**2 - det_e, 0.0))
        eps1 = tr_e / 2.0 + gap
        eps2 = tr_e / 2.0 - gap
        def mac_plus(x): return ufl.max_value(x, 0)
        return 0.5 * lmbda * mac_plus(tr_e)**2 + mu * (mac_plus(eps1)**2 + mac_plus(eps2)**2)
    def sigma(u_): return lmbda * ufl.tr(eps(u_)) * ufl.Identity(domain.geometry.dim) + 2.0 * mu * eps(u_)
    def g(phi_): return (1.0 - phi_)**2 + k_res
    u_trial, v = ufl.TrialFunction(V_u), ufl.TestFunction(V_u)
    phi_trial, q = ufl.TrialFunction(V_phi), ufl.TestFunction(V_phi)
    a_u = ufl.inner(g(phi) * sigma(u_trial), eps(v)) * ufl.dx
    L_u = ufl.inner(fem.Constant(domain, default_scalar_type((0.0, 0.0))), v) * ufl.dx
    a_phi = (gc * l0 * ufl.inner(ufl.grad(phi_trial), ufl.grad(q)) + (gc / l0 + 2.0 * H) * phi_trial * q) * ufl.dx
    L_phi = (2.0 * H * q) * ufl.dx
    t_disp = fem.Constant(domain, default_scalar_type(0.0))
    # BC: bottom fixed, top uy = t_disp (same as PMB2_1/paper)
    domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
    bottom_facets = facet_tags.find(TAG_BOTTOM)
    bottom_dofs = fem.locate_dofs_topological(V_u, domain.topology.dim - 1, bottom_facets)
    bc_bottom = fem.dirichletbc(np.array([0.0, 0.0], dtype=default_scalar_type), bottom_dofs, V_u)
    top_facets = facet_tags.find(TAG_TOP)
    top_dofs_y = fem.locate_dofs_topological(V_u.sub(1), domain.topology.dim - 1, top_facets)
    bc_top = fem.dirichletbc(t_disp, top_dofs_y, V_u.sub(1))
    # top_dofs_x = fem.locate_dofs_topological(V_u.sub(0), domain.topology.dim - 1, top_facets)
    # bc_top_x = fem.dirichletbc(default_scalar_type(0.0), top_dofs_x, V_u.sub(0))
    bcs_u = [bc_bottom, bc_top]
    # bcs_u = [bc_bottom, bc_top, bc_top_x]
    problem_u = LinearProblem(a_u, L_u, bcs=bcs_u,
        petsc_options={"ksp_type": "cg", "pc_type": "gamg", "ksp_rtol": 1e-8}, petsc_options_prefix='p_u')
    problem_phi = LinearProblem(a_phi, L_phi, bcs=[],
        petsc_options={"ksp_type": "cg", "pc_type": "jacobi", "ksp_rtol": 1e-8}, petsc_options_prefix='p_phi')
    return {
        "mesh": domain, "facet_tags": facet_tags,
        "V_u": V_u, "V_phi": V_phi,
        "u": u, "phi": phi, "phi_old": phi_old, "H": H,
        "E": E, "nu": nu, "gc": gc, "l0": l0, "k_res": k_res,
        "lmbda": lmbda, "mu": mu,
        "eps": eps, "psi_plus": psi_plus, "g": g, "sigma": sigma,
        "t_disp": t_disp,
        "problem_u": problem_u, "problem_phi": problem_phi,
        "ds": ufl.Measure("ds", domain=domain, subdomain_data=facet_tags),
# 4. Main simulation (no AMR, no ATS)
domain, facet_tags = generate_initial_mesh()
sys = setup_problem(domain, facet_tags)
# Initial crack: phi=1 on y=0.5, x<=0.5 (geometric, no TAG_CRACK needed)
def crack_marker(x):
    return np.logical_and(x[0] <= 0.5 + 1e-10, np.isclose(x[1], 0.5, atol=1e-10))
crack_dofs = fem.locate_dofs_geometrical(sys["V_phi"], crack_marker)
sys["phi"].x.array[crack_dofs] = 1.0
sys["phi_old"].x.array[:] = sys["phi"].x.array[:]
sys["H"].x.array[crack_dofs] = 1e10
# Reaction force form
load_form = fem.form(sys["g"](sys["phi"]) * (
    sys["lmbda"] * ufl.tr(sys["eps"](sys["u"])) * ufl.Identity(2)
    + 2 * sys["mu"] * sys["eps"](sys["u"]))[1, 1] * sys["ds"](TAG_TOP))
results_disp = []
results_load = []
u_total = 0.0
num_cells_global = domain.topology.index_map(domain.topology.dim).size_global
print(f"Start PFM simulation (uniform mesh, no AMR, no ATS)")
print(f"Mesh: {num_cells_global} cells, lc={lc_initial}")
print(f"Loading: du1={delta_u_stage1:.0e} up to u={u_stage_switch}, du2={delta_u_stage2:.0e} to u={u_max}")
print()
while u_total < u_max:
    # Two-stage fixed step size (paper PFM_C)
    if u_total < u_stage_switch:
        delta_u = delta_u_stage1
        delta_u = delta_u_stage2
    delta_u = min(delta_u, u_max - u_total)
    u_trial = u_total + delta_u
    sys["t_disp"].value = default_scalar_type(u_trial)
    # Staggered iteration
    converged = False
    for iter_count in range(iter_max):
        # Solve displacement
        u_res = sys["problem_u"].solve()
        sys["u"].x.array[:] = u_res.x.array[:]
        # Update history field
        psi_expr = fem.Expression(sys["psi_plus"](sys["u"]), sys["V_phi"].element.interpolation_points)
        psi_vals = fem.Function(sys["V_phi"])
        psi_vals.interpolate(psi_expr)
        sys["H"].x.array[:] = np.maximum(psi_vals.x.array, sys["H"].x.array)
        # Solve phase field
        phi_res = sys["problem_phi"].solve()
        sys["phi"].x.array[:] = phi_res.x.array[:]
        sys["phi"].x.array[:] = np.clip(sys["phi"].x.array, 0.0, 1.0)
        # Convergence check
        error_local = fem.assemble_scalar(fem.form((sys["phi"] - sys["phi_old"])**2 * ufl.dx))
        error_global = sys["mesh"].comm.allreduce(error_local, op=MPI.SUM)
        norm_local = fem.assemble_scalar(fem.form(sys["phi"]**2 * ufl.dx))
        norm_global = sys["mesh"].comm.allreduce(norm_local, op=MPI.SUM)
        rel_error = np.sqrt(error_global) / (np.sqrt(norm_global) + 1e-12)
        if rel_error < tol_staggered:
            converged = True
            break
    N_iter = iter_count + 1
    if not converged:
        print(f"  Warning: step at u={u_trial:.6f} did not converge ({N_iter} iters, err={rel_error:.2e})")
    u_total = u_trial
    # Reaction force
    local_load = fem.assemble_scalar(load_form)
    global_load = sys["mesh"].comm.allreduce(local_load, op=MPI.SUM)
    results_load.append(global_load)
    results_disp.append(u_total)
    print(f"Step {len(results_disp):4d} | u={u_total:.6f} | iter={N_iter} | "
          f"max_phi={np.max(sys["phi"].x.array):.3f} | F={global_load*1000:.2f} N")
print()
print(f"Simulation finished. Steps={len(results_disp)}, cells={num_cells_global}")
Now I can upload pictures!!! I drew two diagrams. The first one is a displacement field cloud map, and the second one is a phase field cloud map. As you can see, the crack path did not expand in a horizontal direction. Instead, it tended towards a composite crack of type i (stretching) and type ii (shearing).
I tried many approaches, including modifying the feature length l0, the grid size lc, the boundary conditions, the iteration method, and the grid generation, etc. However, without exception, none of them could solve the problem.
But perhaps it’s a problem with my own abilities. So I really hope that some experienced person can solve my issue.
Explanation of the generate_initial_mesh function: To construct a structured grid, I adopted the approach of dividing the domain at y = 0.5 into two rectangular sections, with the fracture segment (x ≤ a) not sharing nodes and the ligament segment (x > a) sharing nodes. Thus, Gmsh independently performs Delaunay triangulation on the two subdomains, each naturally symmetrically, and the result of the run shows that I have not solved the problem; there are still composite fractures.
The mesh generated by the “generate_initial_mesh” function looks like this
Below is my complete code.
Uses a globally uniform fine mesh and
two-stage fixed displacement increments (paper PFM_C approach).
from dolfinx import fem, mesh, io, plot, default_scalar_type
# 1. Physical tags and parameters
TAG_DOMAIN = 1
TAG_BOTTOM = 2
TAG_RIGHT = 3
TAG_TOP = 4
TAG_LEFT = 5
TAG_CRACK = 6
# Material parameters (mm, kN)
E_val = 210.0          # kN/mm^2
nu_val = 0.3
gc_val = 2.7e-3        # kN/mm (2.7 N/mm)
l0_val = 0.015          # mm
# Mesh: uniform fine mesh, no AMR
lc_initial = 0.005     # = l0/2, matches paper PFM_C (~92k cells)
# To reduce runtime, try lc_initial = 0.01 (~23k cells)
# Fixed two-stage displacement increments (paper PFM_C)
delta_u_stage1 = 1.0e-5    # mm, up to u = 5e-3
delta_u_stage2 = 1.0e-6    # mm, after u = 5e-3
u_stage_switch = 5.0e-3
u_max = 0.007
# Staggered solver
tol_staggered = 1.0e-6
iter_max = 15
# 2. Mesh generation
    eps = 1e-6
    y_mid = W / 2.0
    left_curves = []
    gmsh.finalize()
    def psi_plus(u_):
        e = eps(u_)
        tr_e = ufl.tr(e)
        det_e = ufl.det(e)
    return {
        "t_disp": t_disp,
results_disp = []
results_load = []
u_total = 0.0
print()
    converged = False
        # Solve phase field
        # Convergence check
            converged = True
            break
    if not converged:
    u_total = u_trial
    # Reaction force
print()
# 5. Visualization
# Phase field with mesh edges
import pyvista
topology_phi, cell_types_phi, geometry_phi = plot.vtk_mesh(sys["V_phi"])
grid_phi = pyvista.UnstructuredGrid(topology_phi, cell_types_phi, geometry_phi)
grid_phi.point_data["phi"] = sys["phi"].x.array.real
grid_phi.set_active_scalars("phi")
plotter = pyvista.Plotter(window_size=(900, 800))
plotter.set_background("white")
plotter.add_mesh(grid_phi, show_edges=False,
                cmap="coolwarm", clim=[0, 1])
plotter.add_text(f"Phase Field (u={u_total:.4f} mm, {num_cells_global} cells)",
                 font_size=12, color="black")
plotter.view_xy()
plotter.show()
# Displacement magnitude
u_mag = np.sqrt(sys["u"].x.array[0::2]**2 + sys["u"].x.array[1::2]**2)
topology_u, cell_types_u, geometry_u = plot.vtk_mesh(sys["V_u"])
grid_u = pyvista.UnstructuredGrid(topology_u, cell_types_u, geometry_u)
grid_u.point_data["|u|"] = u_mag.real
grid_u.set_active_scalars("|u|")
plotter2 = pyvista.Plotter(window_size=(900, 800))
plotter2.set_background("white")
plotter2.add_mesh(grid_u, show_edges=False,
                cmap="viridis")
plotter2.add_text(f"Displacement Magnitude (u={u_total:.4f} mm)",
plotter2.view_xy()
plotter2.show()
At first, I intended to replicate the ATS + AMR form used in the first numerical experiment of the paper, but I failed to do so consistently. Therefore, I gave up and simply went ahead with the global fixed-grid version.
The title of the paper is
Accelerated adaptive phase-field fracture model with an efficient sub-stepping scheme
I would like to know how the crack initialization for the uniaxial notch tensile test is carried out. Is it by embedding the crack line + the initial history field H, or by directly creating a geometric notch on the sample? In Miehe’s (2010) paper, I didn’t see how this condition was set. Do you know?
I never worked with AMR + phase-field, but I would rely on the implementations and scientific background of the phase-field by @cmaurini. You can find here the simplest implementation possible: Gradient damage as phase-field models of brittle fracture: dolfinx example — FEniCSx Fracture Mechanics.
Btw, regarding your crack’s path, it looks like it’s mode II rather than mode I. Double-check how you assign tags to ur gmsh curves.
I’m sorry for replying to you so late. The content of the link you sent is very useful. I will conduct some experiments to see if I can solve my problem. I will show my results later.
In conclusion, I would like to express my sincere gratitude for your reply.
I studied the content in this link and improved my experiment based on its ideas. Finally, I obtained the following picture (after post-processing with Paraview)
Congrats! The right part looks a bit wider than the left one. I guess it’s due to unconstructed mesh. Make sure that the mesh size is small enough to discretize the damage band: you need to set the mesh size 4-5 times smaller than the regularization length.
