Hey guys,
Im currently working on my bachelor thesis and i started with coding a linear elasticity problem with a phase field to detect a crack on my domain. Unfortunately the phi in the calculation is not evolving the way I want it to. In the picture above you can see that the phi evolves more like a surface than a crack and I do not really know why. My code is based on this paper by Hirshikesh et al. The mesh is made with Gmsh, I will also post the gmsh script below. Maybe some of you have a clue how to fix this code, I would be very grateful for any help.
Paper: A FEniCS implementation of the phase field method for
quasi-static brittle fracture
Regards, Leandro
**GMSH:**
gmsh.model.add("testmesh3")
lc = 5
width=1
gmsh.model.geo.addPoint(0,0,0, lc)
gmsh.model.geo.addPoint(90,0,0, lc)
gmsh.model.geo.addPoint(100,0,42, lc)
gmsh.model.geo.addPoint(110,0,0, lc)
gmsh.model.geo.addPoint(200,0,0, lc)
gmsh.model.geo.addPoint(200,0,50, lc)
gmsh.model.geo.addPoint(0,0,50, lc)
gmsh.model.geo.addLine(1,2)
gmsh.model.geo.addLine(2,3)
gmsh.model.geo.addLine(3,4)
gmsh.model.geo.addLine(4,5)
gmsh.model.geo.addLine(5,6)
gmsh.model.geo.addLine(6,7)
gmsh.model.geo.addLine(7,1)
gmsh.model.geo.addCurveLoop([1,2,3,4,5,6,7])
field_tag = gmsh.model.mesh.field.add("MathEval")
# middle of the profile, mesh should be more fine
x_feiner = 100
z_feiner = 47
lc=gmsh.model.mesh.field.setString(field_tag, "F", f"0.3 + 0.03 * sqrt((x - {x_feiner})^2 + (z - {z_feiner})^2)")
# activate field
gmsh.model.mesh.field.setAsBackgroundMesh(field_tag)
gmsh.model.geo.synchronize()
gmsh.model.geo.addPlaneSurface([1])
gmsh.model.addPhysicalGroup(2, [1], tag=1)
gmsh.model.setPhysicalName(2, 1, "front")
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.Algorithm", 5) # or 5/7/11
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.model.mesh.generate(2)
gmsh.model.mesh.recombine()
# Extrude the 2D mesh to create a 3D mesh
vol = gmsh.model.geo.extrude([(2, 1)], 0, breite, 0, #2,1 -> dim, tag und dim=2 weil 0=punkt, 1= linie ...
[1], recombine=True)
gmsh.model.addPhysicalGroup(2, [19], tag=2)
gmsh.model.setPhysicalName(2, 2, "bottom_left")
gmsh.model.addPhysicalGroup(2, [31], tag=3)
gmsh.model.setPhysicalName(2, 3, "bottom_right")
gmsh.model.addPhysicalGroup(2, [35], tag=4)
gmsh.model.setPhysicalName(2, 4, "right_side")
gmsh.model.addPhysicalGroup(2, [39], tag=6)
gmsh.model.setPhysicalName(2, 6, "top")
gmsh.model.addPhysicalGroup(2, [43], tag=5)
gmsh.model.setPhysicalName(2, 5, "left_side")
gmsh.model.addPhysicalGroup(2, [44], tag=7)
gmsh.model.setPhysicalName(2, 7, "backside")
gmsh.model.addPhysicalGroup(3, [1], tag=8)
gmsh.model.setPhysicalName(3, 8, "domain")
# Generate the 3D mesh
gmsh.model.mesh.generate(3)
gmsh.write("mesh_linearelastFINALRadial.msh")
gmsh.fltk.run()
gmsh.finalize()
from dolfinx import log, default_scalar_type,fem,io
from dolfinx import fem, mesh, plot
from numpy import random
import pyvista
from dolfinx.io import gmshio
#Mesh von Gmsh reinladen
domain, cell_tags, facet_tags = gmshio.read_from_msh("mesh_linearelastFINALRadial.msh", MPI.COMM_WORLD)
#Functionspaces
ndegree=1
FS= fem.functionspace(domain, ("CG", ndegree, (domain.geometry.dim, )))
FSPF=fem.functionspace(domain, ("CG", ndegree))
#Phasefield "phi"
phi = fem.Function(FSPF)
phi.x.array[:]= 0
#Boundary Conditions
disp= fem.Constant(domain, PETSc.ScalarType(0.0))
zero=np.zeros(domain.geometry.dim, dtype=default_scalar_type)
zero_scalar=PETSc.ScalarType(0.0)
dofs_bottom_left = fem.locate_dofs_topological(FS.sub(2), domain.topology.dim - 1, facet_tags.find(2))
dofs_bottom_right = fem.locate_dofs_topological(FS.sub(2), domain.topology.dim - 1, facet_tags.find(3))
dofsleft = fem.locate_dofs_topological(FS.sub(0), domain.topology.dim-1, facet_tags.find(5))
dofsright = fem.locate_dofs_topological(FS.sub(0), domain.topology.dim-1, facet_tags.find(4))
dofsfront = fem.locate_dofs_topological(FS.sub(1), domain.topology.dim-1, facet_tags.find(1))
bc_bottom_l = fem.dirichletbc(zero_scalar, dofs_bottom_left, FS.sub(2))
bc_bottom_r = fem.dirichletbc(zero_scalar, dofs_bottom_right, FS.sub(2))
bc_right = fem.dirichletbc(disp, dofsright, FS.sub(0))
bc_front = fem.dirichletbc(zero_scalar, dofsfront, FS.sub(1))
bc_left = fem.dirichletbc(zero_scalar, dofsleft, FS.sub(0))
BC= [bc_bottom_l, bc_bottom_r, bc_right, bc_front, bc_left ]
#Constants
E = 210000
nu = 0.2
mu = E / (2 * (1 + nu))
lambda_ = E * nu / ((1 + nu) * (1 - 2 * nu))
# lambda_=110.5 # 4000
# mu=82
Gc=0.03
l=0.6
tol= 1e-4
diff= 1
phi_old = fem.Function(FSPF)
phi_old.x.array[:] = phi.x.array
#Testfunktionen und Verschiebung
u=ufl.TrialFunction(FS)
v=ufl.TestFunction(FS)
dphi = ufl.TrialFunction(FSPF) # TrialFunction für Phasefield
theta = ufl.TestFunction(FSPF)
#Funktionen und Konstanten
I= ufl.Identity(len(u))
f= fem.Constant(domain, default_scalar_type((0.0, 0.0,0))) #Bodyforce
T = fem.Constant(domain, default_scalar_type((0, 0, 0))) #Traction
H= fem.Function(FSPF)
#Integrationen
metadata = {"quadrature_degree": 2}
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tags, metadata=metadata) # to integrate over the surface
dx = ufl.Measure("dx", domain=domain, metadata=metadata) # to integrate over the domain
def sigma(u):
eps_reg= 1e-5
return (lambda_ * ufl.nabla_div(u)* I + mu*(ufl.grad(u)+ufl.grad(u).T))*((1-phi)**2+ eps_reg)
return 0.5*(ufl.grad(u)+ ufl.grad(u).T)
#L
L = ufl.inner(f,v)*dx+ufl.inner(T, v)*ds
#a(u,v)
a = ufl.inner(sigma(u), epsilon(v))*dx
dispmax= 1 # 20
delta= 0.01
loadfactors = np.arange(delta,1+delta,delta)
Traction_list =[]
Disp_List =[]
normal = ufl.FacetNormal(domain)
xdmf_phi = XDMFFile(MPI.COMM_WORLD, "phi_output2.xdmf", "w")
xdmf_phi.write_mesh(domain)
# xdmf_phi.write_function(phi, 0.0)
xdmf_uh = XDMFFile(MPI.COMM_WORLD, "uh_output2.xdmf", "w")
xdmf_uh.write_mesh(domain)
counter=0
for loadfactor in loadfactors:
diff=1.0
disp.value = loadfactor * dispmax
counter = counter + 1
print(f"Iteration:{counter}")
while diff > tol:
problem = LinearProblem(a, L, bcs=BC, petsc_options={"ksp_type": "cg","pc_type": "hypre","ksp_rtol": 1e-8})
uh = problem.solve()
psi_expression = fem.Expression(0.5*lambda_*(ufl.tr(epsilon(uh)))**2 + mu * (ufl.inner(epsilon(uh), epsilon(uh))),FSPF.element.interpolation_points())
psi= fem.Function(FSPF)
psi.interpolate(psi_expression)
with H.vector.localForm() as H_local, psi.vector.localForm() as psi_local:H_local.array[:] = np.maximum(H_local.array, psi_local.array)
#a fürs phasefield
a_pf= ufl.inner(ufl.grad(theta), Gc * l * ufl.grad(dphi)) * dx + (Gc / l + 2 * H) * theta * dphi * dx
#L fürs phasefield
L_pf=2*H*theta*dx
PFproblem = LinearProblem(a_pf, L_pf, petsc_options={"ksp_type": "cg", "pc_type": "hypre", "ksp_rtol": 1e-8})
phi = PFproblem.solve()
#Konvergenz?
diff = np.linalg.norm(phi.x.array - phi_old.x.array)
print(f"diff = {diff:.4e}")
Disp_List.append(loadfactor * dispmax)
#Reaktionskraft zwischenspeichern
storedtraction = fem.assemble_scalar(fem.form(ufl.inner(ufl.as_vector([1.0, 0.0, 0.0]), ufl.dot(sigma(uh),normal))*ds(4))) #top surface traction
Traction_list.append(storedtraction)
xdmf_phi.write_function(phi, loadfactor)
xdmf_uh.write_function(uh, loadfactor)
xdmf_phi.close()
xdmf_uh.close()
#pdf für Kraft-Verschiebung
plt.plot(Disp_List, Traction_list, '-')
plt.xlabel("Displacement")
plt.ylabel("Force")
plt.legend(["Kraft-Verschiebungs Kurve"])
plt.grid(True)
please note that i changed my code from
L_pf=2*H*theta*dx + ufl.inner(ufl.grad(phi), ufl.FacetNormal(domain))*theta*ds
to
L_pf=2*H*theta*dx
otherwise phi did not convergate for a small Gc
