Hello everyone,
I have written a beam simulation code using DOLFINx, but I am not sure if the algorithm for calculating charge density from charge deposition is correct. I would appreciate any advice or suggestions. The code is attached below.
def deposit_charge_dg0_parallel(particles, V_rho):
自洽电荷沉积 (P -> rho) - 采用与对称脚本一致的 DG0 空间
确保非结构网格单元中心的电荷质心绝对对称
mesh = V_rho.mesh
rho = fem.Function(V_rho)
rho.x.array[:] = 0.0
if len(particles) > 0:
points = np.array([p.x for p in particles], dtype=np.float64)
bb_tree = geometry.bb_tree(mesh, mesh.topology.dim)
# 批量确定点所属单元
cell_candidates = geometry.compute_collisions_points(bb_tree, points)
colliding_cells = geometry.compute_colliding_cells(mesh, cell_candidates, points)
dofmap = V_rho.dofmap
for i, p in enumerate(particles):
cells = colliding_cells.links(i)
if len(cells) > 0:
p.cell_id = cells[0] # 缓存单元 ID
local_dofs = dofmap.cell_dofs(p.cell_id)
dof = local_dofs[0]
rho.x.array[dof] += p.q
p.cell_id = -1
# MPI 并行求和汇总
rho.x.scatter_reverse(la.InsertMode.add)
# 转换为密度 rho = Q/V
vol_func = fem.Function(V_rho)
vol_expr = fem.Expression(ufl.CellVolume(mesh), V_rho.element.interpolation_points())
vol_func.interpolate(vol_expr)
vol_array = vol_func.x.array
rho_array = rho.x.array
mask = vol_array > 1e-30
rho_array[mask] /= vol_array[mask]
rho_array[~mask] = 0.0
rho.x.scatter_forward()
return rho
