Poisson solver with big field error
Hello everyone,
I have a numerical model consisting of a grounded metallic outer shell enclosing a uniformly charged spherical particle distribution to solve the internal electric field. The simulated electric field results are compared with the analytical solutions. At present, the maximum deviation between numerical and theoretical results is approximately 5%. This noticeable error is likely introduced by the charge deposition scheme, although the exact source cannot be fully confirmed. I would appreciate suggestions on feasible approaches to reduce this numerical error. The relevant code and simulation results are attached for reference. Thank you very much.
track_inject_iter.py:
import numba
from dolfinx import fem, geometry
import dolfinx.la as la
@numba.njit(parallel=True, fastmath=True)
def numba_deposit_kernel(
    alive_x,
    alive_q,
    cell_ids,
    invT_arr,
    origin_arr,
    cell_dofs_arr,
    num_dofs
    n_particles = alive_x.shape[0]
    n_threads = numba.get_num_threads()
    # 1. Thread-isolated buffer to avoid race conditions without locks
    thread_buf = np.zeros((n_threads, num_dofs), dtype=np.float64)
    thread_outside_counts = np.zeros(n_threads, dtype=np.int64)
    chunk_size = (n_particles + n_threads - 1) // n_threads
    for tid in numba.prange(n_threads):
        start_idx = tid * chunk_size
        end_idx = min(start_idx + chunk_size, n_particles)
        buf = thread_buf[tid]
        outside_cnt = 0
        for i in range(start_idx, end_idx):
            cell = cell_ids[i]
            if cell < 0:
                outside_cnt += 1
                continue
            invT = invT_arr[cell]
            orig = origin_arr[cell]
            dx = alive_x[i, 0] - orig[0]
            dy = alive_x[i, 1] - orig[1]
            dz = alive_x[i, 2] - orig[2]
            # Strict calculation of tetrahedral barycentric coordinates
            l0 = invT[0, 0]*dx + invT[0, 1]*dy + invT[0, 2]*dz
            l1 = invT[1, 0]*dx + invT[1, 1]*dy + invT[1, 2]*dz
            l2 = invT[2, 0]*dx + invT[2, 1]*dy + invT[2, 2]*dz
            l3 = 1.0 - (l0 + l1 + l2)
            # Tolerance judgment: allow tiny floating-point out-of-bounds to avoid falsely removing particles near cell boundaries
            eps = 1e-9
            if l0 < -eps or l1 < -eps or l2 < -eps or l3 < -eps:
                outside_cnt += 1
                continue  # Only discard particles far outside the mesh
            # 1. Truncate minor negative values to eliminate negative charge contamination
            l0 = l0 if l0 > 0.0 else 0.0
            l1 = l1 if l1 > 0.0 else 0.0
            l2 = l2 if l2 > 0.0 else 0.0
            l3 = l3 if l3 > 0.0 else 0.0
            # 2. Local shape function renormalization: ensure full charge conservation across the 4 tetrahedron nodes
            l_sum = l0 + l1 + l2 + l3
            if l_sum > 0.0:
                inv_sum = 1.0 / l_sum
                l0 *= inv_sum
                l1 *= inv_sum
                l2 *= inv_sum
                l3 *= inv_sum
            q = alive_q[i]
            dofs = cell_dofs_arr[cell]
            # 3. Thread-safe accumulation into local thread buffer
            buf[dofs[0]] += q * l0
            buf[dofs[1]] += q * l1
            buf[dofs[2]] += q * l2
            buf[dofs[3]] += q * l3
        thread_outside_counts[tid] = outside_cnt
    # 2. Cross-thread reduction to sum contributions over all threads
    result = np.zeros(num_dofs, dtype=np.float64)
    for d in numba.prange(num_dofs):
        s = 0.0
        for t in range(n_threads):
            s += thread_buf[t, d]
        result[d] = s
    # 3. Sum total count of particles out of mesh bounds
    total_outside = 0
        total_outside += thread_outside_counts[t]
    return result, total_outside
def numba_deposit_core_adapter(ps, alive_idx, cell_ids_alive, geo_cache, num_dofs):
    """Wrapper interface for argument conversion"""
    return numba_deposit_kernel(
       ps.x[alive_idx],
       ps.q[alive_idx],
        cell_ids_alive,
       geo_cache.invT_arr,
       geo_cache.origin_arr,
       geo_cache.cell_dofs_arr,
        num_dofs
def deposit_charge(ps, V_rho, geo_cache):
    Charge deposition kernel with strict dual-dimensional charge conservation (external entry point for Dolfinx)
    domain = V_rho.mesh
    rho = fem.Function(V_rho)
    rho.x.array[:] = 0.0
    alive_mask = ps.alive
    alive_idx = np.where(alive_mask)[0]
    if len(alive_idx) == 0:
        return rho
    # 1. Batch collision detection to locate particle-cell intersections via geometry tree
    points = ps.x[alive_idx]
    candidates = geometry.compute_collisions_points(geo_cache.bb_tree, points)
    colliding = geometry.compute_colliding_cells(domain, candidates, points)
    # Update cell ID index for each living particle
    cell_ids_alive = np.full(len(alive_idx), -1, dtype=np.int32)
    for local_i, pidx in enumerate(alive_idx):
        links = colliding.links(local_i)
        if len(links) == 0:
            ps.alive[pidx] = False  # Mark particles outside local mesh as dead
            continue
        cell = links[0]
        ps.cell_id[pidx] = cell
        cell_ids_alive[local_i] = cell
    # 2. Calculate total DoF count including local DoFs and cross-process ghost DoFs
    num_dofs = V_rho.dofmap.index_map.size_local + V_rho.dofmap.index_map.num_ghosts
    # 3. Execute high-performance Numba charge deposition core
    Q_arr, total_outside = numba_deposit_core_adapter(ps, alive_idx, cell_ids_alive, geo_cache, num_dofs)
    # 4. Populate Dolfinx vector with charge array and perform bidirectional cross-process reduction
    Q = fem.Function(V_rho)
    Q.x.array[:len(Q_arr)] = Q_arr[:len(Q.x.array)]
    # Critical synchronization step: reverse scatter ghost contributions back to owning ranks first, then forward sync for global consistency
    Q.x.scatter_reverse(la.InsertMode.add)
    Q.x.scatter_forward()
    # 5. Compute nodal control volumes via mass lumping (convert total nodal charge Q to charge density rho)
    vtest = ufl.TestFunction(V_rho)
    lump_form = fem.form(vtest * ufl.dx)
    lump = fem.Function(V_rho)
    fem.petsc.assemble_vector(lump.x.petsc_vec, lump_form)
    lump.x.scatter_reverse(la.InsertMode.add)
    lump.x.scatter_forward()
    # 6. Compute charge density rho = Q / control_volume
    vol = lump.x.array
    mask = vol > 1e-30
    rho.x.array[mask] = Q.x.array[mask] / vol[mask]
    # Final forward synchronization to ensure consistent source term for Poisson solver
    rho.x.scatter_forward()
    return rho
electric_field.py:
import dolfinx.fem as fem
import dolfinx.geometry as geometry
from datetime import datetime
# ====================== 你的高性能模块 ======================
# 请确保这些函数已在 track_fast.py 中定义
from track_inject_iter import ParticleSystemSoA, deposit_charge, MeshGeometryCache
EPS0 = 8.8541878128e-12
def create_spherical_mesh(comm, R_wall=0.020, cell_size=0.00025):
    """生成球体网格"""
    if comm.rank != 0:
        gmsh.option.setNumber("General.Terminal", 0)
    model = gmsh.model
    model.add("sphere_cavity")
    sphere = model.occ.addSphere(0.0, 0.0, 0.0, R_wall)
    model.occ.synchronize()
    model.mesh.setSize(model.getEntities(0), cell_size)
    volumes = [e[1] for e in model.getEntities(3)]
    model.addPhysicalGroup(3, volumes, tag=1, name="volume")
    surfaces = [e[1] for e in model.getEntities(2)]
    model.addPhysicalGroup(2, surfaces, tag=100, name="metal_wall")
    model.mesh.generate(3)
    gmsh.write("spherical_cavity.msh")
    from dolfinx.io import gmshio
    domain, cell_tags, facet_tags = gmshio.model_to_mesh(model, comm, rank=0, gdim=3)
    gmsh.finalize()
    return domain, facet_tags
class FastPoissonSolver:
    def __init__(self, domain, facet_tags, wall_tag=100):
        self.domain = domain
        self.facet_tags = facet_tags
        # PIC推荐配置
        self.V_rho = fem.functionspace(
            domain,
            ("Lagrange", 1)
        self.V_phi = fem.functionspace(
            domain,
            ("Lagrange", 2)
        self.W = fem.functionspace(
            domain,
            ("DG", 1, (3,))
        # Poisson
        u = ufl.TrialFunction(self.V_phi)
        v = ufl.TestFunction(self.V_phi)
        self.a_form = fem.form(
            ufl.inner(
                ufl.grad(u),
                ufl.grad(v)
            ) * ufl.dx
        self.rho_func = fem.Function(self.V_rho)
        self.L_form = fem.form(
            (1.0 / EPS0)
            * self.rho_func
            * v
            * ufl.dx
        self.phi = fem.Function(self.V_phi)
        # E = -grad(phi)
        # L2 projection
        E_trial = ufl.TrialFunction(self.W)
        E_test = ufl.TestFunction(self.W)
        self.aE = fem.form(
            ufl.inner(E_trial, E_test)
            * ufl.dx
        self.LE = fem.form(
            ufl.inner(
                -ufl.grad(self.phi),
                E_test
            * ufl.dx
        self.E_field = fem.Function(self.W)
        # 边界条件
        facets = facet_tags.indices[
            facet_tags.values == wall_tag
        self.dofs_wall = fem.locate_dofs_topological(
            self.V_phi,
            domain.topology.dim - 1,
            facets
        # Poisson Solver
        self.ksp = PETSc.KSP().create(domain.comm)
        self.ksp.setType("cg")
        pc = self.ksp.getPC()
        pc.setType("hypre")
        pc.setHYPREType("boomeramg")
        self.ksp.setInitialGuessNonzero(True)
        self.ksp.setTolerances(
            rtol=1e-8,
            atol=1e-12
        # E Projection Solver
        self.kspE = PETSc.KSP().create(domain.comm)
        self.kspE.setType("cg")
        pcE = self.kspE.getPC()
        pcE.setType("jacobi")
    def solve(self, v_wall=0.0):
        # Dirichlet BC
        bc = fem.dirichletbc(
            PETSc.ScalarType(v_wall),
            self.dofs_wall,
            self.V_phi
        bcs = [bc]
        # Assemble Poisson
        A = fem.petsc.create_matrix(
            self.a_form
        fem.petsc.assemble_matrix(
            A,
            self.a_form,
            bcs=bcs
        self.ksp.setOperators(A)
        b = fem.petsc.create_vector(
            self.L_form
            b,
            self.L_form
        fem.petsc.apply_lifting(
            b,
            [self.a_form],
            [bcs]
        b.ghostUpdate(
            addv=PETSc.InsertMode.ADD,
            mode=PETSc.ScatterMode.REVERSE
        fem.petsc.set_bc(
            b,
            bcs
        # Solve phi
        self.ksp.solve(
            b,
            self.phi.x.petsc_vec
        self.phi.x.scatter_forward()
        # L2 Projection of E
        AE = fem.petsc.create_matrix(
            self.aE
            AE,
            self.aE
        AE.assemble()
        bE = fem.petsc.create_vector(
            self.LE
            bE,
            self.LE
        bE.ghostUpdate(
        self.kspE.setOperators(AE)
        self.kspE.solve(
            bE,
            self.E_field.x.petsc_vec
        self.E_field.x.scatter_forward()
        A.destroy()
        b.destroy()
        AE.destroy()
        bE.destroy()
        return self.phi, self.E_field
    def destroy(self):
        self.ksp.destroy()
        self.kspE.destroy()
def verify_grounded_sphere_system():
    comm = MPI.COMM_WORLD
    rank = comm.rank
    R_wall = 0.010
    R_beam = 0.005
    Q_total = 1e-9
    num_particles = 60000
    # mesh
    domain, facet_tags = create_spherical_mesh(
        comm,
        R_wall,
        cell_size=0.00025
    # particles
    ps = ParticleSystemSoA(num_particles)
    np.random.seed(42)
    if rank == 0:
        count = 0
        while count < num_particles:
            xyz = np.random.uniform(-R_beam, R_beam, 3)
            if np.linalg.norm(xyz) <= R_beam:
                ps.x[count] = xyz
                ps.q[count] = Q_total / num_particles
                ps.alive[count] = True
                count += 1
    comm.Bcast(ps.x, root=0)
    comm.Bcast(ps.q, root=0)
    comm.Bcast(ps.alive, root=0)
    # solver + cache
    poisson = FastPoissonSolver(domain, facet_tags, wall_tag=100)
    geo_cache = MeshGeometryCache(
        domain,
        poisson.V_rho
    # 1. particle charge check
    alive_idx = np.where(ps.alive)[0]
    particle_Q = np.sum(ps.q[alive_idx])
    if rank == 0:
        print("particle_Q =", particle_Q)
        print("target_Q   =", Q_total)
    # 2. deposit
    rho = deposit_charge(ps, poisson.V_rho, geo_cache)
    alive_after = np.sum(ps.alive)
    charge_after = np.sum(ps.q[ps.alive])
    if rank == 0:
        print("alive_after =", alive_after)
        print("charge_after =", charge_after)
    poisson.rho_func.x.array[:] = rho.x.array
    poisson.rho_func.x.scatter_forward()
    # 3. FEM integrated charge
    Q_form = fem.form(rho * ufl.dx)
    Q_local = fem.assemble_scalar(Q_form)
    Q_num = comm.allreduce(Q_local, op=MPI.SUM)
    if rank == 0:
        print(f"FEM ∫rho dx = {Q_num:.6e}")
    # 4. MASS LUMPED CHECK (关键守恒标准)
    v = ufl.TestFunction(poisson.V_rho)
    lump_form = fem.form(v * ufl.dx)
    lump = fem.Function(poisson.V_rho)
    Q_lumped = np.sum(rho.x.array * lump.x.array)
    if rank == 0:
        print(f"Lumped Q     = {Q_lumped:.6e}")
    # 5. solve
    phi, E_field = poisson.solve(v_wall=0.0)
    # 6. field validation
    if rank == 0:
        print("\n====== 球体场验证 ======")
        print(f"{'r(mm)':<12}{'E_num':<18}{'E_exact':<18}{'err%':<10}")
        print("-" * 60)
        test_idx = np.random.choice(alive_idx, 8, replace=False)
        for idx in test_idx:
            p = ps.x[idx]
            r = np.linalg.norm(p)
            if r <= R_beam:
                E_exact = (
                    Q_total /
                    (4 * np.pi * EPS0 * R_beam**3)
                ) * r
                E_exact = (
                    Q_total /
                    (4 * np.pi * EPS0 * r**2)
            points = np.array([p], dtype=np.float64)
            cell_cand = geometry.compute_collisions_points(
                geo_cache.bb_tree,
                points
                domain,
                cell_cand,
                points
            if len(colliding.links(0)) > 0:
                E_num_vec = E_field.eval(
                    p,
                    [colliding.links(0)[0]]
                E_num = np.linalg.norm(E_num_vec)
                err = abs(E_num - E_exact) / E_exact * 100
                print(f"{r*1000:<12.3f}{E_num:<18.4f}{E_exact:<18.4f}{err:<10.3f}")
    poisson.destroy()
if __name__ == "__main__":
The simulation results are:
particle_Q = 1.0000000000000005e-09
target_Q = 1e-09
alive_after = 60000
charge_after = 1.0000000000000005e-09
FEM ∫rho dx = 9.759833e-10
Lumped Q = 9.759833e-10
====== Spherical Field Validation ======
r(mm) E_num E_exact err%
4.519 319018.8044 324914.4684 1.815
4.595 324181.0148 330373.3166 1.874
4.819 337208.7909 346496.2446 2.680
4.819 331767.5544 346494.7841 4.250
3.677 264973.1326 264347.6137 0.237
3.394 245362.6843 244064.4941 0.532
4.023 282003.2988 289252.0044 2.506
3.324 232931.4091 239022.3070 2.548
