Clamped circular plate bending solution error
I am very new to FEniCS and I am currently trying to solve the deflection of a clamped circular plate of radius a under uniform load q . The governing equation is ∇^4u=f , in which f=q/D is constant in my case. I have just adapted the biharmonic demo code from FEniCS website, changing only the mesh type and the forcing function f definition. The code runs perfectly, but the results do not match the analytical solution w=q(a^2−(x^2+y^2))/64D. What am I doing wrong? Also, sorry for the bad formatting of this question, its my first post here.
import math
# A mesh is created, and a quadratic finite element function space::
# Make mesh ghosted for evaluation of DG terms
parameters["ghost_mode"] = "shared_facet"
raio = 10e-3  # Radius
q = 9e6       # Uniform pressure
E = 6.9e10    # Young Modulus
h = 2e-3      # Thickness
v = 0.33      # Poisson ratio
D = E*math.pow(h,3.0) / (12*(1-math.pow(v,2.0)))
domain = Circle(Point(0, 0), raio)
mesh = generate_mesh(domain, 64)
V = FunctionSpace(mesh, "CG", 2)
# Define Dirichlet boundary
class DirichletBoundary(SubDomain):
        return on_boundary
# The Dirichlet boundary condition is created::
# Define boundary condition
u0 = Constant(0.0)
bc = DirichletBC(V, u0, DirichletBoundary())
# Define normal component, mesh size and right-hand side
h = CellDiameter(mesh)
h_avg = (h('+') + h('-'))/2.0
f = Constant(q/D)
analitico = Expression("q*pow(pow(a,2)-pow(x[0],2)-pow(x[1],2),2)/(64*D)",q=q,a=raio,D=D,degree=3)
# Penalty parameter
alpha = Constant(8.0)
# The bilinear and linear forms are defined::
# Define bilinear form
a = inner(div(grad(u)), div(grad(v)))*dx \
  - inner(avg(div(grad(u))), jump(grad(v), n))*dS \
  - inner(jump(grad(u), n), avg(div(grad(v))))*dS \
  + alpha/h_avg*inner(jump(grad(u),n), jump(grad(v),n))*dS
# Define linear form
L = f*v*dx
# Solve variational problem
solve(a == L, u, bc)
# Error
error_L2 = errornorm(analitico, u, 'L2')
print('error_L2 =', error_L2)
Please properly format your code using 3x` Encapsulation
Running your code, I get the output
error_L2 = 5.465542724341058e-07
which is a very good match, considering that you are approximating a fourth order polynomial with a set of second order polynomials.
I am not sure what error you expect to get?
