Compute a boundary flux after solving the PDE
I’m currently trying to compute a boundary flux from the solution of an already solved PDE (Poisson equation) and I’m failing miserably. What works so far is
uh = problem.solve()
ds = Measure('ds', domain = mesh, subdomain_data=dofsRight)
flux = inner(grad(uh), n)*ds
On the other hand, I am failing at really getting the value of the flux. I have tried with
assemble_scalar (form(flux)) as well as assemble_scalar (form(flux)) (see the error logs below).
I’ve found a few examples which seem to use the command assemble, but it is I believe outdated… Since this is a simple problem, I would imagine I only fail to understand something simple but I can’t figure out what… If someone has an idea, I’ll be very grateful!
Thanks a lot!
form(flux) returns
File "/usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/forms.py", line 48, in __init__
    super().__init__(ffi.cast("uintptr_t", ffi.addressof(self._ufcx_form)),
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
    1. dolfinx.cpp.fem.Form_float64(spaces: List[dolfinx::fem::FunctionSpace], integrals: Dict[dolfinx::fem::IntegralType, Tuple[List[Tuple[int, object]], dolfinx.cpp.mesh.MeshTags_int32]], coefficients: List[dolfinx.cpp.fem.Function_float64], constants: List[dolfinx.cpp.fem.Constant_float64], need_permutation_data: bool, mesh: dolfinx.cpp.mesh.Mesh = None)
    2. dolfinx.cpp.fem.Form_float64(arg0: int, arg1: List[dolfinx::fem::FunctionSpace], arg2: List[dolfinx.cpp.fem.Function_float64], arg3: List[dolfinx.cpp.fem.Constant_float64], arg4: Dict[dolfinx::fem::IntegralType, dolfinx.cpp.mesh.MeshTags_int32], arg5: dolfinx.cpp.mesh.Mesh)
Invoked with: <cdata 'uintptr_t' 139961674859552>, [], [<dolfinx.cpp.fem.Function_float64 object at 0x7f4b64ac8fb0>], [], {<IntegralType.cell: 0>: None, <IntegralType.exterior_facet: 1>: array([    1,     2,     5,     9,    14,    20,    27,    35,    44,
          54,    65,    77,    90,   104,   119,   135,   152,   170,
         189,   209,   230,   252,   275,   299,   324,   350,   377,
         405,   434,   464,   495,   527,   560,   594,   629,   665,
         702,   740,   779,   819,   860,   902,   945,   989,  1034,
        1080,  1127,  1175,  1224,  1274,  1325,  1377,  1430,  1484,
        1539,  1595,  1652,  1710,  1769,  1829,  1890,  1952,  2015,
        2079,  2144,  2210,  2277,  2345,  2414,  2484,  2555,  2627,
        2700,  2774,  2849,  2925,  3002,  3080,  3159,  3239,  3320,
        3402,  3485,  3569,  3654,  3740,  3827,  3915,  4004,  4094,
        4185,  4277,  4370,  4464,  4559,  4655,  4752,  4850,  4949,
        5049,  5150,  5252,  5355,  5459,  5564,  5670,  5777,  5885,
        5994,  6104,  6215,  6327,  6440,  6554,  6669,  6785,  6902,
        7020,  7139,  7259,  7380,  7502,  7625,  7749,  7874,  8000,
        8127,  8255,  8384,  8514,  8645,  8777,  8910,  9044,  9179,
        9315,  9452,  9590,  9729,  9869, 10010, 10152, 10295, 10439,
       10584, 10730, 10877, 11025, 11174, 11324, 11475, 11627, 11780,
       11934, 12089, 12245, 12402, 12560, 12719, 12879, 13040, 13202,
       13365, 13529, 13694, 13860, 14027, 14195, 14364, 14534, 14705,
       14877, 15050, 15224, 15399, 15575, 15752, 15930, 16109, 16289,
       16470, 16652, 16835, 17019, 17204, 17390, 17577, 17765, 17954,
       18144, 18335, 18527, 18720, 18914, 19109, 19305, 19502, 19700,
       19899, 20099, 20300, 20502, 20705, 20909, 21114, 21320, 21527,
       21735, 21944, 22154, 22365, 22577, 22790, 23004, 23219, 23435,
       23652, 23870, 24089, 24309, 24530, 24752, 24975, 25199, 25424,
       25650, 25877, 26105, 26334, 26564, 26795, 27027, 27260, 27494,
       27729, 27965, 28202, 28440, 28679, 28919, 29160, 29402, 29645,
       29889, 30134, 30380, 30627, 30875, 31124, 31374, 31625, 31877,
       32130, 32384, 32639, 32895, 33152, 33410, 33669, 33929, 34190,
       34452, 34715, 34979, 35244, 35510, 35777, 36045, 36314, 36584,
       36855, 37127, 37400, 37674, 37949, 38225, 38502, 38780, 39059,
       39339, 39620, 39902, 40185, 40469, 40754, 41040, 41327, 41615,
       41904, 42194, 42485, 42777, 43070, 43364, 43659, 43955, 44252,
       44550, 44849, 45149, 45450, 45752, 46055, 46359, 46664, 46970,
       47277, 47585, 47894, 48204, 48515, 48827, 49140, 49454, 49769,
       50085, 50402, 50720, 51039, 51359, 51680, 52002, 52325, 52649,
       52974, 53300, 53627, 53955, 54284, 54614, 54945, 55277, 55610,
       55944, 56279, 56615, 56952, 57290, 57629, 57969, 58310, 58652,
       58995, 59339, 59684, 60030, 60377, 60725, 61074, 61424, 61775,
       62127, 62480, 62834, 63189, 63545, 63902, 64260, 64619, 64979,
       65340, 65702, 66065, 66429, 66794, 67160, 67527, 67895, 68264,
       68634, 69005, 69377, 69750, 70124, 70499, 70875, 71252, 71630,
       72009, 72389, 72770, 73152, 73535, 73919, 74304, 74690, 75077,
       75465, 75854, 76244, 76635, 77027, 77420, 77814, 78209, 78605,
       79002, 79400, 79799, 80199, 80600], dtype=int32), <IntegralType.interior_facet: 2>: None, <IntegralType.vertex: 3>: None}, <dolfinx.mesh.Mesh object at 0x7f4b6d577040>
and assemble_scalar(flux) returns
File "/usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/assemble.py", line 128, in assemble_scalar
    constants = constants or _pack_constants(M)
TypeError: pack_constants(): incompatible function arguments. The following argument types are supported:
    1. (arg0: dolfinx::fem::Form<double>) -> numpy.ndarray[numpy.float64]
    2. (arg0: dolfinx::fem::Expression<double>) -> numpy.ndarray[numpy.float64]
    3. (arg0: dolfinx::fem::Form<float>) -> numpy.ndarray[numpy.float32]
    4. (arg0: dolfinx::fem::Expression<float>) -> numpy.ndarray[numpy.float32]
    5. (arg0: dolfinx::fem::Form<std::complex<double> >) -> numpy.ndarray[numpy.complex128]
    6. (arg0: dolfinx::fem::Expression<std::complex<double> >) -> numpy.ndarray[numpy.complex128]
Invoked with: Form([Integral(Conj(Inner(FacetNormal(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0)), Grad(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 0)))), 'exterior_facet', Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), 'everywhere', {}, array([    1,     2,     5,     9,    14,    20,    27,    35,    44,
       79002, 79400, 79799, 80199, 80600], dtype=int32))])
See Read before posting: How do I get my question answered?
As stated in the link @francesco-ballarin posted, please use the search functionality for the forum before creating a post. This exact problem was solved in this post.
Cheers
Thank you for your replies. I finally found the solution which was how I defined the boundary. I should have used meshtags as in How to compute flux at particular boundary facets?.
I do not need so far to compute the flux at every point of the boundary, only its integral, so I do not need the normal vector approximation. But thanks for pointing that out, it will certainly be useful someday.
