Hi.
I am solving the heat equation over a square plate with a tri-material distribution with different thermal conductivities. In the centre of the plate I have a circle, and I would like to calculate the heat flux into this circle. I have seen this topic Calculate flux from solution with Fenicsx - #19 by dokken and have tried unsuccesfully to interpolate grad(Th) into a DG0 space.
I am getting an error I have gotten before since switching from legacy fenics, and previously resolved by either restarting the computer or creating a new environment. This time, neither of those have worked. Here is the terminal output:
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really needed).
Info : Meshing 1D...
Info : [ 0%] Meshing curve 1 (Line)
Info : [ 20%] Meshing curve 2 (Line)
Info : [ 40%] Meshing curve 3 (Line)
Info : [ 60%] Meshing curve 4 (Line)
Info : [ 80%] Meshing curve 5 (Ellipse)
Info : Done meshing 1D (Wall 0.000599726s, CPU 0.00273s)
Info : Meshing 2D...
Info : [ 0%] Meshing surface 1 (Plane, Frontal-Delaunay)
Info : [ 50%] Meshing surface 2 (Plane, Frontal-Delaunay)
Info : Done meshing 2D (Wall 0.117702s, CPU 0.619779s)
Info : 3198 nodes 6477 elements
Info : Writing 'example_mesh.msh'...
Info : Done writing 'example_mesh.msh'
Info : Reading 'example_mesh.msh'...
Info : 12 entities
Info : 3060 nodes
Info : 5958 elements
Info : Done reading 'example_mesh.msh'
INFO:root:running build_ext
INFO:root:building 'libffcx_elements_fe1a0993602258ab98fb05640c655d4a385d47cf' extension
INFO:root:/home/matei/anaconda3/envs/fenicsx-v1/bin/x86_64-conda-linux-gnu-cc -Wno-unused-result -Wsign-compare -DNDEBUG -fwrapv -O2 -Wall -fPIC -O2 -isystem /home/matei/anaconda3/envs/fenicsx-v1/include -fPIC -O2 -isystem /home/matei/anaconda3/envs/fenicsx-v1/include -march -DNDEBUG -D_FORTIFY_SOURCE -fPIC -I/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/ffcx/codegeneration -I/home/matei/anaconda3/envs/fenicsx-v1/include/python3.10 -c libffcx_elements_fe1a0993602258ab98fb05640c655d4a385d47cf.c -o ./libffcx_elements_fe1a0993602258ab98fb05640c655d4a385d47cf.o -O2 -g0
x86_64-conda-linux-gnu-cc: error: unrecognized command-line option '-march'
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 185, in _compile
self.spawn(compiler_so + cc_args + [src, '-o', obj] + extra_postargs)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 1041, in spawn
spawn(cmd, dry_run=self.dry_run, **kwargs)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/spawn.py", line 70, in spawn
raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/home/matei/anaconda3/envs/fenicsx-v1/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/cffi/ffiplatform.py", line 48, in _build
dist.run_command('build_ext')
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/dist.py", line 989, in run_command
super().run_command(command)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 88, in run
_build_ext.run(self)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
self.build_extensions()
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 467, in build_extensions
self._build_extensions_serial()
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 493, in _build_extensions_serial
self.build_extension(ext)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 249, in build_extension
_build_ext.build_extension(self, ext)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 548, in build_extension
objects = self.compiler.compile(
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 600, in compile
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 187, in _compile
raise CompileError(msg)
distutils.errors.CompileError: command '/home/matei/anaconda3/envs/fenicsx-v1/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
File "/home/matei/PhD/GAOpt/src/solvers/mwe.py", line 70, in <module>
V = fem.VectorFunctionSpace(msh, ("DG", 0))
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/dolfinx/fem/function.py", line 609, in VectorFunctionSpace
return FunctionSpace(mesh, ufl_element)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/dolfinx/fem/function.py", line 487, in __init__
(self._ufcx_element, self._ufcx_dofmap), module, code = jit.ffcx_jit(
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/dolfinx/jit.py", line 56, in mpi_jit
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/dolfinx/jit.py", line 206, in ffcx_jit
r = ffcx.codegeneration.jit.compile_elements([ufl_object], options=p_ffcx, **p_jit)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 144, in compile_elements
impl = _compile_objects(decl, elements, names, module_name, p, cache_dir,
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 270, in _compile_objects
ffibuilder.compile(tmpdir=cache_dir, verbose=True, debug=cffi_debug)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/cffi/api.py", line 725, in compile
return recompile(self, module_name, source, tmpdir=tmpdir,
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/cffi/recompiler.py", line 1564, in recompile
outputfilename = ffiplatform.compile('.', ext,
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/cffi/ffiplatform.py", line 20, in compile
outputfilename = _build(tmpdir, ext, compiler_verbose, debug)
File "/home/matei/anaconda3/envs/fenicsx-v1/lib/python3.10/site-packages/cffi/ffiplatform.py", line 54, in _build
raise VerificationError('%s: %s' % (e.__class__.__name__, e))
cffi.VerificationError: CompileError: command '/home/matei/anaconda3/envs/fenicsx-v1/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
In this MWE, I have set the conductivity as uniform (1.0), as I still get the same error. I am using fenicsx 0.6.0 installed via conda-forge on Ubuntu. I am not sure if this error is because of my instillation or because of a mistake in the way I am trying to acquire the heat flux. Many thanks for any help.
from dolfinx import fem
from dolfinx.mesh import meshtags
from dolfinx.fem import (Function, FunctionSpace)
from dolfinx.io import gmshio
from ufl import (ds, dx, grad, inner, TrialFunction, TestFunction)
proc = MPI.COMM_WORLD.rank
r = 0.125 # Circle radius
cx, cy = 0.5, 0.5 # Circle center
element_size = 0.02 # Mesh element size
if proc == 0:
# Set the mesh element size
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", element_size)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", element_size)
square = gmsh.model.occ.addRectangle(0, 0, 0, 1, 1)
# Create circle within the rectangle
circle = gmsh.model.occ.addDisk(cx, cy, 0, r, r)
gmsh.model.occ.synchronize()
# Marking the physical groups (modify as per your needs)
circle_boundary = gmsh.model.getBoundary([(2, circle)])
gmsh.model.mesh.embed(1, [circle_boundary[0][1]], 2, square)
gmsh.model.addPhysicalGroup(2, [square], 1)
gmsh.model.addPhysicalGroup(1, [circle_boundary[0][1]], 2)
# gmsh.model.mesh.generate(1)
gmsh.model.mesh.generate(2)
gmsh.write("example_mesh.msh")
gmsh.finalize()
msh, cell_markers, facet_markers = gmshio.read_from_msh("example_mesh.msh", MPI.COMM_WORLD, gdim=2)
V = FunctionSpace(msh, ("CG", 1))
# locate DOFs associated w boundary
dofs_L = fem.locate_dofs_geometrical(V, lambda x: np.isclose(x[0], 0))
bc_L = fem.dirichletbc(value=ScalarType(293), dofs=dofs_L, V=V)
dofs_R = fem.locate_dofs_geometrical(V, lambda x: np.isclose(x[0], 1))
bc_R = fem.dirichletbc(value=ScalarType(393), dofs=dofs_R, V=V)
T, v = TrialFunction(V), TestFunction(V)
a = inner(1.0 * grad(T), grad(v)) * dx
L = fem.Constant(msh, ScalarType(0)) * v * dx + fem.Constant(msh, ScalarType(0)) * v * ds # No source term and zero-neumann
problem = fem.petsc.LinearProblem(a, L, bcs=[bc_L, bc_R],
petsc_options={"ksp_type": "preonly", # preonly / gmres
"pc_type": "lu"}) # lu / ilu
Th = problem.solve()
bnd_tag = 2 # boundary tag
arc_indices = facet_markers.indices[facet_markers.values == bnd_tag]
arc_tags = meshtags(msh, 1, arc_indices, bnd_tag)
dS = ufl.Measure("dS", domain=msh, subdomain_data=arc_tags)
# HEAT FLUX
n = ufl.FacetNormal(msh) # normal vector
qw = Function(V)
qw_expr = fem.Expression(1*grad(Th), V.element.interpolation_points())
qw.interpolate(qw_expr)
flux = ufl.dot(qw, n('+'))*dS # heat flux
flux_form = fem.form(flux) # fem form
flux_local = fem.assemble_scalar(flux_form) # assemble over cell
total_flux = msh.comm.allreduce(flux_local, op=MPI.SUM) # sum all procs
