In a plane strain linear elastic model to calculate the safty factor (SF) in underground mining, i need to implementate a conditional between a UFL and a number to evite obtain NAN results, but it seems like im doing something wrong.
The SF depends from te principal stress values and rock mass propierties, the code is:
#Malla
mesh = Mesh("fantasma1.xml")
#Inputs
E = Constant(46.9e3)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda =E*nu/(1+nu)/(1-2*nu)
x_max = 1669.4431
y_r=1078.926
#Functions
def eps(v):
return sym(grad(v))
def sigma(v):
return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v)
#Neumann BC
rigth_function = Expression(("-0.027*1.5*(y_r-x[1])", 0), degree=1,y_r=y_r) #Compression in rigth Boundary
tol=10e-10
rigth = AutoSubDomain(lambda x: near(x[0],x_max,tol))
boundaries.set_all(0)
rigth.mark(boundaries, 2)
ds = ds(subdomain_data=boundaries)
rho_g = 0.027
f = Constant((0, -rho_g))
V = VectorFunctionSpace(mesh, 'Lagrange', degree=2)
du = TrialFunction(V)
u_ = TestFunction(V)
#Dirichlet BC
def bottom(x, on_boundary):
return near(x[1], 0.,tol)
def left(x, on_boundary):
return near(x[0], 0.,tol)
def right(x, on_boundary):
return near(x[0], x_max,tol)
bc3 = DirichletBC(V.sub(0), Constant(0.), right)
bc2 = DirichletBC(V.sub(0), Constant(0.), left)
bc1 = DirichletBC(V.sub(1), Constant(0.), bottom)
bc=[bc1,bc2]
#Weak formulation
a = inner(sigma(du), eps(u_))*dx
l = inner(f, u_)*dx +inner(rigth_function, u_)*ds(2)
u = Function(V, name="Displacement")
solve(a == l, u, bc)
#Principal Stress
Vsig = TensorFunctionSpace(mesh, "DG",degree=1)
sig = Function(Vsig, name="Cauchy_Stress")
sig.assign(project(-sigma(u), Vsig));
sx = sig.sub(0)
sy = sig.sub(3)
txy = sig.sub(1)
def sigma1(sigma_x, sigma_y, tau_xy): # magnitude of first principal stress
return((sigma_x+sigma_y)/2 + sqrt(((sigma_x-sigma_y)/2)**2 + tau_xy**2))
def sigma3(sigma_x, sigma_y, tau_xy): # magnitude of first principal stress
return((sigma_x+sigma_y)/2 - sqrt(((sigma_x-sigma_y)/2)**2 + tau_xy**2));
S1 = sigma1(sx,sy,txy);
S3 = sigma3(sx,sy,txy)
Vp = TensorFunctionSpace(mesh, "DG",degree=1)
sp = Function(Vsig, name="Principal_Stress")
sp.assign(project(as_tensor(((S1,0.),(0.,S3))), Vp));
#FS
mb=5.157
s=0.02
a=0.502
Em=41.5
sci=65
RCU=296
s3m=sp.sub(3)
s1m=sp.sub(0)
def hb(s3m):
return(s3m+RCU*(mb*(s3m/RCU)+s)**a)
s1hb= hb(s3m)
a1=abs(s3m)
a2=abs(sci*s**a)
FS= conditional(gt(a1,a2),sci*s**a/s3m,s1hb/s1m)
Vs = TensorFunctionSpace(mesh,"DG",degree=1)
s = Function(Vs,name="FS")
s.assign(project(as_tensor(((FS,0.),(0.,0.))), Vs))
file_results = XDMFFile("fantasma1_Prueba3.xdmf")
file_results.write(u, 0.)
file_results.write(sig, 0.)
file_results.write(sp,0.)
file_results.write(s,0.)
I really hope you can help me
