My query is related to imposing constraints on assembly matrix which works in legacy-dolfin but, not the same in dolfinx. The MWE code below works for legacy-dolfin.
from scipy.sparse import csr_matrix
mesh=UnitSquareMesh(5,5)
Ve = VectorElement("CG", mesh.ufl_cell(), 1,dim=3)
Re = VectorElement("R", mesh.ufl_cell(), 0,dim=4)
W = FunctionSpace(mesh, MixedElement([Ve, Re]))
V = FunctionSpace(mesh, Ve)
v_,lamb_ = TestFunctions(W)
dv, dlamb = TrialFunctions(W)
dx = Measure('dx')(domain=mesh)
C=as_tensor([[ 7.56043956e+08, 2.26813187e+08, 0.00000000e+00, 9.31322575e-10, 9.31322575e-10, 0.00000000e+00],
[ 2.26813187e+08, 7.56043956e+08, 0.00000000e+00, 9.31322575e-10, 9.31322575e-10, 0.00000000e+00],
[ 0.00000000e+00, 0.00000000e+00, 2.64600000e+08, 0.00000000e+00, 0.00000000e+00, 0.00000000e+00],
[-1.39698386e-09, -1.39698386e-09, 0.00000000e+00, 2.52014652e+06, 7.56043956e+05, 0.00000000e+00],
[-1.39698386e-09, -1.39698386e-09, 0.00000000e+00, 7.56043956e+05, 2.52014652e+06, 0.00000000e+00],
[ 0.00000000e+00, 0.00000000e+00, 0.00000000e+00, 0.00000000e+00, 0.00000000e+00, 8.82000000e+05]])
def eps(v):
return as_vector([0,v[1].dx(0),v[2].dx(1),v[1].dx(1)+v[2].dx(0),v[0].dx(1),v[0].dx(0)])
F2=dot(dot(C,eps(dv)),eps(v_))*dx
c1=lamb_[0]*dv[0]+lamb_[1]*dv[1]+lamb_[2]*dv[2]
c2=dlamb[0]*v_[0]+dlamb[1]*v_[1]+dlamb[2]*v_[2]
c3=lamb_[3]*(dv[1].dx(1)-dv[2].dx(0))+dlamb[3]*(v_[1].dx(1)-v_[2].dx(0))
a2=F2+(c1+c2+c3)*dx
A2=assemble(a2)
ai, aj, av= as_backend_type(A2).mat().getValuesCSR()
A_csr=csr_matrix((av, aj, ai))
A=A_csr.toarray()
print(A.shape)
print('Matrix rank after using constraints',np.linalg.matrix_rank(A))
# Without constraints
A2=assemble(F2)
A=A_csr.toarray()
print('Matrix rank without constraints',np.linalg.matrix_rank(A))
However, for implementing the constraints in dolfinx, I tried with the null constraints to restrict the rigid body motions. But, that doesn’t make affect. The below MWE in dolfinx does the same but, there is no affect in rank of amtrix. This shows the constraints are not implemented in coefficient matrix A_l. Kindly help me to resolve this issue.
import basix
from dolfinx.fem import form, petsc, Function, functionspace
from ufl import TrialFunction, TestFunction, inner, lhs, rhs, dx, dot, eq, grad
from dolfinx import fem
import petsc4py.PETSc
from contextlib import ExitStack
mesh_l=dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 5,5, dolfinx.mesh.CellType.triangle)
V_l = dolfinx.fem.functionspace(mesh_l, basix.ufl.element(
"CG", mesh_l.topology.cell_name(), 1, shape=(3, )))
w_l = Function(V_l)
dv = TrialFunction(V_l)
v_= TestFunction(V_l)
dx_l= ufl.Measure('dx')(domain=mesh_l)
C=ufl.as_tensor([[ 7.56043956e+08, 2.26813187e+08, 0.00000000e+00, 9.31322575e-10, 9.31322575e-10, 0.00000000e+00],
def eps(v):
return ufl.as_vector([0,v[1].dx(0),v[2].dx(1),v[1].dx(1)+v[2].dx(0),v[0].dx(1),v[0].dx(0)])
#### Without applying constraints ###############
A_l=dolfinx.fem.petsc.assemble_matrix(form(F2))
A_l.assemble()
print(A_l[:,:].shape)
print('Matrix rank without constraints',np.linalg.matrix_rank(A_l[:,:]))
# Nullspace Constraint implement
index_map = V_l.dofmap.index_map
nullspace_basis = [dolfinx.la.create_petsc_vector(index_map, V_l.dofmap.index_map_bs) for i in range(4)]
with ExitStack() as stack:
vec_local = [stack.enter_context(x.localForm()) for x in nullspace_basis]
basis = [np.asarray(x) for x in vec_local]
dofs = [V_l.sub(i).dofmap.list for i in range(3)]
# Build translational null space basis
for i in range(3):
basis[i][dofs[i]] = 1.0
# Build rotational null space basis
x = V_l.tabulate_dof_coordinates()
dofs_block = V_l.dofmap.list
x0, x1, x2 = x[dofs_block, 0], x[dofs_block, 1], x[dofs_block, 2]
basis[3][dofs[1]] = -x2
basis[3][dofs[2]] = x1
dolfinx.la.orthonormalize(nullspace_basis)
nullspace_l = petsc4py.PETSc.NullSpace().create(nullspace_basis, comm=MPI.COMM_WORLD)
A_l.setNullSpace(nullspace_l)
print('Matrix rank after using constraints',np.linalg.matrix_rank(A_l[:,:]))
I don’t know where I am wrong in dolfinx to constrain A_l matrix for rigid body motion. Any help is greatly appreciated!
