Convergence order of semi-distretization not yielding reasonable convergence order, yet the numerical and true solution look good
Howdy,
So as a warm up I solved the 1d heat equation. First I represent the solution as u= \sum c_j(t)\phi_j(x). Next I do a FEM discretization in space (using first-order CG), resulting in an ODE system for the time dependent coifficents. I solve this problem, for increassing finer meshes (each one have 2x the number of vertices as before). I then calculate the convergence or i.e \frac{ln(\frac{E_{n_x}}{E_{2n_x}})}{ln(2)}. I do this up to 256 grid points in space ( I choose \Delta t=\Delta x for the time integration), and produce the following convergence table:
|  N  |      Max Error      |    Convergence Order    |
|  32 | 0.26974518677568843 |            -            |
|  64 | 0.26985983054165796 |  -0.0006130261573324018 |
| 128 |  0.2698884906012833 | -0.00015321113308644212 |
| 256 | 0.26989568274959913 |  -3.844527950794879e-05 |
Average Convergence Order:-0.0002682275233089309
It looks like the error is not improving (I would expect for a smooth problem that the convergence order would begin to go towards 2, since I used linear basis functions, but it isn’t changing. When I look at a plot of the numerical solution versus the true solution, then look good in the eyeball norm: here is a comparison of the true and exact solution for 256 points
256lastprob
This makes me believe that somehow I’m calulating the error incorrectly. Here I am constructing my own expression at each time step that represents the solution at time step n i.e u(x,t_n) = \sum c_j(t_n) \phi_j(x). I am then comparing it with the true solution at t_n in the L2 norm. I then take the maximum of all these errors to be used in the congerence order calculation for the error at a spatial discretization of n_x. Is this how one would do it correctly?
	max_abs_error = 0.0
	for i in range(0,len(t_list)):
		cur_num_sol = NumericalSolution(i,sol,list_of_basis_functions,V,element=V.ufl_element())
		cur_num_sol_u =interpolate(cur_num_sol, V)
		true_fun = Expression("sin(x[0]*(t+1))",t=t_max ,degree =2)
		error_cur = math.sqrt(assemble(np.inner(cur_num_sol_u - true_fun, cur_num_sol_u- true_fun)*dx))
		print("error" + str((i,error_cur)))
		if(error_cur > max_abs_error):
			max_abs_error=error_cur
		#if(i==len(t_list)-1):
		if(i==0):
			plot(cur_num_sol_u)
			#plt.show()
			plt.savefig(str(n_x)+"firstprob.pdf")
			plt.clf()
			plot(cur_num_sol_u, )
			u_exaxt = interpolate(true_fun,V)
			#plt.show()
			plot(u_exaxt,linestyle="dotted")
			plt.legend(["numerical","exact"])
			plt.savefig(str(n_x)+"lastprob.png")
			plt.clf()
Here is my full code if you want to look at it - thank you:
import math
from numpy.linalg import inv
from scipy.integrate import odeint
from scipy.integrate import solve_ivp
from scipy import *
import scipy
import time
from prettytable import PrettyTable
import pylab as plt
class NumericalSolution(UserExpression):
	def __init__(self,time_step,c_list, basis_funcs,V, **kwargs):
		super().__init__(**kwargs)
		self.c_list = c_list
		self.V=V
		self.time_step=time_step
		basis_vals = np.zeros(V.dim())
		self.basis_vals=basis_vals
		self.basis_funcs=basis_funcs
	def eval(self, values, x):
		V=self.V
		value=0.0
		for i in range(0,V.dim()):
			value = value+self.c_list[self.time_step,i]*self.basis_funcs[i](x)
		#print("value:" + str(value))
		#print("c" +str((self.time_step,self.c_list.max())))
		#print(self.c_list)
		values[0] = value
		# print(value)
		# quit()
	def value_shape(self):
		return (1,)
def basis_func_derv_i(i,x,n,tree,V,spatial_mesh):
    cell_index = tree.compute_first_entity_collision(Point(*x))
    cell_global_dofs = V.dofmap().cell_dofs(cell_index)
    for local_dof in range(0,len(cell_global_dofs)):
        if(i==cell_global_dofs[local_dof]):
            cell = Cell(spatial_mesh, cell_index)
            values = np.array([0,])
            return V.element().evaluate_basis_derivatives(local_dof,n,x,cell.get_vertex_coordinates(),cell.orientation())
    # If none of this cell's shape functions map to the i-th basis function,
    # then the i-th basis function is zero at x.
    return 0.0
def basis_func(i,x,tree,V,spatial_mesh):
            return V.element().evaluate_basis(local_dof,x,
                                              cell.orientation())
    return 0.0
def d_1(t,source_exp,phi_i,first_derv_list_a,first_derv_list_b,left_exp,right_exp,alpha,left_der,right_der):
	source_exp.t =t
	term = source_exp*phi_i*dx
	Term = assemble(term)
	Term = Term.get_local()
	# Term = PETScMatrix()
	# Term = assemble(term,tensor=Term)
	# Term =Term.mat()
	# Term = Term.convert("dense")
	# Term=Term.getDenseArray()
	# for i in range(0,len(Term)):
	# 	Term[i] = Term[i] + alpha*(left_exp(t)*first_derv_list_a[i] - right_exp(t)*first_derv_list_b[i])
	Term[0] = left_der(t)
	Term[-1] = right_der(t)
	return Term
def IC_b(ic_exp,phi_i,dx):
	term = ic_exp*phi_i*dx
	return Term
def ode_prob(t,c,M1_inv,M2,d_fun):
	# print(M2@c)
	# print(d_fun(t))
	# print(M1_inv@(M2@c +d_fun(t)))
	# print(type(M1_inv@(M2@c +d_fun(t))))
	return M1_inv@(M2@c +d_fun(t))
	#return d_fun(t)
def heat_1d(a,b,t_max,n_x,alpha,source_exp,true_fun,order_pol,ic_exp,left_exp,right_exp):
	np.set_printoptions(precision=17)
	order_of_polynomial = order_pol
	spatial_mesh= IntervalMesh(n_x,a,b)
	tree = BoundingBoxTree()
	tree.build(spatial_mesh)
	V = FunctionSpace(spatial_mesh,"CG",order_of_polynomial)
	left_exp_der = lambda t: a*math.cos(a*(t+1))
	right_exp_der = lambda t: b*math.cos(b*(t+1))
	phi_i=TestFunction(V)
	phi_j = TrialFunction(V)
	phi_jx = phi_j.dx(0)
	phi_ix = phi_i.dx(0)
	phi_ixx=phi_ix.dx(0)
	# t=1.0
	# print(len(d_1(t,source_exp,phi_i)))
	# print(d_1(t,source_exp,phi_i)[-1])
	first_derv = lambda i,x:basis_func_derv_i(i,x,1,tree,V,spatial_mesh)
	basis_func_temp  = lambda i,x: basis_func(i,x,tree,V,spatial_mesh)
	first_derv_list_a=np.zeros(V.dim())
	first_derv_list_b=np.zeros(V.dim())
	basis_list_a=np.zeros(V.dim())
	basis_list_b=np.zeros(V.dim())
	list_of_basis_functions_der=[]
	list_of_basis_functions=[]
	point_a = np.array([a])
	point_b = np.array([b])
		list_of_basis_functions_der += [(lambda i: lambda x : first_derv(i,x))(i),]
		list_of_basis_functions +=[(lambda i: lambda x : basis_func_temp(i,x))(i),]
		first_derv_list_a[i] = list_of_basis_functions_der[i](point_a)
		first_derv_list_b[i] = list_of_basis_functions_der[i](point_b)
		basis_list_a[i] = list_of_basis_functions[i](point_a)
		basis_list_b[i] = list_of_basis_functions[i](point_b)
	just_phi = phi_i*dx
	phi_assemb  = assemble(just_phi)
	phi_vec = phi_assemb.get_local()
	first_row = np.zeros(len(phi_vec))
	last_row = np.zeros(len(phi_vec))
	for i in range(0,len(first_row)):
		first_row[i] = basis_list_a[i]*phi_vec[i]
		last_row[i] = basis_list_b[i]*phi_vec[i]
	m1=phi_i*phi_j*dx
	M = PETScMatrix()
	assemble(m1, tensor=M)
	Mmat = M.mat()
	Mmat_dense = Mmat.convert("dense")
	M1=Mmat_dense.getDenseArray()
	M1[0,:] = basis_list_a
	M1[-1,:]=basis_list_b
	M1_inv=inv(M1)
	ic_int =phi_i*phi_j*dx
	ic_mat_pet= PETScMatrix()
	assemble(ic_int, tensor=ic_mat_pet)
	ICmat = ic_mat_pet.mat()
	ICmat_dense = ICmat.convert("dense")
	ic_mat = ICmat_dense.getDenseArray()
	nalpha_f =  Constant(-alpha)
	m2 = nalpha_f*phi_ix*phi_jx*dx
	# M2 = PETScMatrix()
	# M2 = assemble(m2,tensor=M2)
	# M2 = M2.mat()
	# M2 = M2.convert("dense")
	# M2=M2.getDenseArray()
	B = PETScMatrix()
	assemble(m2, tensor=B)
	MBmat = B.mat()
	MBmat_dense = MBmat.convert("dense")
	M2=MBmat_dense.getDenseArray()
	M2_dim = M2.shape
	for i in range(0,M2_dim[0]):
		for j in range(0, M2_dim[1]):
			M2[i,j] = M2[i,j] + alpha*(basis_list_b[i]*first_derv_list_b[j] - basis_list_a[i]*first_derv_list_a[j])
	zero_row = np.zeros(M2_dim[1])
	M2[0,:] = zero_row
	M2[-1,:]=zero_row
	# (w,v)= np.linalg.eig(M1_inv*M2)
	# print(M2)
	# print(w)
	# quit()
	d = lambda t: d_1(t,source_exp,phi_i,first_derv_list_a,first_derv_list_b,left_exp,right_exp,alpha,left_exp_der,right_exp_der)
	#ode_func = lambda c,t: ode_prob(c,t,M1_inv,M2,d)
	ode_func = lambda t,c: ode_prob(c,t,M1_inv,M2,d)
	b_vec = IC_b(ic_exp,phi_i,dx)
	#print(b_vec)
	#IC = M1_inv@b_vec
	IC= np.linalg.solve(ic_mat, b_vec)
	#(IC,info)= scipy.sparse.linalg.gmres(M1,b_vec,maxiter=10000)
	#print(info)
	delta_x = (b-a)/n_x
	n_t = math.ceil((t_max*2*alpha)/delta_x**2)
	n_t=n_x
	t_list = np.linspace(0,t_max,n_t)
	sol = odeint(ode_func, IC,t_list)
	#sol_ode = solve_ivp(ode_func, (0, t_max), IC, method='Radau')
	# for i in range(0,len(t_list)):
	# 	print("--------solution t=" +str(t_list[i])+"-----------")
	# 	print(sol[i,:])
	# 	print("-------------------------------------------------")
	# t_list = sol_ode.t
	# sol= np.zeros((len(t_list),len(IC)))
	# print(sol)
	# for i in range(0,len(IC)):
	# 	sol[:,i] = sol_ode.y[i]
	# sol = np.zeros((len(t_list),len(IC)))
	# sol[0,:]=IC
	# dt = t_list[1]-t_list[0]
	#print(np.linalg.det(M1))
	#quit()
	# comp = M1
	# for val_i in range(1,len(t_list)):
	# 	t_cur = t_list[val_i-1]
	# 	#print(np.linalg.cond(M1))
	# 	#print(M1.max())
	# 	# print(np.all(M1==comp))
	# 	# comp = M1
	# 	next_sol = np.linalg.solve(M1,dt*(M2@sol[val_i-1,:] +d(t_cur)) + M1@sol[val_i-1,:])
	# 	# next_sol= scipy.sparse.linalg.gmres(M1,dt*(M2@sol[val_i-1,:] +d(t_cur)) + (M1@sol[val_i-1,:]))
	# 	#next_sol= M1_inv*(dt*(M2@sol[val_i-1,:] +d(t_cur)) + (M1@sol[val_i-1,:]))
	# 	# M1=comp1
	# 	# M2=comp2
	# 	print("--------solution ----------")
	# 	print("--------t=" +str(t_list[val_i]) +"----------")
	# 	print("--------order_pol=" +str(order_of_polynomial) +"----------")
	# 	print(next_sol)
	# 	print("------------------")
	# 	time.sleep(1)
	# 	sol[val_i,:]=next_sol
	# 	# print(M2@sol[i-1,:])
	max_abs_error = 0.0
		if(i==0):
			plot(cur_num_sol_u)
			#plt.show()
			plt.clf()
			#plt.show()
			plt.clf()
	#t_list = sol.t
	# print(IC)
	# print(sol.shape)
	# print(M1.shape)
	# print(n_x)
	# print(sol[:,0])
	# quit()
	return (n_x,max_abs_error)
def generate_convergence_history(error_list,n_list,file_name):
	x = PrettyTable()
	x.field_names = ["N", "Max Error","Convergence Order"]
	x.add_row([n_list[0], error_list[0],"-"])
	con_list = np.zeros(len(error_list)-1)
	for i in range(0,len(error_list)-1):
		con_order = math.log(error_list[i]/error_list[i+1])/math.log(2.0)
		x.add_row([n_list[i+1], error_list[i+1],con_order])
		con_list[i] = con_order
	print(x)
	print("Average Convergence Order:" + str(np.mean(con_list)))
	f = open(file_name, "a")
	f.write(x.get_string() + str("\n"))
	f.write("Average Convergence Order:" + str(np.mean(con_list)))
	f.close()
def heat_1d_main(a,b,t_max,alpha):
#true solution sin((t+1)x)
#source this then
	true_fun = Expression("sin(x[0]*(t+1))",t=0 ,degree =2)
	source_exp = Expression("cos(x[0]*(t+1))*x[0] +a*sin(x[0]*(t+1))*pow(t+1,2)",t=0,a=alpha ,degree =2)
	left_exp = lambda t: math.sin(a*(t+1))
	right_exp = lambda t: math.sin(b*(t+1))
	ic_exp = Expression("sin(x[0])",t=0 ,degree =2)
#grid size 2^n for n=5....10 so 64 to 1024 grid points
	order_pol=1
	n_list=[]
	error_list=[]
	for i in range(5,9):
		n_x = 2**i
		print("solving 1d heat equation with n=" +str(n_x))
		(n_x,max_error)=heat_1d(a,b,t_max,n_x,alpha,source_exp,true_fun,order_pol,ic_exp,left_exp,right_exp)
		n_list.append(n_x)
		error_list.append(max_error)
	generate_convergence_history(error_list,n_list,"heat_out.txt")
heat_1d_main(0.0,1.0,1.0,2.0)
Your code is very difficult for me to understand, so I can’t see for myself. Are you sure your time discretisation is a 2nd order method or better?
Hey Nate,
Is this someway I can clean up my code to make it more understandable to you or others in the community? The solution to the numerical problem I set up is u(x,t)=\sin(x(t+1)), which is a smooth function. So I’d assume once I started the grid refinement analysis that the ||u-u_h||_{L^2} would go to zero as h\rightarrow0. Right now it seems that the maximum error over time is staying the same as I refine the mesh, which seems wrong to me.
Maybe you can play around with the following and use it to guide you in your own work. It’s tricky to choose the number of time steps in relation to the spatial step size.
# Thermal conducitivty
k = 0.1
# Analytical solution
def u_soln(x, t, sym=np):
	return sym.sin(sym.pi*x[0])*sym.exp(-sym.pi**2 * k * t)
# Spatial approximation order
p_order = 1
# Value used in theta scheme: {0: forward Euler, 0.5: Crank Nicholson, 1: backward Euler}
theta = 0.5
# Maximum time and the maximum value of the solution at final time
t_max = 1.0
print(f"u(0.5, t_max) = {u_soln([0.5], t_max)}")
# Spatial and temporal discretisation
nxs = np.array([8, 16, 32, 64], dtype=int)
nts = np.array(5*k*nxs, dtype=int)
l2_errors = []
l2_error_final = []
# Error computation loop
for nx, nt in zip(nxs, nts):
	print(f"Running case nx={nx}, nt={nt}")
	mesh = dolfinx.mesh.create_unit_interval(MPI.COMM_WORLD, nx)
	V = dolfinx.fem.FunctionSpace(mesh, ("CG", p_order))
	u0 = dolfinx.fem.Function(V)
	u0.interpolate(lambda x: u_soln(x, 0.0))
	dt = dolfinx.fem.Constant(mesh, t_max / nt)
	uth = theta*u + (1 - theta)*u0
	F = ufl.inner((u - u0)/dt, v) * ufl.dx + ufl.inner(k * ufl.grad(uth), ufl.grad(v)) * ufl.dx
	a, L = ufl.lhs(F), ufl.rhs(F)
	facets = dolfinx.mesh.locate_entities_boundary(
		mesh, mesh.topology.dim-1, lambda x: np.full_like(x[0], True))
	bc_dofs = dolfinx.fem.locate_dofs_topological(
		V, mesh.topology.dim-1, facets)
	bc = dolfinx.fem.dirichletbc(np.asarray(0.0, dtype=np.double), bc_dofs, V)
	problem = dolfinx.fem.petsc.LinearProblem(
		a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
	# Exact representation of the solution at the quadrature points
	t = dolfinx.fem.Constant(mesh, 0.0)
	u_exact = u_soln(ufl.SpatialCoordinate(mesh), t, sym=ufl)
	l2_error_u_vs_t = np.zeros(nt + 1, dtype=np.double)
	l2error_u = mesh.comm.allreduce(
		dolfinx.fem.assemble.assemble_scalar(
			dolfinx.fem.form((u0 - u_exact) ** 2 * ufl.dx))**0.5,
		op=MPI.SUM)
	u_l2 = mesh.comm.allreduce(
			dolfinx.fem.form(u_exact ** 2 * ufl.dx))**0.5,
		op=MPI.SUM)
	l2_error_u_vs_t[0] = l2error_u / u_l2
	# Time loop
	for dt_i in range(1, nt+1):
		uh = problem.solve()
		u0.x.array[:] = uh.x.array
		u0.x.scatter_forward()
		t.value = dt_i * dt.value
				dolfinx.fem.form((uh - u_exact) ** 2 * ufl.dx))**0.5,
			op=MPI.SUM)
			op=MPI.SUM)
		l2_error_u_vs_t[dt_i] = l2error_u / u_l2
	l2_errors.append(l2_error_u_vs_t)
	l2_error_final.append(l2_error_u_vs_t[-1])
# Compute rates
l2_error_final = np.array(l2_error_final, dtype=np.double)
h = 1.0 / np.array(nxs, dtype=np.double)
end_rate = np.log(l2_error_final[:-1]/l2_error_final[1:]) / np.log(h[:-1]/h[1:])
print(f"t=t_max convergence rates: {end_rate}")
# Plot error vs time
for i, (nx, nt) in enumerate(zip(nxs, nts)):
	plt.semilogy(np.linspace(0, t_max, nt+1), l2_errors[i], "-o", label=f"$n_x = {nx}, n_t = {nt}$")
plt.grid()
plt.xlim(0.0, t_max)
plt.xlabel("$t$")
plt.ylabel(r"$\Vert u(x, t) - u_h(x, t)\Vert_{L_2(\Omega)} / \Vert u(x, t) \Vert_{L_2(\Omega)}$")
plt.legend()
Which gives me:
t=t_max convergence rates: [1.99456405 1.99863957 1.99965981]
Hi nate,
Thanks a lot for the response. Great explanation and I found out what my problem was:
I was accidently always evaluating the true solution at the final time rather than the time step I wanted to compare the numerical solution with
Changing it to
true_fun = Expression("sin(x[0]*(t+1))",t=t_list[i] ,degree =2)
yields a convergence table of
|  32  | 0.00022939920740024068 |         -          |
|  64  | 5.736353920536092e-05  | 1.999654463652096  |
| 128  |  1.43675046559781e-05  | 1.9973245212282682 |
| 256  | 3.5929865481595023e-06 | 1.999554077564116  |
| 512  | 9.272496943505876e-07  | 1.9541537417355859 |
| 1024 | 2.2701963249854172e-07 | 2.0301408210064853 |
Average Convergence Order:1.9961655250373103
which I would expect since I used degree polynomial one, resulting an a convergence order one higher than the degree of polynomial I used.
Thanks a lot for the help - I think this is a good post for those who want to actually test their solver is working as intented.
Thank you
