Howdy,
So as a warm up I tried to solve the 1-d heat equation where I say that u(x,t) = \sum c_j(t) \phi_j(x). I do the FEM in space, and generate the matices associated for each term in the final system of ODE: M_1 \dot{c} = M_2c + d(t).
When I do the time stepping just doing a simple euler:
for i in range(1,len(t_list)):
t = t_list[i-1]
print(np.linalg.cond(M1))
next_sol = np.linalg.solve(M1,dt*(M2@sol[i-1,:] +d(t)) + (M1@sol[i-1,:]))
sol[i,:]=next_sol
# print(M2@sol[i-1,:])
3.9938387318170525
3.9938387318170525
3.9938387318170525
5960.4321111585605
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
70872.20443761055
141053.0689730364
141053.0689730364
4108.854366444064
3570269581.8684115
3570269581.8684115
3570269581.8684115
3570269581.8684115
3570269581.8684115
20314608610026.54
558294360160.5804
558294360160.5804
71401822674.21254
71401822674.21254
23072194296.435165
23072194296.435165
5648302300952801.0
5648302300952801.0
5648302300952801.0
5648302300952801.0
5648302300952801.0
5648302300952801.0
3.241721984318394e+18
2071418921090024.0
2071418921090024.0
1.8281517530721127e+22
7.455156198284555e+28
1.8370838355398053e+28
1.8643064584435324e+27
2.9459028094408635e+29
6.347724126735073e+30
5.915766739658558e+36
5.658535187497739e+40
4.949629828329596e+44
1.4172700791877978e+24
2.5282685613029403e+28
8.315960439107994e+34
2.3362140819840576e+43
9.083946732855834e+60
1.4437317885697556e+65
5.635664062124686e+59
4.548278265376804e+69
2.33032614244715e+72
3.356795993965915e+83
1.7513137109850495e+97
4.2422509650004495e+104
5.065573093182438e+125
inf
5.368240868941827e+177
1.5074951988067158e+196
1.816253544677133e+214
inf
inf
inf
inf
inf
inf
inf
inf
I am extremely confused because each iteration the condition number of the matrix M1 is changing, even though I am not editing it anywhere during the time stepping. (which means also M1) is changing itself each iteration somehow. This is extremely strange behavior to me?
Here is my complete code:
import math
from numpy.linalg import inv
from scipy.integrate import odeint
from scipy import *
import scipy
class NumericalSolution(UserExpression):
def __init__(self,time_step,c_list, basis_funcs,V, **kwargs):
super().__init__(**kwargs)
self.c_list = c_list
self.V=V
self.time_step=time_step
basis_vals = np.zeros(V.dim())
self.basis_vals=basis_vals
self.basis_funcs=basis_funcs
def eval(self, values, x):
V=self.V
value=0.0
for i in range(0,V.dim()):
value = value+self.c_list[self.time_step,i]*self.basis_funcs[i](x)
values[0] = value
# print(value)
# quit()
def value_shape(self):
return (1,)
def basis_func_derv_i(i,x,n,tree,V,spatial_mesh):
cell_index = tree.compute_first_entity_collision(Point(*x))
cell_global_dofs = V.dofmap().cell_dofs(cell_index)
for local_dof in range(0,len(cell_global_dofs)):
if(i==cell_global_dofs[local_dof]):
cell = Cell(spatial_mesh, cell_index)
values = np.array([0,])
return V.element().evaluate_basis_derivatives(local_dof,n,x,cell.get_vertex_coordinates(),cell.orientation())
# If none of this cell's shape functions map to the i-th basis function,
# then the i-th basis function is zero at x.
return 0.0
def basis_func(i,x,tree,V,spatial_mesh):
return V.element().evaluate_basis(local_dof,x,
cell.orientation())
return 0.0
def d_1(t,source_exp,phi_i,first_derv_list_a,first_derv_list_b,left_exp,right_exp,alpha):
source_exp.t =t
term = source_exp*phi_i*dx
Term = assemble(term)
Term = Term.get_local()
# Term = PETScMatrix()
# Term = assemble(term,tensor=Term)
# Term =Term.mat()
# Term = Term.convert("dense")
# Term=Term.getDenseArray()
for i in range(0,len(Term)):
Term[i] = Term[i] + alpha*(left_exp(t)*first_derv_list_a[i] - right_exp(t)*first_derv_list_b[i])
return Term
def IC_b(ic_exp,phi_i):
term = ic_exp*phi_i*dx
return Term
def ode_prob(c,t,M1_inv,M2,d_fun):
print(M2@c)
print(d_fun(t))
print(M1_inv@(M2@c +d_fun(t)))
print(type(M1_inv@(M2@c +d_fun(t))))
return M1_inv@(M2@c +d_fun(t))
def heat_1d(a,b,t_max,n_x,alpha,source_exp,true_fun,order_pol,ic_exp,left_exp,right_exp):
order_of_polynomial = order_pol
spatial_mesh= IntervalMesh(n_x,a,b)
tree = BoundingBoxTree()
tree.build(spatial_mesh)
V = FunctionSpace(spatial_mesh,"CG",order_of_polynomial)
phi_i=TestFunction(V)
phi_j = TrialFunction(V)
phi_ix = phi_i.dx(0)
phi_ixx=phi_ix.dx(0)
# t=1.0
# print(len(d_1(t,source_exp,phi_i)))
# print(d_1(t,source_exp,phi_i)[-1])
m1=phi_i*phi_j*dx
M = PETScMatrix()
assemble(m1, tensor=M)
Mmat = M.mat()
Mmat_dense = Mmat.convert("dense")
print("Dense")
M1=Mmat_dense.getDenseArray()
print(M1)
M1_inv=inv(M1)
alpha_f = p = Constant(alpha)
m2 = alpha_f*phi_ixx*phi_j*dx
# M2 = PETScMatrix()
# M2 = assemble(m2,tensor=M2)
# M2 = M2.mat()
# M2 = M2.convert("dense")
# M2=M2.getDenseArray()
M = PETScMatrix()
assemble(m2, tensor=M)
Mmat = M.mat()
M2=Mmat_dense.getDenseArray()
first_derv = lambda i,x:basis_func_derv_i(i,x,1,tree,V,spatial_mesh)
basis_func_temp = lambda i,x: basis_func(i,x,tree,V,spatial_mesh)
first_derv_list_a=np.zeros(V.dim())
first_derv_list_b=np.zeros(V.dim())
basis_list_a=np.zeros(V.dim())
basis_list_b=np.zeros(V.dim())
list_of_basis_functions_der=[]
list_of_basis_functions=[]
point_a = np.array([a])
point_b = np.array([b])
list_of_basis_functions_der += [(lambda i: lambda x : first_derv(i,x))(i),]
list_of_basis_functions +=[(lambda i: lambda x : basis_func_temp(i,x))(i),]
first_derv_list_a[i] = list_of_basis_functions_der[i](point_a)
first_derv_list_b[i] = list_of_basis_functions_der[i](point_b)
basis_list_a[i] = list_of_basis_functions[i](point_a)
basis_list_b[i] = list_of_basis_functions[i](point_b)
M2_dim = M2.shape
for i in range(0,M2_dim[0]):
for j in range(0, M2_dim[1]):
M2[i,j] = M2[i,j] + alpha*(basis_list_b[i]*first_derv_list_b[j] - basis_list_a[i]*first_derv_list_a[j])
d = lambda t: d_1(t,source_exp,phi_i,first_derv_list_a,first_derv_list_b,left_exp,right_exp,alpha)
ode_func = lambda c,t: ode_prob(c,t,M1_inv,M2,d)
b_vec = IC_b(ic_exp,phi_i)
#print(b_vec)
#IC = M1_inv@b_vec
IC= np.linalg.solve(M1, b_vec)
#(IC,info)= scipy.sparse.linalg.gmres(M1,b_vec,maxiter=10000)
#print(info)
# delta_x = (b-a)/n_x
# n_t = math.ceil((t_max*3*alpha)/delta_x**2)
n_t=2*n_x
t_list = np.linspace(0,t_max,num=10000)
#sol = odeint(ode_func, IC,t_list)
sol = np.zeros((len(t_list),len(IC)))
sol[0,:]=IC
dt = t_list[1]-t_list[0]
print("mat")
print(M1)
#print(np.linalg.det(M1))
#quit()
comp = M1
t = t_list[i-1]
sol[i,:]=next_sol
max_abs_error = 0.0
# for i in range(0,len(t_list)):
# cur_num_sol = NumericalSolution(i,sol,list_of_basis_functions,V,element=V.ufl_element())
# cur_num_sol_u =interpolate(cur_num_sol, V)
# error_cur = math.sqrt(assemble(inner(cur_num_sol_u - true_fun, cur_num_sol_u- true_fun)*dx))
# if(error_cur > max_abs_error):
# max_abs_error=error_cur
# print(max_abs_error)
#t_list = sol.t
# print(IC)
# print(sol.shape)
# print(M1.shape)
# print(n_x)
# print(sol[:,0])
# quit()
return
def heat_1d_main(a,b,t_max,alpha):
#true solution sin((t+1)x)
#source this then
true_fun = Expression("sin(x[0]*(t+1))",t=0 ,degree =2)
source_exp = Expression("cos(x[0]*(t+1))*x[0] +a*sin(x[0]*(t+1))*pow(t+1,2)",t=0,a=alpha ,degree =2)
left_exp = lambda t: math.sin(a*(t+1))
right_exp = lambda t: math.sin(b*(t+1))
ic_exp = Expression("sin(x[0])",t=0 ,degree =2)
#grid size 2^n for n=5....10 so 64 to 1024 grid points
order_pol=1
for i in range(5,11):
n_x = 2**i
print("solving 1d heal equation with n=" +str(n_x))
heat_1d_main(0.0,1.0,1.0,1.0)
