If I use polynomial degree 2, then while using DG(1)CG(2), i.e., DG time stepping with standard Galerkin method in space, I am not getting the correct order of convergence in L2 and H1 norm. One thing here to mention is that while defining the solution U(t)=~U0+~U1(t−tn−1)/Δt on Jn:=(tn−1,tn], so I think the issue is in defining the initial value because tn−1 is not in Jn, the minimal heat equation code for dg time stepping method for approximating polynomial is given below. Here, as I decrease the mesh size, the error increases. This is minimal code for DG(1) in time; DG(0) reduces to the modified Eulers method in time.
## Equation to solve u_t - (1/2pi^2)\Delta u = 0, for exact solution u_exact = e^{-t} sin(pi*x) sin(pi*y)
set_log_level(LogLevel.ERROR)
T = 1.0 # final time
e_time = 0
for j in range(1,5):
nx = 2**(j+1)
T = 1
num_steps = nx
dt = T / (num_steps)
mesh = UnitSquareMesh(nx, nx)
P2 = FiniteElement("Lagrange", triangle, 2)
#element = VectorElement("P2", triangle, 2, dim=2)
element = MixedElement([P2, P2])
W = V.sub(0).collapse()
R = Function(W)
t = 0
u_D = Expression('exp(-t)*sin(pi*x[0])*sin(pi*x[1])', degree = 3, t=t)
def boundary(x, on_boundary):
return on_boundary
bc1 = DirichletBC(V.sub(0), u_D, boundary)
bc2 = DirichletBC(V.sub(1), u_D, boundary)
bc = [bc1, bc2]
U_1, U_2 = TrialFunctions(V)
u_g = Expression(('exp(-t)*sin(pi*x[0])*sin(pi*x[1])', '0'), degree = 3, t=t)
U_n = interpolate(u_g, V)
U_n1, U_n2 = split(U_n)
p, q = TestFunctions(V)
e_time = 0
for i in range(num_steps):
(U_1, U_2) = TrialFunctions(V)
t = (i+1)*dt
u_D = Expression('exp(-t)*sin(pi*x[0])*sin(pi*x[1])', degree = 3, t=(i+1)*dt)
a = (U_1 + U_2) * p * dx + dt/(2*pi*pi) * dot(grad(U_1), grad(p)) * dx + dt / (4*pi*pi) * dot(grad(U_2), grad(p)) * dx + 1 / 2 * U_2 * q * dx + 1 / (4*pi*pi) * dt * dot(grad(U_1), grad(q)) * dx + dt / (6*pi*pi) * dot(grad(U_2), grad(q)) * dx
L = U_n1 * p * dx + U_n2*p*dx
U = Function(V)
solve(a == L, U, bc)
U_1, U_2 = U.split(deepcopy=True)
R = project(U_1 + U_2, W)
U_1.assign(U_1)
U_2.assign(U_2)
vertex_values_u_D = u_D.compute_vertex_values(mesh)
vertex_values_R = R.compute_vertex_values(mesh)
error_max = np.max(np.abs(vertex_values_u_D - vertex_values_R))
error_L2 = errornorm(u_D, R, 'L2')
error_H1 = errornorm(u_D, R, 'H1')
e_time = (e_time + dt*error_H1*error_H1)
e_time1 = sqrt(e_time)
print ('dt=%.6f nx=%.2f error_L2=%8.4E error_H1=%8.4E e_time1=%8.4E error_max = %8.4E' % (dt, nx, error_L2, error_H1, e_time1, error_max ))
getting wrong results as:
dt=0.250000 nx=4.00 error_L2=2.0440E-01 error_H1=9.3619E-01 e_time1=4.6810E-01 error_max = 4.1447E-01
dt=0.125000 nx=8.00 error_L2=2.5724E-01 error_H1=1.1719E+00 e_time1=4.1431E-01 error_max = 5.1490E-01
dt=0.062500 nx=16.00 error_L2=2.8576E-01 error_H1=1.3014E+00 e_time1=3.2535E-01 error_max = 5.7155E-01
dt=0.031250 nx=32.00 error_L2=3.0068E-01 error_H1=1.3693E+00 e_time1=2.4206E-01 error_max = 6.0136E-01
