I am trying to understand how to get stiffness matrices out computed for elasticity problems.
I ported a MEW in this post to the latest dolfinx version, so:
V = dolfinx.fem.FunctionSpace(mesh, ("Lagrange", 1))
u = ufl.TrialFunction(V)
#A = dolfinx.fem.assemble_matrix(dolfinx.fem.form(a))
A = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a))
B = A.convert("dense")
C = A.getDenseArray()
and it seems to work right.
The following also works
G = dolfinx.fem.assemble_matrix(dolfinx.fem.form(a))
and now G is a dolfinx.la.MatrixCSR object, not a petsc4py.PETSc.Mat like t as above. I presume the two are (numerically) equal, but do not know how to extract values from a dolfinx.la.MatrixCSR matrix.
Furtherm if I consider a different case though,
L = 1
W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
from dolfinx import mesh, fem, plot, io
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],
[20,6,6], cell_type=mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
def clamped_boundary(x):
return np.isclose(x[0], 0)
u_D = np.array([0,0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
T = fem.Constant(domain, ScalarType((0, 0, 0)))
return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2*mu*epsilon(u)
f = fem.Constant(domain, ScalarType((0, 0, -rho*g)))
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
A = fem.petsc.assemble_matrix(fem.form(a), bcs=[bc])
A.getValuesCSR()
works as before, but:
returns an error,
Error: error code 56
[0] [0] MatDenseGetLDA() at /home/conda/f<....>dense.c:2100
[0] No support for this operation for this object type
[0] Cannot locate function MatDenseGetLDA_C in object
same for
M = fem.assemble_matrix(fem.form(a))
giving an error
RuntimeError: Block size not yet supported
The immediate difference in the two cases is that the latter uses a VectorFunctionSpace.
The tutorial demonstrates fem.petsc.assemble_matrix but also uses a FunctionSpace.
Why the errors when using DenseArray on a a petsc4py.PETSc.Mat object, or after M = fem.assemble_matrix(fem.form(a))? Thanks a lot.
I tried to get to the PETSc4py code, I somehow get to this repo but I cannot figure out at all where to look for the functions used in Dolfinx, a hint would also be greatly appreciated.
