I am trying to use a COMSOL mesh exported in .mphtxt format with legacy FEniCS. However, I am not sure how to convert this format into one that can be used in my FEniCS code.
Currently, my workflow uses the XDMF format because I need MPI support for parallel computations.
Could anyone suggest the correct workflow to convert a COMSOL .mphtxt mesh into a format compatible with legacy FEniCS? Alternatively, is there a better mesh export format from COMSOL that works reliably with FEniCS and XDMF?
Thank you.
import os
## convert the mesh from .msh to .xml
os.system('dolfin-convert geo/BCS.msh geo/BCS.xml')
mesh = Mesh("geo/BCS.xml")
facet_f = MeshFunction("size_t", mesh, "geo/BCS_facet_region.xml")
region_f = MeshFunction("size_t", mesh, "geo/BCS_physical_region.xml")
##convert the xml mesh to xdmf
with XDMFFile("geo/mesh_BCS.xdmf") as f:
f.write(mesh)
with XDMFFile("geo/facet_BCS.xdmf") as f:
f.write(facet_f)
with XDMFFile("geo/region_BCS.xdmf") as f:
f.write(region_f)
print("Converted successfully!")
Thankyou @nate. I tried the .stl file from Comsol, used Gmsh to create a surface with tag 1 (include all in one) and a volume with tag 1, but there is a problem when I import the mesh in Fenics using the above code. The STL file is this. What does it look like and
Expecting 39087 vertices
Found all vertices
Expecting 231505 cells
Found all cells
File "/home/shah/miniconda3/envs/fenics-env/bin/dolfin-convert", line 132, in <module>
main(sys.argv[1:])
File "/home/shah/miniconda3/envs/fenics-env/bin/dolfin-convert", line 79, in main
meshconvert.convert2xml(ifilename, ofilename, iformat=iformat)
File "/home/shah/miniconda3/envs/fenics-env/lib/python3.10/site-packages/dolfin_utils/meshconvert/meshconvert.py", line 1301, in convert2xml
convert(ifilename, XmlHandler(ofilename), iformat=iformat)
File "/home/shah/miniconda3/envs/fenics-env/lib/python3.10/site-packages/dolfin_utils/meshconvert/meshconvert.py", line 1322, in convert
gmsh2xml(ifilename, handler)
File "/home/shah/miniconda3/envs/fenics-env/lib/python3.10/site-packages/dolfin_utils/meshconvert/meshconvert.py", line 494, in gmsh2xml
index = nodes_as_facets[tuple(nodes)]
KeyError: (288, 289, 15868)
File "/home/shah/phd/fenics/convert_xdmf.py", line 9, in <module>
mesh = Mesh("geo2/BCS.xml")
RuntimeError:
*** Error: Unable to read data from XML file.
*** Reason: Error while parsing XML with status "Start-end tags mismatch".
*** Where: This error was encountered inside XMLFile.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 828b3965c3ebcd128da494c596c78b17c0a303da
