How to convert 3D mesh from Comsol to .xml for legacy fenics?
I meshed a 3D Cube in COMSOL using a free tetrahedral mesh. I wanted to export this mesh into some format which is readable by legacy fenics.
Unfortunately (cf. p. 6 of https://www.comsol.com/model/download/1273541/COMSOL_MeshImportExportGuide.pdf ) Comsol does just support NASTRAN and Comsol-multiphysics files for the export of full 3D meshes, while the other formats (as .stl or .ply) just support the export of the surface part.
I now wanted to convert the exported .nas file to an .xml file using meshio 5.3.5, i.e.:
meshio convert foo.nas foo.xml
But this gives the error:
meshio._exceptions.WriteError: DOLFIN XML only supports triangles and tetrahedra. Consider using XDMF instead.
However, the .nas file looks like it would contain a tetrahedral mesh (although it is not clear to me, what +CONT means in the element data section), as you can see from the following snippet of the .nas file:
$ Generated by COMSOL 6.1.0.357
$ Sep 19 2024, 12:52
BEGIN BULK
$ Grid data section
GRID           1        0.0000000.0000000.000000
GRID           2        0.0000000.0000000.100000
GRID           3        0.0000000.0620530.064720
GRID           4        0.0000000.1000000.000000
GRID           5        0.0000000.0000000.200000
GRID       23665        0.9762760.9757490.899960
GRID       23666        0.9525530.9014980.949920
$ Element data section
CTETRA         1       1       4       7       3       1    4018    5473+CONT
+CONT       3291    3179    4017    3289
CTETRA         2       1       6       3       2       9    5474    3290+CONT
+CONT       5475    5476    3294    3292
CTETRA         3       1       6       9       2       5    5476    3292+CONT
+CONT       5475    5477    3293    3170
CTETRA         4       1       1       3      10       7    3289    5478+CONT
+CONT       3653    4017    5473    5479
CTETRA     16563       1    3166    3164    3168    3163    4741    4744+CONT
+CONT       3278    5471   23662    5472
$ Property data section
PSOLID         1
ENDDATA
Do you have an idea, how I can convert this into a 3D mesh that is usable in legacy fenics, presumably in the .xml format?
Without a full grid, it is impossible to reproduce the error or help you.
Please consider using meshio as a Python package, and consider: Cannot read facetag when converting .bdf file genarted from hypermesh to xdmf - #22 by dokken for inspiration as to how to use meshio from Python.
