Hi Everyone,
I have a quick question about converting a gmsh mesh to xdmf. I’m using the following .geo file
SetFactory(“OpenCASCADE”);
Cylinder(1) = {0.0, 0, 0.0, 0, 0, 1, .5};
Cylinder(2) = {0.0, 0, 0.0, 0, 0, 1, .25};
BooleanDifference{ Volume{1}; Delete; }{ Volume{2}; Delete; }
Physical Surface(“TOP”) = {6};
Physical Surface(“BOTTOM”) = {7};
Physical Surface(“INNER”) = {4};
Physical Surface(“OUTER”) = {5};
Physical Volume(“VOL”) = {1};
and based on some of the code from a different thread, the following code to convert the mesh to xdmf.
msh = meshio.read("TC_mesh.msh")
for cell in msh.cells:
if cell.type == "triangle":
triangle_cells = cell.data
elif cell.type == "tetra":
tetra_cells = cell.data
if key == "triangle":
elif key == "tetra":
tetra_data = msh.cell_data_dict["gmsh:physical"][key]
triangle_mesh =meshio.Mesh(points=msh.points,
I’m under the impression the mf.xdmf file should be outputting the entire surface of the mesh. However, when I examine it in paraview I’m only getting one slice.
Can someone explain if I’m misunderstanding something or if there is a bug here?
Thank You
