Hello everyone,
I am new to FeniCS and trying to learn it for a school project by implementing the Allen-Cahn equation:
\frac{\partial \varphi}{\partial t } = \nabla^2 \varphi +\varphi -\varphi^3
Its variational formulation is as follows:
\int_{\Omega}\varphi_{n+1} v \,d\Omega = \int_{\Omega}\varphi_{n} v \,d\Omega + dt \left[-\int_{\Omega} \nabla\varphi_n \nabla v \, d\Omega \, + \int_{\Omega} (\varphi_n - \varphi_n^3)v \, d\Omega \right]
Which i implemented as a linear problem in DolfinX :
from dolfinx.io.gmshio import model_to_mesh
import pyvista
import dolfinx.fem as fem
import dolfinx.mesh as mesh
import dolfinx.io as io
import dolfinx.plot as plot
from dolfinx.fem import Expression
import dolfinx_mpc.utils
from dolfinx_mpc import LinearProblem, MultiPointConstraint
##Generate square mesh##
L,W = 1,1
nx,ny = 50,50
mesh = dolfinx.mesh.create_rectangle(
MPI.COMM_WORLD,
[np.array([0, 0]), np.array([L, W])],
[nx, ny], dolfinx.mesh.CellType.triangle
##Define scalar field
element_a= ufl.FiniteElement('CG',mesh.ufl_cell(),degree=1)
V_a = fem.FunctionSpace(mesh, element_a)
phi_next = fem.Function(V_a, name="phase")
phi_prev = fem.Function(V_a, name="phaseold")
##initial conditions : Random distribution between -1 and 1
def randm(x):
return [np.random.random()*2-1 for i in range(len(x[0]))]
phi_prev.interpolate(randm)
## Define variational problem
v = ufl.TestFunction(V_a)
u = ufl.TrialFunction(V_a)
from ufl import Measure
dx = ufl.Measure("dx", domain=mesh)
dt = 1e-6
def a(u,v):
return u*v*dx
def L(v):
return phi_prev*v*dx-dt* ufl.dot(ufl.grad(phi_prev),ufl.grad(v))*dx - dt*phi_prev*v*dx + dt*phi_prev**3*v*dx
##Define periodic boundary conditions along x, it need sto be along y too but corner points are wrong
def periodic_boundary_x(x):
return np.isclose(x[0], 1, atol=1e-6)
def periodic_relation_x(x):
out_x = np.zeros_like(x)
out_x[0] = x[0]-1
out_x[1] = x[1]
out_x[2] = x[2]
return out_x
mpc = MultiPointConstraint(V_a)
mpc.create_periodic_constraint_geometrical(V_a, periodic_boundary_x, periodic_relation_x,[])
mpc.finalize()
#Main solver loop
ffile = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "AC_Random.xdmf", "w")
ffile.write_mesh(mesh)
ffile.write_function(phi_prev, 0)
Nstep=1000
for n in range(1,Nstep):
print("Timestep ",n)
problem = LinearProblem(a(u,v), L(v),mpc)
ph = problem.solve()
ph.name = "phase"
phi_prev.x.array[:] = ph.x.array
ffile.write_function(ph, n)
ffile.close()
The code is running and i am getting a solution but it behaves in the wrong way, as if the \varphi-\varphi³ term is not being considered. In fact, I initialize the field with a a random noise between -1 and 1 and it evolves to a smooth variation around 0, which is not the right physical behavior because the last term is supposed to penalize this and separate phases into regions of -1 others of +1
Is my implementation correct?
Thank you for your help
