Hi
I am using NewtonSolver along with mumps as the linear solver like this:
ns = NewtonSolver()
ns['linear_solver'] = 'mumps'
Now I want to tune the parameters like mat_mumps_icntl_14, so I did the following after reading some old posts
PETScOptions.set('mat_mumps_icntl_14', 40)
PETScOptions.set('mat_mumps_icntl_35', 2)
PETScOptions.set('mat_mumps_icntl_36', 1)
But nothing really changes (runtime, memory use, etc), but supposedly, at least the latter two should effectively reduce operations (by sacrificing accuracy). Am I missing something, or is this just how it is?
Thanks for any suggestions!
Victor
The following excerpt works for me in the context of a different problem:
PETScOptions.set("mat_mumps_icntl_24",1)
problem = NonlinearVariationalProblem(F,w,bcs,J=derivative(F,w))
solver.parameters['newton_solver']['linear_solver'] = 'mumps'
solver.solve()
In this example, F is the residual for a saddle point problem (which I’ve left out for clarity), and MUMPS fails if I comment the first line, so the option is clearly being applied.
Just saw the reply. I decided to go directly with PETSc to avoid the ambiguity from the dolfin wrappers:
PETSc.Options()['mat_mumps_icntl_35'] = 1
It seems to work.
Thanks anyways
