Hello every one hope you are fine.
I have the next question to ask to you about the formulation in multiphenics about non linear contact problem using unbiased Nitsche method.
The idea is to simulate the contact between two bodies considering Coulomb Friction Law and small strains. The bodies are assumed to be already in contact (gap function =0 ).
The formula used was taken from Finite Element Approximation of Contact and Friction in Elasticity (Chapter 10, page 245) from Franz Chouly, Patrick Hild, Yves Renard:
I am getting no convergence using this method:
*** Warning: PETSc SNES solver diverged in 0 iterations with divergence reason DIVERGED_FNORM_NAN.
File "/home/user/fenics_work/MODELO/multiphenics_nonlinear/example_two_rectangles_multiphenics.py", line 223, in <module>
solver.solve()
File "/home/user/.local/lib/python3.12/site-packages/multiphenics/nls/block_petsc_snes_solver.py", line 27, in solve
no_iterations, convergence_flag = PETScSNESSolver.solve(
RuntimeError:
*** https://fenicsproject.discourse.group/
*** Error: Unable to solve nonlinear system with PETScSNESSolver.
*** Reason: Solver did not converge.
*** Where: This error was encountered inside PETScSNESSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.2.0.13.dev0
*** Git changeset: ubuntu
The MWE uses legacy multiphenics inspired in the tutorials:
from multiphenics import *
# Solver parameters
snes_solver_parameters = {"nonlinear_solver": "snes",
"snes_solver": {"linear_solver": "mumps",
"maximum_iterations": 20,
"report": True,
"error_on_nonconvergence": True}}
parameters["allow_extrapolation"] = True
# RectangleMesh(Point(-1, -1), Point(1.0, 1.0), 100, 50)
mesh = RectangleMesh(Point(-1.0, -2.0), Point(1.0, 2.0), 50, 100)
bdry = MeshFunction('size_t', mesh, 1, 0)
subdomains = MeshFunction("size_t", mesh, 2, 0)
dim = mesh.topology().dim()
# Surface subdomains
class Omega2(SubDomain):
return x[1] >= 0.
class Omega1(SubDomain):
return x[1] <= 0.
class Interface(SubDomain):
return near(x[1], 0.0)
# Boundary subdomains
class Top(SubDomain):
return (near(x[1], 2.0) and on_boundary)
class TRight(SubDomain):
return (near(x[0], 1.0) and between(x[1], (0.0, 2.0)) and on_boundary)
class TLeft(SubDomain):
return (near(x[0], -1.0) and between(x[1], (0.0, 2.0)) and on_boundary)
class BRight(SubDomain):
return (near(x[0], 1.0) and between(x[1], (-2.0, 0.0)) and on_boundary)
class BLeft(SubDomain):
return (near(x[0], -1.0) and between(x[1], (-2.0, 0.0)) and on_boundary)
class Bot(SubDomain):
return (near(x[1], -2.0) and on_boundary)
# parametros físicos
E1 = 1.1E11 # ACERO GPa
E2 = 1.1E11
nu = 0.35
top = 1
bottom = 2
interface = 3
tright = 4
bright = 5
tleft = 6
bleft = 7
O1 = 1
O2 = 2
alfa = 20
Omega2().mark(subdomains, O2)
Omega1().mark(subdomains, O1)
Interface().mark(bdry, interface)
Top().mark(bdry, top)
TRight().mark(bdry, tright)
TLeft().mark(bdry, tleft)
BRight().mark(bdry, bright)
BLeft().mark(bdry, bleft)
Bot().mark(bdry, bottom)
def pos_f(u):
return 0.5*(abs(u) + u)
def neg_f(u):
return 0.5*(abs(u) - u)
def tnv(v, normal):
return v - dot(v, normal)*normal
return sym(grad(u))
def D(E, nu, u):
mu = E/(2*(1+nu))
lamb = E*nu/((1-2*nu)*(1+nu))
return 2*mu*epsilon(u)+lamb*tr(epsilon(u))*Identity(dim)
def Pin(v, normal, E, nu):
jumpu = jump(v, normal) # scalar
sigmn = avg(dot(D(E, nu, v)*normal, normal)) # scalar
return gamN*jumpu - sigmn
def Pit(v, normal, E, nu):
jumpu = jump(tnv(v, normal)) # vector
sig_t = avg(tnv(D(E, nu, v)*normal, normal)) # vector
return gamN*jumpu - sig_t
def Pit_fric(v, normal, E, nu, fric):
# Coulomb friction law: - fric*|sig_n(u) | * u_t/|u_t|
sigmn = avg(abs(dot(D(E, nu, v)*normal, normal)))
v_t = avg(tnv(v, normal))
Coulomb = -fric*sigmn*v_t/sqrt(dot(v_t, v_t))
return gamN*jumpu - Coulomb
# print(domains.array())
omega1 = MeshRestriction(mesh, Omega1())
omega2 = MeshRestriction(mesh, Omega2())
dx = Measure("dx", domain=mesh, subdomain_data=subdomains)
ds = Measure("ds", domain=mesh, subdomain_data=bdry)
dS = Measure("dS", domain=mesh, subdomain_data=bdry)
Pv = VectorFunctionSpace(mesh, "CG", 1)
# u1 = u on Bottom domain
# u2 = u on Top domain
# u1, u2
Hh = BlockFunctionSpace([Pv, Pv],
restrict=[omega1, omega2])
sol = BlockFunction(Hh)
u1, u2, = block_split(sol)
test = BlockTestFunction(Hh)
v1, v2 = block_split(test)
dsol = BlockTrialFunction(Hh) # To use with Jacobian
bcUtleft = DirichletBC(Hh.sub(1), Constant((0, 0)), bdry, tleft)
bcUbleft = DirichletBC(Hh.sub(0), Constant((0, 0)), bdry, bleft)
bcs = BlockDirichletBC([bcUtleft, bcUbleft])
h = CellDiameter(mesh)
h_avg = (h("+") + h("-")) / 2.0
gamN = alfa/h_avg
# Define bilinear form tanto en el domino 1 como en el dominio 2
aO1 = inner(D(E1, nu, u1), epsilon(v1)) * dx(O1)
aO2 = inner(D(E2, nu, u2), epsilon(v2)) * dx(O2)
# Add Nitsche terms
aO1 += -0.5*inner(1/gamN*avg(D(E1, nu, u1)*n),
avg(D(E1, nu, v1)*n))*dS(interface)
aO2 += -0.5*inner(1/gamN*avg(D(E2, nu, u2)*n),
avg(D(E2, nu, v2)*n))*dS(interface)
aO1 += 0.5*inner(1/gamN*pos_f(Pin(u1, n, E1, nu)),
Pin(v1, n, E1, nu))*dS(interface)
aO2 += 0.5*inner(1/gamN*pos_f(Pin(u2, n, E2, nu)),
Pin(v2, n, E2, nu))*dS(interface)
# Coulomb friction law: - Fric*|sig_n(u)|* u_t/|u_t|
fric1 = 1E-10
fric2 = 1E-10
aO1 += 0.5 * inner(1/gamN*Pit_fric(u1, n, E1, nu, fric1),
Pit(v1, n, E1, nu))*dS(interface)
aO2 += 0.5 * inner(1/gamN*Pit_fric(u2, n, E2, nu, fric2),
Pit(v2, n, E2, nu))*dS(interface)
# Define linear form
loadf = Constant((10, 0))
LO1 = inner(loadf, v1) * ds(bright)
LO2 = inner(loadf, v2) * ds(tright)
F = [aO1 - LO1, aO2 - LO2]
J = block_derivative(F, sol, dsol)
# Solve
problem = BlockNonlinearProblem(F, sol, bcs, J)
solver = BlockPETScSNESSolver(problem)
solver.parameters.update(snes_solver_parameters["snes_solver"])
solver.solve()
u2h, u1h = block_split(sol)
Can anyone please could help me to solve this problem. I appreciate your answers.
