Multi-node calculation with mpi on cluster
Hi, I am recently trying to run a script on the cluster and distribute the job into multiple nodes, because I have a large model to calculate, which require large amount of memory for the solution. Just for test, I ran the helmholtz equation code below on the cluster with mpi:
from dolfinx import default_scalar_type,mesh
from dolfinx.fem.petsc import assemble_vector
import scifem
import dolfinx.fem as fem
from dolfinx.fem import functionspace, Function, locate_dofs_geometrical
from dolfinx.mesh import CellType, GhostMode, locate_entities
def left_part(x):
    return (x[0]<0.3)
def runhelmholtz(omega,c,n):
    # Wavenumber
    omega0 = omega
    c0 = c
    k0 = omega0/c0
    # Approximation space polynomial degree
    deg = 1
    # Number of elements in each direction of the mesh
    n_elem = n
    domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, n_elem, n_elem)
    V = dolfinx.fem.functionspace(domain, ("Lagrange", deg))
    V_ele = functionspace(domain, ("DG", 0))
    u_c = dolfinx.fem.Function(V)
    k = fem.Function(V_ele)
    cells_l = locate_entities(domain, domain.topology.dim, left_part)
    num_cells = domain.topology.index_map(2).size_local
    cell_indices = list(range(num_cells))
    cells_r = list(set(cell_indices) - set(cells_l))
    k.x.array[cells_l] = np.full_like(cells_l, k0*(1+0.005j), dtype=default_scalar_type)
    k.x.array[cells_r] = np.full_like(cells_r, k0/2*(1+0.005j), dtype=default_scalar_type)
    f = dolfinx.fem.Function(V)
    gamma=1
    geom_dtype = domain.geometry.x.dtype
    points = np.array([0.5, 0.2, 0], dtype=geom_dtype)
    point_source = scifem.PointSource(V, points, magnitude=gamma)
    point_source.apply_to_vector(f)
    a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx - k ** 2 * ufl.inner(u, v) * ufl.dx
    L = 1/c0**2*ufl.inner(f, v) * ufl.dx
    domain.topology.create_connectivity(domain.topology.dim - 1, domain.topology.dim)
    boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
    boundary_dofs = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets)
    # exclude the top dofs
    def top_free(x):
        return np.isclose(x[1],1.0)
    def fix(x):
        return np.logical_and(np.isclose(x[0],0.0),np.isclose(x[1],0.0))
    edge_top = mesh.locate_entities_boundary(domain,fdim,top_free)
    dof_fix = np.array(locate_dofs_geometrical(V, fix)).astype(np.int32)
    top_dofs = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim - 1, edge_top)
    boundary_minus_top = np.setdiff1d(boundary_dofs, top_dofs)
    bc = dolfinx.fem.dirichletbc(u_c, boundary_minus_top)
    bcs = [bc]
    amat = fem.petsc.assemble_matrix(fem.form(a), bcs=bcs)
    amat.assemble()
    Lmat = fem.petsc.assemble_vector(fem.form(L))
    fem.petsc.apply_lifting(Lmat, [fem.form(a)], bcs=[bcs])
    Lmat.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    fem.petsc.set_bc(Lmat, bcs)
    Lmat.assemble()
    ksp = PETSc.KSP().create(domain.comm)
    ksp.setOperators(amat)
    def monitor(ksp, it, rnorm):
        print(f"iteration: {it} rnorm: {rnorm:.3e}")
    ksp.setMonitor(monitor)
    opts = PETSc.Options()
    ksp.setOptionsPrefix("0_")
    # direct solver
    # iterative solver
    # opts[f"{option_prefix}ksp_type"] = "gmres"
    # opts[f"{option_prefix}pc_type"] = "bjacobi"
    # opts[f"{option_prefix}sub_pc_type"] = "ilu"
    # opts[f"{option_prefix}ksp_max_it"] = 100
    ksp.setFromOptions()
    uh = fem.Function(V)
    ksp.solve(Lmat,uh.x.petsc_vec)
    # # Write both solutions for comparison
    with VTXWriter(domain.comm, "uh_dirichlet_mpi.bp", [uh], engine="BP4") as vtx:
        vtx.write(0.0)
omega=100*np.pi
c=2
runhelmholtz(omega,c,300)
And the sh file I used for submitting this job is:
#!/bin/bash
#SBATCH --nodes=2
#SBATCH --job-name=helmholtz_mpi4
#SBATCH --ntasks-per-node=4
#SBATCH -p common --account=xx
#SBATCH --output=output/%x_%j.out   # Output file in the 'output' directory
#SBATCH --error=output/%x_%j.err    # Error file in the 'output' directory
#SBATCH --mail-type=END,FAIL
#SBATCH --mail-user=xx.edu
source xx/miniconda3/etc/profile.d/conda.sh
conda activate fenicsx-complex-ssh
cd /hpc/group/xx/mpi_test
mpirun -np 8 python helmholtz_mpi.py -log_view
conda deactivate
It turns out that this will hang when it is solving the equation. However, when I change mpirun -np 8 into mpirun -np 4, it works, which means the calculation is done on only one node. Does anybody know what the issue is? I will really appreciate it if you can provide some advice on how to run the job on multi-node. Many thanks!
Hello, I have the same problem but I haven’t found any way to solve it. Don’t hesitate to share your solution if you find one !
Nothing obvious in your example would indicate that it should fail when run with more than one node.
Unfortunately debugging this could be a tedious process.
You indicate your code “hangs” at the equation solve stage. Have you tried a solver other than MUMPS? I can’t remember which direct factorisation packages support complex numbers.
Hi nate, thanks for the reply! Yes I tried other solvers, such as sluperlu_dist, klu, and simply petsc. All of them hanged. I also tried using the iterative solver using the code below: opts[f"{option_prefix}ksp_type"] = "gmres" opts[f"{option_prefix}pc_type"] = "bjacobi" opts[f"{option_prefix}sub_pc_type"] = "ilu" opts[f"{option_prefix}ksp_max_it"] = 100 . The iterative solver also hangs, unfortunately.
Hi ruhsnay, I am sorry that I haven’t found a solution to this yet. Though, I have seen something that might be useful. This link talks about a bug on moose, which is a very similar issue: Parallel computing hung when using Mortar Constraint · Issue #23796 · idaholab/moose · GitHub. Also, I found that in the fenicsx-pctools documents, they provided an example to run the script on multi-node. See this: FEniCSx Preconditioning Tools, at the “examples” folder. Hope this can help.
Hi there, just want to share an update on this issue. I will be happy if anybody figure out the real issue. But I find out that if I use the iterative solver and configure as:
    # iterative solver
    opts[f"{option_prefix}pc_type"] = "jacobi"
This surprisingly will not hang for multi-node calculation.
Hi, finally, I found the solution to this: use the cluster MPI. It seems that there are many issues for multi-node calculation with petsc if we use the conda MPI. Therefore, what I have done is to build dolfinx from source through spack. For those who are interested, this is how the spack env file looks like in my build:
openmpi-4.1.6 is our cluster MPI, of course you will need to modify it on your own cluster. After modifying this, use spack concretize -f to configure and spack install to install. It runs well with this job submitting file:
#!/bin/bash
#SBATCH --nodes=2
module purge
module load OpenMPI/4.1.6
source x/spack/share/spack/setup-env.sh
spack env activate spack-dolfinx-test
mpirun -n $SLURM_NTASKS python helmholtz_mpi.py
As stated by this post, using conda on HPC clusters is not adviced, as you will likely get an MPI mismatch between the binaries on conda and the one installed on the cluster.
Spack is always adviced as the go-to method on clusters.
having the same issue with the following my code. Here is the sh file.. Any guess what is the issue?
#!/bin/bash
#SBATCH --job-name=gather
#SBATCH --nodes=2
#SBATCH --ntasks-per-node=20
#SBATCH --cpus-per-task=1
#SBATCH --exclusive          # Gets whole nodes without sharing
#SBATCH --switches=1               # Ensure all nodes start simultaneously
#SBATCH --time=14-00:00:00
#SBATCH --partition=normal
#SBATCH --mail-type=ALL
#SBATCH --mail-user=xx@yy.edu
#SBATCH --account=xyz
module load python-3.9.6-gcc-8.4.1-2yf35k6
echo "Job $SLURM_JOB_ID running on SLURM NODELIST: $SLURM_NODELIST"
# Calculate total MPI processes (nodes * tasks-per-node)
TOTAL_PROCS=$((SLURM_NNODES * SLURM_NTASKS_PER_NODE))
# Run the simulation
singularity exec -e /path/fenics.simg \
  mpirun -np $TOTAL_PROCS python3 ./test_combined_gather.py > output_test_gather
Hi kamaya, have you tried using spack to build fenicsx, specifying the cluster MPI? You can see my solution above
