Crank–Nicolson method in linear elasticity
I would like to use the Crank-Nicolson method to simulate the dynamics of a linear elastic system. As an example problem I set up a simple cantilever structure. In a first step I obtain the deflection for a static point load applied to the free end of the cantilver. The solution to the static part should then serve as the initial condition for the dynamic problem which is the mechanical oscillation from this deflection in the absence of any load.
To obtain the time-dependent solution I rewrite the initial PDE \nabla \cdot \pmb{\sigma} = \rho \frac{\partial^2 \mathbf{u}}{\partial t^2} as a system of two coupled equations ( \mathbf{u}_1 = \mathbf{u}, \mathbf{u}_2 = \dot{\mathbf{u}} ) and derive the corresponding linear forms.
However, I am not sure if I implemented the forms as I am supossed to. To solve this problem I introduce an mixed function space with
V1 = fe.VectorElement('Lagrange', mesh.ufl_cell(), 3)
V2 = fe.VectorElement('Lagrange', mesh.ufl_cell(), 3)
Vt = fe.FunctionSpace(mesh, V1 * V2)
Just executing this command takes a couple of seconds. Even longer takes the assembly of the system using
A, b = fe.assemble_system(a, L, [bc1, bc2])
The final step solution step does not converge and I obtain after a long computation the error message
RuntimeError:
*** Error:   Unable to successfully call PETSc function 'KSPSolve'.
*** Reason:  PETSc error code is: 76 (Error in external library).
*** Where:   This error was encountered inside /tmp/dolfin/dolfin/la/PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
You find the complete code of my example below. This code only computes the first time-step of the time-dependent solution.
Is my problem related to an unproper definition of the function spaces or am my forms not correctly defined? I would be very happy if someone could point me in the right direction. Thanks in advance.
import fenics as fe
# Geometry parameters
l = 100e-6
h = 0.1 * l
w = 0.1 * l
# Mesh parameters
nl = 50
nw = 5
nh = 5
# Material parameters
E = 130e9
nu = 0.22
rho = 2330 # density kg/m**3
# Lame parameters
mu = E / (2 * (1 + nu))
lmbda = E * nu / ((1 + nu) * (1 - 2 * nu))
# Load parameters
f_ = fe.Constant((0, 0, 0))
delta = fe.PointSource(V.sub(2), fe.Point(l, w / 2, h / 2), -1)
mesh = fe.BoxMesh(fe.Point(0, 0, 0), fe.Point(l, w, h), nl, nw, nh)
V = fe.VectorFunctionSpace(mesh, 'Lagrange', 1)
def boundary(x, on_boundary):
    return on_boundary and fe.near(x[0], 0)
bc = fe.DirichletBC(V, fe.Constant((0, 0, 0)), boundary)
    return 0.5 * (fe.grad(u) + fe.grad(u).T)
def sigma(u):
    return 2 * mu * epsilon(u) + lmbda * (fe.div(u)) * fe.Identity(3)
u = fe.TrialFunction(V)
v = fe.TestFunction(V)
a = fe.inner(sigma(u), epsilon(v)) * fe.dx
L = fe.inner(f_, v) * fe.dx
A, b = fe.assemble_system(a, L, bc)
delta.apply(b)
uh = fe.Function(V)
fe.solve(A, uh.vector(), b)
uh.rename('displacement', 'displacement')
f = fe.File('static.pvd')
f << uh
# ## Time-Dependent Problem
dt = 0.0001
bc1 = fe.DirichletBC(Vt.sub(0), fe.Constant((0, 0, 0)), boundary)
bc2 = fe.DirichletBC(Vt.sub(1), fe.Constant((0, 0, 0)), boundary)
v1, v2 = fe.TestFunctions(Vt)
u1, u2 = fe.TrialFunctions(Vt)
u10, u20 = fe.Function(Vt).split()
u10.assign(uh)
a1 = fe.inner(u1, v1) * fe.dx - fe.Constant(0.5 * dt) * fe.inner(u2, v1) * fe.dx
a2 = fe.inner(u2, v2) * fe.dx - fe.Constant(0.5 * dt / rho) * fe.inner(sigma(u1), epsilon(v2)) * fe.dx
a = a1 + a2
L1 = fe.inner(u10, v1) * fe.dx + fe.Constant(0.5 * dt) * fe.inner(u20, v1) * fe.dx
L2 = fe.inner(u20, v2) * fe.dx + fe.Constant(0.5 * dt / rho) * fe.inner(sigma(u10), epsilon(v2)) * fe.dx
L = L1 + L2
uht = fe.Function(Vt)
fe.solve(a==L, uht, [bc1, bc2])
You don’t need to use a mixed space; you can formally eliminate the velocity unknowns at the current time level, and solve a problem in terms of displacement unknowns only. See my response to an older question here, which provides an implementation of the scalar wave equation:
