I am using a mesh generated by FEniCSx using the create_box function. When I use 2nd order elements in the ufl I get the following error.
UFL mesh and CoordinateElement do not match.
I have looked into the source code and I have seen that the create_box function initializes a CoordinateElement with degree 1 which is the reason for the error. I have tried copying the function to modify it to work with second order polynomials however I would like to know if there are there any other quick work arounds for this?
If you are referring to DOLFINx: dolfinx::mesh Namespace Reference
this function creates a mesh with a first order coordinate element, i.e. the element sent into mesh in the ufl file should be
