Hi, everyone.
I have tried to create a custom Degree 2 vector Lagrange on a triangle and use it for a 2D linear elastic problem.
code
import basix
from basix import CellType, MapType, PolynomialType, PolysetType, SobolevSpace
from ufl import (Identity, TestFunction, TrialFunction,
dx, inner, grad, sym, tr)
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, set_bc
# Set coefficients for the basis functions
wcoeffs = np.zeros((12, 12))
wcoeffs[0, 0] = 1 # (1,0)
wcoeffs[1, 6] = 1 # (0,1)
wcoeffs[2, 3] = 1 # (x,0)
wcoeffs[3, 9] = 1 # (0,x)
wcoeffs[4, 4] = 1 # (x^2,0)
wcoeffs[5, 10] = 1 # (0,x^2)
wcoeffs[6, 1] = 1 # (y,0)
wcoeffs[7, 7] = 1 # (0,y)
wcoeffs[8, 5] = 1 # (xy,0)
wcoeffs[9, 11] = 1 # (0,xy)
wcoeffs[10, 2] = 1 # (y^2,0)
wcoeffs[11, 8] = 1 # (0,y^2)
# Interpolation points
# DOFs are point evaluations at vertices: (0,0), (1,0), (0,1)
# and edge midpoints: (0.5,0), (0.5,0.5), (0,0.5) for x- and y-components.
x = [[], [], [], []]
# Vertices
x[0].append(np.array([[0.0, 0.0]])) # Vertex 0
x[0].append(np.array([[1.0, 0.0]])) # Vertex 1
x[0].append(np.array([[0.0, 1.0]])) # Vertex 2
# Edge midpoints
x[1].append(np.array([[0.5, 0.0]])) # Edge 0: midpoint between (0,0) and (1,0)
x[1].append(np.array([[0.5, 0.5]])) # Edge 1: midpoint between (1,0) and (0,1)
x[1].append(np.array([[0.0, 0.5]])) # Edge 2: midpoint between (0,1) and (0,0)
# Empty for cell interior
x[2].append(np.zeros((0, 2)))
# Interpolation matrices
# Each point (vertex or edge midpoint) has two DOFs: x-component (v . (1,0)) and y-component (v . (0,1)).
# Shape per point: (2, 2, 1, 1) for 2 DOFs, value size 2, 1 point, 0 derivatives.
M = [[], [], [], []]
for _ in range(3): # One matrix per vertex
mat = np.zeros((2, 2, 1, 1))
mat[0, :, 0, 0] = [1.0, 0.0] # x-component: v . (1,0)
mat[1, :, 0, 0] = [0.0, 1.0] # y-component: v . (0,1)
M[0].append(mat)
for _ in range(3): # One matrix per edge midpoint
M[1].append(mat)
M[2].append(np.zeros((0, 2, 0, 1))) # Empty for cell interior
# Create the custom element
basix_element = basix.create_custom_element(
CellType.triangle, # Cell type
[2], # Value shape (vector in 2D)
wcoeffs, # Polynomial coefficients
x, # Interpolation points
M, # Interpolation matrices
0, # Number of derivatives (point evaluations, so 0)
MapType.identity, # Identity map for Lagrange elements
SobolevSpace.H1, # H^1-conforming
False, # Not discontinuous
2, # Embedded subdegree (contains all degree 2 polynomials)
2, # Embedded superdegree (highest degree is 2)
PolysetType.standard, # Standard polynomial set
ufl_el = basix.ufl.wrap_element(basix_element)
# Create mesh
L = 25.0
H = 1.0
Nx = 40
Ny = 2
msh = mesh.create_rectangle(
MPI.COMM_WORLD,
[[0.0, 0.0], [L, H]],
[Nx, Ny],
mesh.CellType.triangle
#ufl_element = element(basix_element)
V = fem.functionspace(msh, ufl_el)
# Define material properties
E = 1e5
nu = 0.3
model = "plane_stress"
mu = E / 2 / (1 + nu)
lmbda = E * nu /( (1 + nu) *(1 - 2 * nu))
if model == "plane_stress":
lmbda = 2 * mu * lmbda / (lmbda + 2 * mu)
# Define strain and stress functions
def eps(v):
return sym(grad(v))
def sigma(v):
return lmbda * tr(eps(v)) * Identity(2) + 2.0 * mu * eps(v)
# Define body force
rho_g = 1e-3
f = fem.Constant(msh, (0.0, -rho_g))
a = inner(sigma(u), eps(v)) * dx
L = inner(f, v) * dx
# Define boundary condition
def left(x):
return np.isclose(x[0], 0.0)
fdim = msh.topology.dim - 1
left_facets = mesh.locate_entities_boundary(msh, fdim, left)
left_dofs = fem.locate_dofs_topological(V, fdim, left_facets)
zero = fem.Function(V)
zero.x.array[:] = 0.0
bc = fem.dirichletbc(zero, left_dofs)
# Solve problem
uh = problem.solve()
uh.name = "Displacement"
def project(e, target_func, bcs=[]):
"""Project UFL expression.
Note
This method solves a linear system (using KSP defaults).
# Ensure we have a mesh and attach to measure
V = target_func.function_space
dx = ufl.dx(V.mesh)
# Define variational problem for projection
w = ufl.TestFunction(V)
v = ufl.TrialFunction(V)
a = dolfinx.fem.form(ufl.inner(v, w) * dx)
L = dolfinx.fem.form(ufl.inner(e, w) * dx)
# Assemble linear system
A = assemble_matrix(a, bcs)
b = assemble_vector(L)
apply_lifting(b, [a], [bcs])
set_bc(b, bcs)
# Solve linear system
solver = PETSc.KSP().create(A.getComm())
solver.setType("bcgs")
solver.getPC().setType("bjacobi")
solver.rtol = 1.0e-05
solver.setOperators(A)
solver.solve(b, target_func.x.petsc_vec)
assert solver.reason > 0
target_func.x.scatter_forward()
# Destroy PETSc linear algebra objects and solver
solver.destroy()
A.destroy()
b.destroy()
V_vector = fem.functionspace(msh, ("DG", 1, (2,)))
displacement = fem.Function(V_vector)
project(uh, displacement)
print("Solution array contains NaN:", np.any(np.isnan(uh.x.array)))
print("Solution array contains inf:", np.any(np.isinf(uh.x.array)))
print("Solution array max/min:", np.max(np.abs(uh.x.array)), np.min(np.abs(uh.x.array)))
# from dolfinx.io import VTXWriter
# outputfoldername = "results_2D_custom_triangle_p1/"
# u_bp = VTXWriter(MPI.COMM_WORLD, f"{outputfoldername}displacement.bp", [displacement], engine="BP4")
# u_bp.write(0.0)
# u_bp.close()
print("Maximum displacement:", np.max(np.linalg.norm(uh.x.array.reshape(-1, 2), axis=1)))
output:
AssertionError Traceback (most recent call last)
File ~/FEniCSx/unbenannt2.py:209
207 V_vector = fem.functionspace(msh, ("DG", 1, (2,)))
208 displacement = fem.Function(V_vector)
--> 209 project(uh, displacement)
210 print("Solution array contains NaN:", np.any(np.isnan(uh.x.array)))
211 print("Solution array contains inf:", np.any(np.isinf(uh.x.array)))
File ~/FEniCSx/unbenannt2.py:198, in project(e, target_func, bcs)
196 solver.setOperators(A)
197 solver.solve(b, target_func.x.petsc_vec)
--> 198 assert solver.reason > 0
199 target_func.x.scatter_forward()
202 # Destroy PETSc linear algebra objects and solver
AssertionError:
When i tried to comment the projection and run the code to check the displacement value, i got the displacement value as inf.
The code ran fine when tried with custom degree 1 vector lagrange.
any suggestions would be appreciated.
Thanks!
