hello, I am writing topology optimization code and want to collect data using DataFrame but the result as shown in DataFrame is only the data in the last iteration , how can DataFrame collect the result in every iteration.
import pandas as pd
import dolfinx.nls.petsc
import dolfinx.fem.petsc
import pyvista
from dolfinx.mesh import CellType, create_rectangle
from dolfinx import fem, nls, io, default_scalar_type
from ufl import Measure, inner, grad, div, TestFunction, TrialFunction, adjoint, derivative, SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx
from dolfinx.fem import (Constant, Function, FunctionSpace,
assemble_scalar, dirichletbc, form, locate_dofs_geometrical)
import pyvista as pv
import time
#Library for ML
import seaborn as sns
import tensorflow as tf
import tensorflow.compat.v1 as tf
from sklearn.model_selection import train_test_split
from tensorflow.keras.layers import Dense
from tensorflow.keras.models import Sequential
from sklearn.preprocessing import LabelEncoder
import ast
start_time = time.time()
#Parameter
D0 = 1;
k0 = -1.0;
eta = 2.0;
gamma = 2.0;
alpha = 1e-16
Rfl = 0.0018
# mesh and function space
mesh = create_rectangle(MPI.COMM_WORLD, [[0, 0], [1, 1]], [100, 100], CellType.quadrilateral)
V = fem.FunctionSpace(mesh, ("CG", 1))
c = fem.Function(V)
phi = TestFunction(V)
lambdh = fem.Function(V)
lamda_real,sen_real,eps_real,c_real = fem.Function(V),fem.Function(V),fem.Function(V),fem.Function(V)
# The eps is the design variable
eps = fem.Function(V)
eps.x.array[:] = 0.5
data_sen = []
data_lam = []
data_eps = []
data_c = []
data_ite = []
loop = 5
for i in range(loop):
eps_real = eps.x.array.real
data_eps.append(eps_real)
df_eps = pd.DataFrame(data_eps)
df_eps_final = pd.DataFrame(df_eps)
print("iteration ",i)
print("eps",eps_real)
#boundary_markers = FacetFunction('size_t',mesh)
ds = Measure('ds')
dx = Measure("dx") ##integration over different parts of the domain
x = SpatialCoordinate(mesh)
gu = Constant(mesh, default_scalar_type(0)) ##Neauman = 0
# Residual of the variational form of Poisson problem
R = inner(D0*eps**eta*grad(c), grad(phi))*dx - inner(k0*(1-eps)**gamma*c,phi)*dx - inner(gu,phi) *ds # " - inner(gu,phi) *ds " is boundary neauman
##Dirichlet
def on_boundary(x):
return np.isclose(x[0], 0)
dofs_L = fem.locate_dofs_geometrical(V , on_boundary)
bc_L = fem.dirichletbc(default_scalar_type(1), dofs_L, V) ##Dirichlet = 1
bcs = [bc_L]
#Forming and solving the linear system
problem_u = fem.petsc.NonlinearProblem(R, c, bcs)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD,problem_u)
solver.rtol = 1e-16
solver.solve(c)
#how big is the solution
J = -ufl.inner((k0*(1-eps)**gamma),c)*dx ##Objective function
J_form = fem.form(J)
J_old = fem.assemble_scalar(J_form)
#solve the adjoint vector
lhs = ufl.adjoint(ufl.derivative(R,c))
rhs = -ufl.derivative(J,c)
def on_boundary_1(x):
dofs_L_adj = fem.locate_dofs_geometrical(V , on_boundary_1)
bc_L_adj = fem.dirichletbc(default_scalar_type(0), dofs_L_adj, V) ##Dirichlet = 1
bcs_adjoint = [bc_L_adj]
#Adjective problem
problem_adj = dolfinx.fem.petsc.LinearProblem(lhs, rhs, bcs_adjoint, petsc_options={"ksp_type": "preonly", "pc_type": "lu","pc_factor_mat_solver_type": "mumps"})
#solve adj problem in lamda (lamda is adjoint variable)
lamda = problem_adj.solve()
dJde = dolfinx.fem.Expression(k0*gamma*((1-eps)**(gamma-1))*c+dot(D0*eta*(eps**(eta-1))*grad(c),grad(lamda))+inner(k0*gamma*((1-eps)**(gamma-1))*c,lamda), V.element.interpolation_points())
sens = fem.Function(V)
sens.interpolate(dJde)
# steepest descent with constant beta as stepsize
beta = 0.02
delta_eps = beta*sens
eps_new = dolfinx.fem.Expression(eps + delta_eps, V.element.interpolation_points())
# determine new value for the design variables
eps.interpolate(eps_new)
eps1 = fem.Function(V)
phi_3 = TestFunction(V)
filter = inner((Rfl**2)*grad(eps1), grad(phi_3))*dx + inner(eps1,phi_3)*dx - inner(eps,phi_3)*dx
filter_eps = fem.petsc.NonlinearProblem(filter, eps1)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD,filter_eps)
solver.rtol = 1e-16
solver.solve(eps1)
eps.interpolate(eps1)
eps.x.array[eps.x.array > 1] = 1
eps.x.array[eps.x.array < 0] = 0
import math
lamda_real,sen_real,eps_real,c_real = lamda.x.array.real, sens.x.array.real, eps.x.array.real, c.x.array.real
###collect data###
data_c.append(c_real)
df_c = pd.DataFrame(data_c)
df_c_final = pd.DataFrame(df_c)
print("c",c_real)
print(" ")
#data = eps
#df = pd.DataFrame(data)
end_time = time.time()
execution_time = end_time - start_time
print("Execution time:", execution_time, "seconds")
the result from printed c and eps
iteration 0
eps [0.5 0.5 0.5 ... 0.5 0.5 0.5]
c [1. 1. 0.99243388 ... 0.64808462 0.64805222 0.64805222]
iteration 1
eps [0.49144952 0.49144952 0.49145228 ... 0.49159995 0.4916007 0.4916007 ]
c [1. 1. 0.99202673 ... 0.63116817 0.63113441 0.63113441]
iteration 2
eps [0.4836042 0.4836042 0.48359976 ... 0.48349888 0.48350033 0.48350033]
c [1. 1. 0.99163397 ... 0.61468617 0.61465109 0.61465109]
iteration 3
eps [0.47648518 0.47648518 0.47646429 ... 0.47569298 0.47569508 0.47569508]
c [1. 1. 0.99126011 ... 0.59872791 0.59869154 0.59869154]
iteration 4
eps [0.47009843 0.47009843 0.47005283 ... 0.46817523 0.46817795 0.46817795]
c [1. 1. 0.990909 ... 0.58336524 0.5833276 0.5833276 ]
show dataframe collecting ‘c’
show dataframe collecting ‘eps’
