Define a vector space to solve a diffusion advection diffusion equation
Hello everyone! I want to solve a PDE like:
\partial_t \rho-\nabla \cdot(D \nabla \rho)+\nabla \cdot( I(x) \rho)=0.
Here I is a vector depend on x.
Suppose now I define a function space like:
V = fem.functionspace(domain, ("Lagrange", k))
I wonder how to define a vector function space for I(x) in the weak form as I know the weak form is -\rho I\cdot \nabla v with zero Neumann boundary condition.
You can do this with ufl.SpatialCoordinate and ufl.as_vector, i.e.
def I_func(x):
     return (x[0], 2*x[1])
I = ufl.as_vector(I_func(x))
Thanks for your kindly reply! However, I don’t want to use ufl.SpatialCoordinate to define the vector functions. I notice that you used to publish a post for the usage of Expression in Dolfinx,
This is the way I define a function used your way:
class K():
    def __call__(self, x):
    #    return x[1]
        return np.exp(0*x[1])+np.exp(-((x[1]-100)/100)**2)*np.exp(-((x[0]-300)/100)**2)
k = fem.Function(V)
k.interpolate(K_0_true())
so I wonder if it is possible to define a vector functions as the same as above for a vector function like (\exp(x[0]), \exp(x[1])+\sin(x[0]))?
Yes,
you can do that.
Just return a tuple
    return (np.exp(x[0]), np.exp(x[1]) + np.sin(x[0]))
I try to write something like:
class I_func():
beta = ufl.as_vector(I_func())
However, it fails. The error showed is that “raise ValueError(“Expecting nested list or tuple of Exprs.”)”.
You are now mixing methods. If you don’t want to use spatial coordinate you need to interpolate into an appropriate function vector function space.
What is the reasoning behind not wanting to use spatial coordinate ?
I think I asked a silly question. I only need to change np into ufl to obtain a function. However, if I want to define a function which do not have explicit form on spatial coordinate, how to define an appropriate function vector space? For example, I have a matrix A representing values of a vector function on the grids and I want to define this function into my weak form.
The question is quite vague.
How do you define the matrix A with respect to your grid. There either has to be a spatial relation, or an implicit spatial relation by the index in A.
A minimal example of what you want to achieve would be beneficial for understanding your problem.
I will try to give an example of the vector functions.
Suppose the space domain \Omega is a unit square with gird N_x*N_y and I have the values of a vector function f=(a,b) on these grids, which are two matric A_1=[a_{i,j}], A_2=[b_{i,j}], 1\leq i\leq N_x, 1\leq j\leq N_y. Now I create a function space like:
domain = mesh.create_unit_square(MPI.COMM_WORLD, N_x, N_y, mesh.CellType.triangle)
V = fem.functionspace(domain, ("Lagrange", 1))
Then how to pass these values to a vector function in the integral form?
I think there are various ways you could do this.
  1. is to invert the map in: Reordering nodal values in accordance with meshgrid created using numpy - #3 by dokken
    which is similar to
  2. Assigning values to function: order issues - #4 by dokken
  3. Another one is to use an interpolator: Mapping 2D numpy array into dolfinx function - #4 by dokken
Thanks for your help! I still have some questions. The first is that if I have a function space V and u_1, u_2 are two functions in V, how to define a vector function U=(u_1,u_2) so that I can compute the inner product of <U, grad(v)>, where v is a test function. The second is that I want to define a vector function like:
def I_func(x):
     if x[0]**2+x[1]**2<0.5:
          return (0,0)
How to correctly write a such function?
Use ufl.as_vector as below.
For the second question, use ufl.conditional
http://jsdokken.com/FEniCS-workshop/src/form_compilation.html#conditional-values
Thanks for your reply! For the use of ufl.conditional, I still have a question. If I want to define a function u in a function sapce V, such that u has the same property, such as u(x)=0 when x>1 and u(x)=1 when x<1, how to define such a function?
