Define different materials via the sub domain
hi all,
im trying to set different material properties on my model and for some reason in the view of paraview it does not seems to be working, i dont see my model colored in 2 different colors
when i tried different subdomain its working as expected
for exp
import os
import fenics as fe
from ffc.fiatinterface import create_quadrature as cquad
import dolfin
#rest of code
class Omega_0(SubDomain):
        return x[0] <= 0.5 + DOLFIN_EPS
class Omega_1(SubDomain):
        return x[0] > 0.5 - DOLFIN_EPS
but when i try this subdomain config its not working
E1, E2, nu = 30e6, 3e6, 0.49
length, width, height = 1.0, 0.2, 0.2  # Dimensions of the rod
num_elements = 40  # Number of elements along each dimension
mesh = BoxMesh(Point(0, 0, 0), Point(length, width, height), num_elements, 4, 4)
#creating subtomains and boundaty conditions
tol = 1E-14
        return np.sqrt(((x[1] - 0.1)*(x[1] - 0.1)) + ((x[2] - 0.1)*(x[2] - 0.1))) <= 0.05
        return np.sqrt(((x[1] - 0.1)*(x[1] - 0.1)) + ((x[2] - 0.1)*(x[2] - 0.1))) > 0.05
subdomain_0 = Omega_0()
subdomain_1 = Omega_1()
materials = MeshFunction('size_t', mesh, mesh.topology().dim())
materials.set_all(0)
subdomain_0.mark(materials, 1)
subdomain_1.mark(materials, 2)
boundary_parts = MeshFunction('size_t', mesh, mesh.topology().dim() - 1)
left = AutoSubDomain(lambda x: near(x[0], 0))
right = AutoSubDomain(lambda x: near(x[0], 1))
up = AutoSubDomain(lambda x: near(x[2], 0.2))
down = AutoSubDomain(lambda x: near(x[2], 0))
front = AutoSubDomain(lambda x: near(x[1], 0))
back = AutoSubDomain(lambda x: near(x[1], 0.2))
left.mark(boundary_parts, 1)
right.mark(boundary_parts, 2)
up.mark(boundary_parts, 5)
down.mark(boundary_parts, 6)
front.mark(boundary_parts, 3)
back.mark(boundary_parts, 4)
bc1 = DirichletBC(V.sub(0), Constant(0), boundary_parts, 1)
bc3 = DirichletBC(V.sub(1), Constant(0), boundary_parts, 3)
bc5 = DirichletBC(V.sub(2), Constant(0), boundary_parts, 5)
bc6 = DirichletBC(V.sub(2), Constant(0), boundary_parts, 6)
tDirBC = Expression(('1.0*time_'), time_=0.0, degree=0)
tDirBC4 = Expression(('((1/(time_+1))-1)*0.2'), time_=0.0, degree=0)
bc2 = DirichletBC(V.sub(0), tDirBC, boundary_parts, 2)
bc4 = DirichletBC(V.sub(1), tDirBC4, boundary_parts, 4)
bcs = [bc1, bc2, bc3, bc4, bc5, bc6]
subdomain_ids = [2, 4]
ds = Measure("ds", subdomain_data=boundary_parts, subdomain_id=(2,4))
ds = ds(degree=4)
#creating material constants
class K(fe.UserExpression):
    def __init__(self, materials, k_0, k_1, **kwargs):
        super().__init__(**kwargs)
        self.materials = materials
        self.k_0 = k_0
        self.k_1 = k_1
        if self.materials[cell.index] == 1:
            values[0] = self.k_0
            values[0] = self.k_1
    def value_shape(self):
        return ()
E_global = K(materials, E1, E2, degree=0)
DG = FunctionSpace(mesh, "DG", 2)
materials_function = Function(DG)
E_values = [E1, E2]
materials_function = project(E_global, DG)
MU1, LAMBDA1 = Constant(E1 / (2 * (1 + nu))), Constant(E1 * nu / ((1 + nu) * (1 - 2 * nu)))
MU2, LAMBDA2 = Constant(E2 / (2 * (1 + nu))), Constant(E2 * nu / ((1 + nu) * (1 - 2 * nu)))
class MUMU(fe.UserExpression):
    def __init__(self, materials, MU_0, MU_1, **kwargs):
        self.MU_0 = MU_0
        self.MU_1 = MU_1
            values[0] = self.MU_0
            values[0] = self.MU_1
        return ()
MU = MUMU(materials, MU1, MU2, degree=0)
class lamabada(fe.UserExpression):
    def __init__(self, materials, lam_0, lam_1, **kwargs):
        self.lam_0 = lam_0
        self.lam_1 = lam_1
            values[0] = self.lam_0
            values[0] = self.lam_1
        return ()
LAMBDA = lamabada(materials, LAMBDA1, LAMBDA2, degree=0)
# rest of the code
File("Materials.pvd") << materials
vtkfile_subdomains = File('subdomains.pvd')
vtkfile_subdomains << materials
#writing into files in order to check it in paraview
materials_function.rename("materials", "")
u.rename("Displacement Vector", "")
beam_deflection_file = fe.XDMFFile("beam_deflection.xdmf")
beam_deflection_file.parameters["flush_output"] = True
beam_deflection_file.parameters["functions_share_mesh"] = True
beam_deflection_file.write(u, 0.0)
beam_deflection_file.write(materials_function, 0.0)
would appreciate to know if you have any idea why
this is what i see
My understanding is that you are trying to define a circle/sphere around (x,y) = (0.1, 0.1). You may need to cut the visualization in paraview with a clip to see that.
I’ve already told you in the past to make sure to include all imports in your snippet, so that people who answer you can easily do a copy and paste. Last time I fixed that for you, this time I won’t, hence I won’t be trying to run your code (because it is not runnable). Please try to remember to do this: it’s a simple task, but you must put the others in the best position possible to help you.
added the imports, sorry for that
i tried the cute and as you can see still no change
It seems to me that you are trying to identify a circle in the cross section of the beam, but the mesh of each cross section is so coarse that you’ll never identify the circle.
The following code
mesh = BoxMesh(Point(0, 0, 0), Point(length, width, height), num_elements, num_elements, num_elements)
materials.set_all(2)
# rest of the code
does produce two subdomains. Note that:
  • I had to increase the number of elements in the cross-section
  • there is no need to have a SubDomain for \Omega_0, and then negate that expression to identify \Omega_1. Simply set the default value to 2 to say that all cells initially belong to \Omega_1, and then identify \Omega_0.
hi thanks for you reply and time checking it
but when run it this is the error i got
UMFPACK V5.7.9 (Oct 20, 2019): ERROR: out of memory
  File "/home/mirialex/PycharmProjects/fibers/13-06-24-take2.py", line 390, in <module>
    solver.solve()
RuntimeError:
***     https://fenicsproject.discourse.group/
*** Error:   Unable to successfully call PETSc function 'KSPSolve'.
*** Reason:  PETSc error code is: 76 (Error in external library).
*** Where:   This error was encountered inside ./dolfin/la/PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.2.0.13.dev0
*** Git changeset:  ubuntu
Process finished with exit code 1
im using a solver once without time dependency and once with
without the time dependency im able to get resolution but once i getting to the loop of the time dependency it fails with the error above
i tried to lower the load steps in the loop or the number of the elements but nothing helped.
if you have any other piece of advice, would be more then happy to read
import fenics as fe
# rest of the code
du = TrialFunction(V)  # Incremental displacement
v = TestFunction(V)  # Test function
u = Function(V)  # Displacement from previous iteration
B = Constant((0.0, 0.0, 0.0))  # Body force per unit volume
T = Constant((0.0, 0.0, 0.0))  # Traction force on the boundary
# Project or interpolate the initial guess onto u
initial_guess = Expression(("x[0]", "x[1]", "x[2]"), degree=1)
u.interpolate(initial_guess)
# u.interpolate(Constant((0,0,0)))
# Kinematics
d = len(u)
I = Identity(d)  # Identity tensor
F = variable(I + grad(u))  # Deformation gradient
C = F.T * F  # Right Cauchy-Green tensor
Ic = tr(C)
J = det(F)
W = MU / 2 * (tr(C) - 3 - 2 * ln(J)) + LAMBDA / 2 * pow((J - 1), 2)
P = diff(W, F)
# Total potential energy
L = inner(P, grad(v)) * dx - dot(B, v) * dx - dot(T, v) * ds
Je = derivative(L, u, du)
problem = NonlinearVariationalProblem(L, u, bcs=bcs,J=Je)
solver.parameters['newton_solver']['relative_tolerance'] = 1e-6
solver.parameters['newton_solver']['linear_solver'] = 'lu'
#rest of the code
dt = 0.0001
t, T = 0.0, 1 * dt
TT = Traction()
while t <= T:
    print('time: ', t)
    # Increase traction
    TT.t = t
    tDirBC.time_ = t
    tDirBC4.time_ = t
    #rest of the code
    solver.solve()
    t += float(dt)
when i lower it back to number of elemnts of the number 4
its working but i still dont see the 2 materials
Try using mumps instead of umfpack. If you don’t know how to do that, it would be appreciated that you made a search (useful keywords could be NonlinearVariationalSolver and mumps) before asking us how to do that.
As I told you, 4 elements in the cross section is too coarse to obtain a decent representation of the circle.
If you want to use a very coarse mesh, the suggestion would be to have it generated by gmsh (you know how to do that, since we discussed it last week), so that the subdomains are build during the mesh generation process, rather than afterwards.
