Hi everyone,
I have read the FENICS course at here and it really helps.
But I have a very easy question just about defining the forward Euler. I am solving the same heat equation at the course and get good result at the backward Euler and the mid-point Euler. I thinks things only goes differently at the stiffness matrix. So I only change something at the stiffness matrix.But the results goes wrong.
Just wonder is there anything wrong at defining the weak form(forward Euler method =2).
#include FEniCS headers
from ufl import nabla_div, nabla_grad, div
import time
#Problem parameters variables
H = 1.00 #Plate Height
W = 1.00 #Plate Width
k_bar=385 #watt.mâ1Kâ1
value = 3.8151e6 #N.mâ2Kâ1
T=1000.0
num_steps=100 #time steps
dt = T / num_steps #delta t
method=2 #method=1 backward method=2 forward method=3 mid-point
#Create mesh
#The points represent the diagonal ends of the box, followed by the number of elments along each dimension
mesh = RectangleMesh(Point(0, 0), Point(W, H), 20, 10) #2D mesh
#Define function space.
#This creates a H1 functiPon space from which we can construct the solution (trail) and test function spaces.
V = FunctionSpace(mesh, 'P', 1) #With degree 1, we get the linear Lagrange element
# Define needed u (trial space), w (test space) function spaces
w = TestFunction(V)
# Define boundary condition
g_left= Constant(300.0) #along x = 0 m (left edge) K
g_right= Constant(310.0) #along x = 1 m (right edge) K
# Define function to identify the left boundary at 300K
def on_left(x, on_boundary):
return on_boundary and x[0] < DOLFIN_EPS
# Create the boundary condition
bc_left = DirichletBC(V, g_left, on_left)
# Define function to identify the right boundary at 310K
def on_right(x, on_boundary):
return on_boundary and x[0] > W - DOLFIN_EPS
bc_right = DirichletBC(V, g_right, on_right)
bc = [ bc_left, bc_right]
# Define expressions for heat conduction
def j(u):
return -k_bar*nabla_grad(u)
# Define initial value
u_0 = Expression('x[0] < 0.5 ? 300 : 300+20*(x[0]-0.5)', degree=1)
u_n=interpolate(u_0,V)
vtkfile = File('heat/heat.pvd')
#Define the weak form of the probleminner
f= Constant(0.0)
t=0
if method==1:
F =value*u*w*dx - dt*dot(j(u),nabla_grad(w))*dx - (value*u_n + dt*f)*w*dx #define the weak form(backward)
elif method==2:
F =value*u*w*dx - dt*dot(j(u_n),nabla_grad(w))*dx - (value*u_n + dt*f)*w*dx #define the weak form(forward)
elif method==3:
F =value*u*w*dx - 0.5* dt*dot(j(u),nabla_grad(w))*dx - 0.5* dt*dot(j(u_n),nabla_grad(w))*dx- (value*u_n + dt*f)*w*dx #define the weak form(mid-point)
a, L = lhs(F), rhs(F)
#solve the problem
#vtkfile << (u_n, t)
for n in range(num_steps):
# Update current time
# Compute solution
solve(a == L, u, bc)
# Save to file and plot solution
vtkfile << (u, t)
# Update previous solution
u_n.assign(u)
