Define time dependent vector valued function used in bilinear form
I want to define a vector valued function which will be used in bilinear form.
The problem I consider is u_{t}+dot(b,grad(u))+epsilon*div(grad(u))+cu=f
where b=(b_1(x,t),b_2(x,t)) in 2D and c=c(x,t).
I try to define them as
def u_exact(mod, t):
            return lambda x: mod.exp(mod.sin(2*mod.pi*t))*2*mod.sin(x[0])*(1-mod.exp(-2*(1-x[0])/epsilon.value))*(1-mod.exp(-(1-x[1])/epsilon.value))*x[1]**2
 #define b
 def bx(t):
      return lambda x:  2+(2*x[0]-x[1])*ufl.cos(2*ufl.pi*t)
def by(t):
      return  lambda x: 3+(-x[0]+2*x[1])*ufl.cos(2*ufl.pi*t)
def c(t):
       return lambda x: 3+t**2
 x=ufl.SpatialCoordinate(domain)
 t_var=ufl.variable(t)
exact_soln_ufl=u_exact(ufl,t_var)  #used for linear form
exact_soln_np=u_exact(np,t.value)    #used for interpolation
 bx=bx(t_var)
 by=by(t_var)
 c=c(t_var)
and I try to use them in
a=fem.form(u*v*dx+dt*epsilon*inner(grad(u),grad(v))*dx+dt*(bx*u.dx(0)*v*dx+by*u.dx(1))*v*dx+ dt*c*u*v*dx +
           dt*delta*(-epsilon*div(grad(u))+(bx*u.dx(0)+by*u.dx(1))+c*u)*(bx*v.dx(0)+by*v.dx(1))*dx+
           (u*delta*(bx*v.dx(0)+by*v.dx(1))*dx))
However , I receive error as
File "/root/shared/Fenics Codes/fenics/FSI_Solver/SUPG_TEST.py", line 82, in <module>
    a=fem.form(u*v*dx+dt*epsilon*inner(grad(u),grad(v))*dx+dt*(bx*u.dx(0)*v*dx+by*u.dx(1))*v*dx+ dt*c*u*v*dx +\
TypeError: unsupported operand type(s) for *: 'function' and 'Indexed'
So how to fix it ? And is there any other way to define a vector valued function used in bilinear form ?
Please help! Thanks in advance.
The complete code is
from dolfinx import mesh,fem,plot
from ufl import div,grad,diff,dot,inner,dx,ds,CellDiameter,TrialFunction,TestFunction,sin,pi,exp,Measure
T=1
ny=nx
num_steps=nx*nx
domain=mesh.create_unit_square(MPI.COMM_WORLD,nx,ny,mesh.CellType.triangle)
V=fem.FunctionSpace(domain,("CG",1))
k=T/num_steps
t=fem.Constant(domain,PETSc.ScalarType(0))
dt=fem.Constant(domain,PETSc.ScalarType(k))
epsilon=fem.Constant(domain,PETSc.ScalarType(1e-8))
#define b
def bx(t):
def by(t):
def c(t):
bx=bx(t_var)
by=by(t_var)
c=c(t_var)
#Apply homogeneous Dirichlet boundary condition
boundary_fun=fem.Function(V)
boundary_fun.interpolate(exact_soln_np)
tdim=domain.topology.dim
fdim=tdim-1
domain.topology.create_connectivity(fdim,tdim)
boundary_facets=mesh.exterior_facet_indices(domain.topology)
bc=fem.dirichletbc(boundary_fun,fem.locate_dofs_topological(V,fdim,boundary_facets))
#Initial condition
u_old=fem.Function(V)
u_old.interpolate(exact_soln_np)
#Define right hand side f
f=diff(exact_soln_ufl(x),t_var)-epsilon*div(grad(exact_soln_ufl(x)))+bx(x)*exact_soln_ufl(x).dx(0)+by(x)*exact_soln_ufl(x).dx(1)+c(x)*exact_soln_ufl(x)
u,v=TrialFunction(V),TestFunction(V)
h=CellDiameter(domain)
delta=h/40
            dt*delta*(-epsilon*div(grad(u))+(bx*u.dx(0)+by*u.dx(1))+c*u)*(bx*v.dx(0)+by*v.dx(1))*dx+ \
L=fem.form(u_old*v*dx+dt*f*(v+delta*(bx*v.dx(0)+by*v.dx(1)))*dx+u_old*delta*(bx*v.dx(0)+by*v.dx(1))*dx)
You really need to put some work into simplifying your code to pin down errors.
For instance, you should figure out what term of your form that causes the issue (as your form is rather long). By reducing it term by term, you will realize that the issue is with the definition of bx and by.
You can for instance use the following definition:
from functools import partial
nx = 1
T=1
ny=nx
num_steps=nx*nx
k=T/num_steps
#define b
def bx(x, t):
    return 2+(2*x[0]-x[1])*ufl.cos(2*ufl.pi*t)
def by(x, t):
    return 3+(-x[0]+2*x[1])*ufl.cos(2*ufl.pi*t)
def c(t):
    return 3+t**2
bx=partial(bx, t=t_var)
by=partial(by, t=t_var)
c=c(t_var)
a = dt*(bx(x)*u.dx(0)+by(x)*u.dx(1))*v*dx
which makes the first part of the code run.
You can then extend it term by term.
