Different mesh interpolation TypeError
Im trying to interpolate one Function between two different meshes. Basically, what I’m doing is (assuming I already have computed T in )
H = FunctionSpace(mesh,('Lagrange',2))
T_int = Function(H)
T_int.interpolate(T, nmm_interpolation_data=create_nonmatching_meshes_interpolation_data( T._V, H))
However, I get the following error:
TypeError: create_nonmatching_meshes_interpolation_data(): incompatible function arguments. The following argument types are supported:
    1. (Vu: dolfinx::fem::FunctionSpace, Vv: dolfinx::fem::FunctionSpace) -> Tuple[List[int], List[int], List[float], List[int]]
    2. (Vu: dolfinx::fem::FunctionSpace, Vv: dolfinx::fem::FunctionSpace, cells: numpy.ndarray[numpy.int32]) -> Tuple[List[int], List[int], List[float], List[int]]
Invoked with: FunctionSpace(Mesh(VectorElement(Basix element (P, triangle, 1, equispaced, unset, False), 2), 5), Basix element (P, triangle, 2, gll_warped, unset, False)), FunctionSpace(Mesh(VectorElement(Basix element (P, triangle, 1, equispaced, unset, False), 2), 6), Basix element (P, triangle, 2, gll_warped, unset, False))
I am using dolfinx 0.6.0, thank you very much
EDIT: if I chage the order of the funcion spaces, i.e. if I call
create_nonmatching_meshes_interpolation_data( H, T._V)
I get exactly the same error
See for instance the test: dolfinx/test_function.py at 8d55f950ca427228a96e96d43893b52b5071bf35 · FEniCS/dolfinx · GitHub
Is there a trick to using create_nonmatching_meshes_interpolation_data? I attempt a simplefrom dolfinx.fem import create_nonmatching_meshes_interpolation_data and get the following error:
ImportError                               Traceback (most recent call last)
Cell In[7], line 1
----> 1 from dolfinx.fem import create_nonmatching_meshes_interpolation_data
ImportError: cannot import name 'create_nonmatching_meshes_interpolation_data' from 'dolfinx.fem' (/usr/local/anaconda3/envs/fenicsx-env/lib/python3.10/site-packages/dolfinx/fem/__init__.py)
What version of DOLFINx do you have installed ?
conda version 0.6.0. I’m in the process of updating because I saw here that was an update 11 days ago. Hopefully that’s the problem.
EDIT. Updating didn’t help
This functionality was added after the 0.6.0 release.
The 0.6.0 release supports interpolation between meshes, but does not offer the Pre-compute interpolation data step.
