Different results with MPI
I have problems in understanding how mpi works. In the code below, I am trying to calculate the error of FEA results with the exact solution. Also I want to plot the displacements of a certain node through time. But when I run in parallel I get different results:
import dolfinx as fe
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem, assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
import os
import pyvista
import pandas as pd
from scipy.spatial import cKDTree
from scipy.special import jv, yv, iv, kv
from itertools import product
import h5py
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read": [cell_data.astype(np.int32)]})
    return out_mesh
def main(rho, E, nu, maximum_pressure, minimum_pressure, mesh_file, num_steps=100, element_degree=1):
    maximum_pressure = fe.default_scalar_type(maximum_pressure)
    minimum_pressure = fe.default_scalar_type(minimum_pressure)
    rho = fe.default_scalar_type(rho)
    E = fe.default_scalar_type(E)
    nu = fe.default_scalar_type(nu)
    proc = MPI.COMM_WORLD.rank
    ############################################Importing the mesh############################################
    #Wrinting the mesh as XDMF file to read from that later
    if proc == 0:
        # Read in mesh
        msh = meshio.read(mesh_file)
        # Create and save one file for the mesh, and one file for the facets
        tetra_mesh = create_mesh(msh, "tetra", prune_z=False)
        facets = create_mesh(msh, "triangle", prune_z=False)
        meshio.write(os.path.join("output", "mt.xdmf"), triangle_mesh)
        meshio.write(os.path.join("output", "mesh.xdmf"), tetra_mesh)
    MPI.COMM_WORLD.barrier()
    #Reading the xdmf files
    with fe.io.XDMFFile(MPI.COMM_WORLD, os.path.join("output", "mesh.xdmf"), "r") as xdmf:
        cell_markers = xdmf.read_meshtags(mesh, name="Grid")
    gdim = mesh.topology.dim
    mesh.topology.create_connectivity(gdim, gdim - 1)
    with fe.io.XDMFFile(MPI.COMM_WORLD, os.path.join("output", "mt.xdmf"), "r") as xdmf:
        facet_markers = xdmf.read_meshtags(mesh, name="Grid")
    points = mesh.geometry.x
    radius_to_check = 2
    for i, p in enumerate(points):
        if np.linalg.norm(p) == radius_to_check:
            index_of_radius_to_check = i
            break
    #######################creating function space and boundary condition#################################
    element = ufl.VectorElement("Lagrange", mesh.ufl_cell(), element_degree)
    V = fe.fem.functionspace(mesh, element)
    gamma_p = 0.01
    t = np.linspace(0, 2*np.pi / gamma_p, num_steps)
    dt = fe.fem.Constant(mesh, t[1] - t[0])
    pressure = maximum_pressure / 2 * (1 - np.cos(gamma_p * t))
    p = fe.fem.Constant(mesh, pressure[0])
    #########################################Formulation##################################################
    u = ufl.TrialFunction(V)
    v  = ufl.TestFunction(V)
    old_u  = fe.fem.Function(V)
    old_velocity  = fe.fem.Function(V)
    old_acceleration  = fe.fem.Function(V)
    d = len(u)
    I = ufl.variable(ufl.Identity(d))             # Identity tensor
    F = ufl.variable(I + ufl.grad(u))             # Deformation gradient
    C = ufl.variable(F.T*F)                   # Right Cauchy-Green tensor
    J = ufl.variable(ufl.det(F))
    metadata = {"quadrature_degree": 2}
    ds = ufl.Measure('ds', domain=mesh, subdomain_data=facet_markers, metadata=metadata)
    dx = ufl.Measure("dx", domain=mesh, metadata=metadata)
    # Generalized-alpha method parameters
    alpha_m = fe.fem.Constant(mesh, 0.01)
    alpha_f = fe.fem.Constant(mesh, 0.01)
    gamma   = fe.fem.Constant(mesh, fe.default_scalar_type(0.5+alpha_f-alpha_m))
    beta    = fe.fem.Constant(mesh, fe.default_scalar_type((gamma+0.5)**2/4.))
    # Update formula for acceleration
    # a = 1/(2*beta)*((u - u0 - v0*dt)/(0.5*dt*dt) - (1-2*beta)*a0)
    def update_a(u, u_old, v_old, a_old, ufl=True):
        if ufl:
            dt_ = dt
            beta_ = beta
            dt_ = float(dt)
            beta_ = float(beta)
        return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
    # Update formula for velocity
    # v = dt * ((1-gamma)*a0 + gamma*a) + v0
    def update_v(a, u_old, v_old, a_old, ufl=True):
        if ufl:
            dt_ = dt
            gamma_ = gamma
            dt_ = float(dt)
            gamma_ = float(gamma)
        return v_old + dt_*((1-gamma_)*a_old + gamma_*a)
    def update_fields(u_new, u_old, v_old, a_old):
        """Update fields at the end of each time step."""
        # Get vectors (references)
        u_vec, u0_vec  = u_new.x.array[:], u_old.x.array[:]
        v0_vec, a0_vec = v_old.x.array[:], a_old.x.array[:]
        # use update functions using vector arguments
        a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl=False)
        v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl=False)
        # Update (u_old <- u)
        v_old.x.array[:], a_old.x.array[:] = v_vec, a_vec
        u_old.x.array[:] = u_new.x.array[:]
    def avg(x_old, x_new, alpha):
        return alpha*x_old + (1-alpha)*x_new
    normal = -ufl.FacetNormal(mesh)
    mu = fe.fem.Constant(mesh, E / (2 * (1 + nu)))
    lmbda = fe.fem.Constant(mesh, E * nu / ((1 + nu) * (1 - 2 * nu)))
        return ufl.sym(ufl.grad(u))
    def S(u):
        return 2.0 * mu * epsilon(u) + lmbda * ufl.nabla_div(u) * I
    acceleration = update_a(u, old_u, old_velocity, old_acceleration, ufl=False)
    velocity = update_v(acceleration, old_u, old_velocity, old_acceleration, ufl=True)
    formulation = rho * ufl.inner(avg(old_acceleration, acceleration, alpha_m), v) * dx \
      + ufl.inner(epsilon(v), S(avg(old_u, u, alpha_f))) * dx \
      - ufl.dot(v, p * normal) * ds(112)
    bilinear_form = fe.fem.form(ufl.lhs(formulation))
    linear_form = fe.fem.form(ufl.rhs(formulation))
    ###############################################Solving################################################
    A = assemble_matrix(bilinear_form, bcs=[])
    b = create_vector(linear_form)
    solver.setInitialGuessNonzero(True)
    solver.setOperators(A)
    solver.getPC().setType(PETSc.PC.Type.SOR)
    displacement = fe.fem.Function(V)
    class exact_solution():
        def __init__(self, rho, inner_radius, k, lmbda, miu, p_0, gamma, num_steps):  # p = -p_0 * (1-cos(gammma*tau))
            self.a = inner_radius
            self.k = k  # outer_radius = k * a
            self.phi = -1/2
            self.n = 3/2
            self.C_11 = lmbda + 2 * miu #E * (1 - miu) / ((1 + miu) * (1 - 2*miu))
            self.C_12 = lmbda #E * miu / ((1 + miu) * (1 - 2*miu))
            self.m = self.C_12 / self.C_11
            self.S_1 = self.n - 2 * self.m - self.phi
            self.alpha = [1.01034, 3.33252, 9.48585, 6.37556, 15.74444, 12.61203, 28.29456, 18.87993, 25.1555, 22.01717, 31.43413, 34.57406, 37.71428, 40.8547, 43.99529, 47.13602, 50.27685, 62.84095, 53.41778, 59.69984, 56.55877, 65.98211, 78.54709, 69.12331, 109.96094, 72.26454, 75.4058, 84.82974, 87.97109, 81.68841, 144.51722, 97.39524, 94.25384, 91.11246, 141.37571, 100.53665, 103.67807, 106.8195, 113.10239, 116.24384, 128.80974, 119.38531]
            self.alpha.sort()
            self.p_0 = p_0
            self.gamma = gamma
            self.tau = 0 # 6 * 2 * np.pi
            self.c = np.sqrt(self.C_11 / rho)
            self.dtau =  2*np.pi / self.gamma /num_steps # dt /(2*np.pi)  # * self.c
        def return_tau(self):
            return self.tau
        def step_one_period(self):
            self.tau += self.gamma * 2*np.pi # self.c
        def step_in_time(self):
            self.tau += self.dtau
            # print(f"tau: {self.tau}")
        def r(self, x):   # distance to the center
            return np.sqrt(np.power(x[0], 2) + np.power(x[1], 2) + np.power(x[2], 2))
        def theta_cood(self, x):
            return np.arccos(x[2]/self.r(x))
        def phi_cood(self, x):
            return np.sign(x[1]) * np.arccos(x[0]/np.sqrt(np.power(x[0], 2) + np.power(x[1], 2)))
        def F(self, p, x):
            k = self.k
            n = self.n
            S_1 = self.S_1
            a = self.a
            return (kv(n, p*k + 0j) * S_1 + p*k * kv(n-1, p*k + 0j)) * iv(n, p*self.r(x)/a + 0j)\
                   - (iv(n, p*k + 0j) * S_1 - p*k * iv(n-1, p*k + 0j)) * kv(n, p*self.r(x)/a + 0j)
        def G(self, p):
            k = self.k
            n = self.n
            S_1 = self.S_1
            a = self.a
            return (kv(n, p*k + 0j) * S_1 + p*k * kv(n-1, p*k + 0j)) * (iv(n, p + 0j) * S_1 - p * iv(n-1, p + 0j))\
                   - (kv(n, p + 0j) * S_1 + p * kv(n-1, p + 0j)) * (iv(n, p*k + 0j) * S_1 - p*k * iv(n-1, p*k + 0j))
        def __call__(self, x, radial=False):
            p_0 = self.p_0
            a = self.a
            phi = self.phi
            C_11 = self.C_11
            k = self.k
            n = self.n
            S_1 = self.S_1
            gamma = self.gamma
            alpha = self.alpha
            first_term = -(p_0 * np.power(self.r(x)/a, phi) / C_11)\
                        * (-np.power(k, 2*n) * (-2*n + S_1) + S_1 * np.power(self.r(x)/a, 2*n))\
                        / ((-1+np.power(k, 2*n)) * (-2*n + S_1) * S_1 * np.power(self.r(x)/a, n))
            second_term = -(p_0 * np.power(self.r(x)/a, phi) / C_11)\
                        * self.F(np.array([1j * gamma]), x) * np.cos(gamma * self.tau)\
                        / self.G(np.array([1j * gamma]))
            series = 0
            for s in range(len(alpha)):
                first_parantheses = S_1 * jv(n, alpha[s] + 0j) - alpha[s] * jv(n-1, alpha[s] + 0j)
                second_parantheses = np.power(S_1, 2) - 2 * S_1 * n + np.power(alpha[s], 2)
                third_parantheses = np.power(S_1 * jv(n, alpha[s] * k + 0j) - alpha[s] * k * jv(n-1, alpha[s] * k + 0j), 2)
                forth_parantheses = S_1 * jv(n, alpha[s] * k + 0j) - alpha[s] * k * jv(n-1, alpha[s] * k + 0j)
                fifth_parantheses = np.power(S_1, 2) - 2 * S_1 * n + np.power(alpha[s] * k, 2)
                sixth_parantheses = np.power(S_1 * jv(n, alpha[s] + 0j) - alpha[s] * jv(n-1, alpha[s] + 0j), 2)
                series += 2 * self.F(np.array([1j * alpha[s]]), x)/(np.power(gamma, 2) - np.power(alpha[s], 2))\
                                        * first_parantheses * forth_parantheses / (second_parantheses * third_parantheses - fifth_parantheses * sixth_parantheses)\
                                        * np.cos(alpha[s] * self.tau)
            third_term = (p_0 * np.power(self.r(x)/a, phi) * np.power(gamma, 2) / C_11) * series
            u = np.zeros((1, x.shape[1]))
            u = first_term + second_term + third_term
            displacement = np.zeros(x.shape)
            mag = np.linalg.norm(x, axis=0)
            for i in range(mag.shape[0]):
                displacement[:, i] = u[i].real * x[:, i] / mag[i]
            if radial==True:
                return u.real
            return displacement #u.real # [0]
    radial_disp = []
    u_exact = exact_solution(1, 1, 2, lmbda.value, mu.value, 18/2, gamma_p, num_steps)
    radial_disp = []
    error = []
    # Stepping through time and solving for displacements and strains
    for i in range(int(num_steps)):
        print(i)
        if i < num_steps:
            p.value = pressure[i]
        with b.localForm() as loc_b:
            loc_b.set(0)
        assemble_vector(b, linear_form)
        apply_lifting(b, [bilinear_form], [[]])
        set_bc(b, [])
        # Solve linear problem
        solver.solve(b, displacement.vector)
        displacement.x.scatter_forward()
        radial_disp.append(np.linalg.norm(displacement.x.array.reshape((-1, 3))[index_of_radius_to_check, :]))
        displacement_exact = fe.fem.Function(V)
        displacement_exact.interpolate(u_exact)
        u_exact.step_in_time()
        error_L2 = MPI.COMM_WORLD.allreduce(
            fe.fem.assemble.assemble_scalar(fe.fem.form(((displacement - displacement_exact))** 2 * ufl.dx))**0.5,
            op=MPI.SUM)
        if mesh.comm.rank == 0:
            error.append(error_L2)
        # Update old fields with new quantities
        update_fields(displacement, old_u, old_velocity, old_acceleration)
    if proc == 0:
        plt.plot(t, [radial_disp[i] for i in range(int(num_steps))])
        print(error)
if __name__ == "__main__":
    mesh_file = "test.msh"
    main(1.0, 400, 0.3, 18, 0, mesh_file)
Both the plotted radial displacement and the error with respect to the exact solution are different in parallel.
Thank you in advance.
I would strongly suggest you try to reduce the complexity of this code, as it is a rather time-consuming effort to read through 350 lines of code to decipher what has gone wrong.
There is also an MPI tutorial for DOLFINx at: Parallel Computations with Dolfinx using MPI — MPI tutorial
Thank you @dokken
I read through the tutorial but I couldn’t find out what is causing the problem. I have used apply_lifting , scatter_reverse, scatter_forward, set_bc in the for loop iterating through time at the end of the code as the tutorial.
I tried to reduce the complexity of my code as much as I could.
def main(rho, E, nu, maximum_pressure, minimum_pressure, num_steps=100, element_degree=1):
    mesh = fe.mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([1, 1, 1])],
                         [20, 6, 6], cell_type=fe.mesh.CellType.hexahedron)
    mu = fe.fem.Constant(mesh, fe.default_scalar_type(E / (2 * (1 + nu))))
    lmbda = fe.fem.Constant(mesh, fe.default_scalar_type(E * nu / ((1 + nu) * (1 - 2 * nu))))
    def clamped_boundary(x):
        return np.isclose(x[0], 0)
    fdim = mesh.topology.dim - 1
    clamped_boundary_facets = fe.mesh.locate_entities_boundary(mesh, fdim, clamped_boundary)
    u_D = np.array([0, 0, 0], dtype=fe.default_scalar_type)
    bc = fe.fem.dirichletbc(u_D, fe.fem.locate_dofs_topological(V, fdim, clamped_boundary_facets), V)
    boundaries = [(1, lambda x: np.isclose(x[0], 1))]
        facets = fe.mesh.locate_entities(mesh, fdim, locator)
        facet_indices.append(facets)
    facet_tag = fe.mesh.meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
    gamma_p = 0.01
    d = len(u)
    ds = ufl.Measure('ds', domain=mesh, subdomain_data=facet_tag, metadata=metadata)
    def update_a(u, u_old, v_old, a_old):
        dt_ = float(dt)
        beta_ = float(beta)
    def update_v(a, u_old, v_old, a_old):
        dt_ = float(dt)
        a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec)
        v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec)
    def S(u):
    acceleration = update_a(u, old_u, old_velocity, old_acceleration)
    velocity = update_v(acceleration, old_u, old_velocity, old_acceleration)
      - ufl.dot(v, p * normal) * ds(1)
        def __call__(self, x):
            return x
    u_exact = exact_solution()
    radial_disp = []
    error = []
            loc_b.set(0)
        set_bc(b, [])
        radial_disp.append(np.linalg.norm(displacement.x.array.reshape((-1, 3))[10, :]))   ###Just a random node
            op=MPI.SUM)
    if MPI.COMM_WORLD.rank == 0:
        plt.plot(t, radial_disp)
        print(error)
    main(1.0, 400, 0.3, 18, 0)
Your L2 error computation is wrong, as \sqrt{a} + \sqrt{b} \neq \sqrt{a+b}.
I.e. you should use:
            fe.fem.assemble.assemble_scalar(fe.fem.form(((displacement - displacement_exact))** 2 * ufl.dx)),
            op=MPI.SUM)**0.5
Secondly, for debugging this, I would strongly advice you to check the displacement (visually in Paraview) and check that they look similar in eye-ball norm. That is what I did, and I saw they were the same, but that the error computation gave different results in serial and parallel.
Thank you really really much for your point,
I have another question about the index of the nodes in parallel, if I want to check for the displacement of one specific node that I know its global index, how can I know which processor with what local index contains the info of that node. Second if I want to save the displacements as petsc binary file like this:
io = PetscBinaryIO.PetscBinaryIO(complexscalars=True)
displacementAsPetscBiIOVec = displacement.vector.array_w.view(PetscBinaryIO.Vec)
io.writeBinaryFile( f"displacement_time_step_{i}.dat", [displacementAsPetscBiIOVec])
Should I append all the displacements calculated by all the processors first?
See the post: How to apply a boundary condition to a range of DOFs? - #7 by dokken
on how to map global input node index to a degree of freedom: How to apply a boundary condition to a range of DOFs? - #7 by dokken
For your second question I cannot give many pointers, as I do not use PetscBinaryIO.
