Diffusion of a Gaussian function - source term on for fraction of simulation time
I want to make a conceptually simple modification of the tutorial Diffusion of a Gaussian function where the Gaussian initial condition is carried over as a source term for a fraction of the simulation time, say 0 \le t \le 0.1. In the code below, the changes from the tutorial code are on lines 64-69, 72-73, and 124-127. However, this code gives the same result as the unmodified tutorial code. What am I doing wrong? Thanks!
# From https://jsdokken.com/dolfinx-tutorial/chapter2/diffusion_code.html
import pyvista
from dolfinx.fem.petsc import (
    apply_lifting,
    assemble_matrix,
    assemble_vector,
    create_vector,
    set_bc,
# Define temporal parameters
t = 0  # Start time
T = 1.0  # Final time
num_steps = 50
dt = T / num_steps  # time step size
t_on = 0.1
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(
    MPI.COMM_WORLD,
    [np.array([-2, -2]), np.array([2, 2])],
    [nx, ny],
    mesh.CellType.triangle,
V = fem.FunctionSpace(domain, ("Lagrange", 1))
# Create initial condition
def initial_condition(x, a=5):
    return np.exp(-a * (x[0] ** 2 + x[1] ** 2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
    domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool)
bc = fem.dirichletbc(
    PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V
xdmf = io.XDMFFile(domain.comm, "diffusion.xdmf", "w")
xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
xdmf.write_function(uh, t)
a = u * v * ufl.dx + dt * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
# Source off
f_source_off = fem.Constant(domain, PETSc.ScalarType(0))
L_source_off = (u_n + dt * f_source_off) * v * ufl.dx
# Source off
f_source_on = uh.copy()
L_source_on = (u_n + dt * f_source_on) * v * ufl.dx
bilinear_form = fem.form(a)
linear_form_source_off = fem.form(L_source_off)
linear_form_source_on = fem.form(L_source_on)
A = assemble_matrix(bilinear_form, bcs=[bc])
b = create_vector(linear_form_source_off)
solver.setOperators(A)
import matplotlib as mpl
pyvista.start_xvfb()
grid = pyvista.UnstructuredGrid(*plot.vtk_mesh(V))
plotter = pyvista.Plotter()
plotter.open_gif("u_time.gif", fps=10)
grid.point_data["uh"] = uh.x.array
warped = grid.warp_by_scalar("uh", factor=1)
viridis = mpl.colormaps.get_cmap("viridis").resampled(25)
sargs = dict(
    title_font_size=25,
    label_font_size=20,
    fmt="%.2e",
    color="black",
    position_x=0.1,
    position_y=0.8,
    width=0.8,
    height=0.1,
renderer = plotter.add_mesh(
    warped,
    show_edges=True,
    lighting=False,
    cmap=viridis,
    scalar_bar_args=sargs,
    clim=[0, max(uh.x.array)],
for i in range(num_steps):
    # Update the right hand side reusing the initial vector and appropriate linear
    # form for source on or off
    with b.localForm() as loc_b:
        loc_b.set(0)
    if t <= t_on:
        assemble_vector(b, linear_form_source_on)
        assemble_vector(b, linear_form_source_off)
    apply_lifting(b, [bilinear_form], [[bc]])
    set_bc(b, [bc])
    # Solve linear problem
    solver.solve(b, uh.vector)
    uh.x.scatter_forward()
    u_n.x.array[:] = uh.x.array
    # Write solution to file
    # Update plot
    plotter.update_coordinates(warped.points.copy(), render=False)
    plotter.update_scalars(uh.x.array, render=False)
    plotter.write_frame()
plotter.close()
xdmf.close()
P.S. I have gone through related topics in the forum, but did not find information that helped me resolve the problem.
The issue is that:
  1. The magnitude of your source is very small, so it is not going to fundamentally change the solution.
  2. You are only applying the source for the first 0.1 seconds (5 time steps, so it doesn’t have much time to influence the solution).
Either:
  1. Increase the magnitude of the source
  2. Increase the time-span of the influence of the source.
Please note that you could do this with a single form, i.e.:
import pyvista
    apply_lifting,
    assemble_matrix,
    assemble_vector,
    create_vector,
    set_bc,
t = 0  # Start time
num_steps = 50
t_on = 0.5
# Define mesh
nx, ny = 50, 50
    MPI.COMM_WORLD,
    [nx, ny],
u_n.name = "u_n"
uh.name = "uh"
# Source off
f = uh.copy()
f.name = "uh"
f.x.array[:] *= 5.
L = (u_n + dt * f) * v * ufl.dx
linear_form = fem.form(L)
b = create_vector(linear_form)
sargs = dict(
    title_font_size=25,
    label_font_size=20,
    fmt="%.2e",
    color="black",
    position_x=0.1,
    position_y=0.8,
    width=0.8,
    height=0.1,
    warped,
    show_edges=True,
    lighting=False,
    cmap=viridis,
        loc_b.set(0)
    if t > t_on:
        f.x.array[:] = 0.
    assemble_vector(b, linear_form)
    set_bc(b, [bc])
    # Update plot
plotter.close()
xdmf.close()
Awesome–that solves it. Thank you so much, and I appreciate the tip about using a single form!
Hello Fenics users,
I would like to slightly modify the tutorial Diffusion of a Gaussian function as
Gnordin did. In my case f = 0, u_{D} = 1 at the right and top boundaries. The initial condition here is u_{0} = 1.
In the code below, the changes from the tutorial code are on lines 33-35 for the initial condition (u (0, x, y) = 1) and on lines 59-67 for the boundary conditions. However, I don’t see the application of the boundary conditions (right and top boundary). What am I doing wrong? Thank you very much!
Here is my MWE:
import pyvista
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
                         form, locate_dofs_geometrical, locate_dofs_topological, set_bc)
from dolfinx.io import XDMFFile, VTXWriter
print(f"DOLFINx version: {dolfinx.__version__} based on GIT commit: {dolfinx.git_commit_hash} of https://github.com/FEniCS/dolfinx/")
t = 0  # Start time
num_steps = 50
# Define mesh
nx, ny = 8, 8
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
                               [nx, ny], mesh.CellType.triangle)
V = fem.functionspace(domain, ("Lagrange", 1))
# Create initial condition u(0, x, y) = 1
def initial_condition(x, a=0):
    return np.exp(-a * (x[0]**2 + x[1]**2))
u_n.name = "u_n"
#We create two python functions for determining the facets to apply boundary conditions to
def right(x):
    return np.isclose(x[0], 1)  #right (x = 1)
def top(x):
    return np.isclose(x[1], 1)  #top (y = 1)
######## Dirichlet boundary conditions #############
boundary_facets_right = locate_entities_boundary(domain, domain.topology.dim - 1, right)
boundary_dofs_right = locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets_right)
bc_m_right = dirichletbc(PETSc.ScalarType(0.), boundary_dofs_right, V)
boundary_facets_top = locate_entities_boundary(domain, domain.topology.dim - 1, top)
boundary_dofs_top = locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets_top)
bc_m_top = dirichletbc(PETSc.ScalarType(0.), boundary_dofs_top, V)
bcs = [bc_m_right, bc_m_top]  #dirichlet boundary conditions
#Time-dependent output
#xdmf = io.XDMFFile(domain.comm, "diffusion.xdmf", "w")
#xdmf.write_mesh(domain)
file = XDMFFile(domain.comm, "2DdiffusionEquation_june29th_2024.xdmf", "w")
file.write_mesh(domain)
uh.name = "uh"
file.write_function(uh, t)
#Variational problem and solver
#Preparing linear algebra structures for time dependent problems
A = assemble_matrix(bilinear_form, bcs=bcs)
#Using petsc4py to create a linear solver
#Visualization of time dependent problem using pyvista
sargs = dict(title_font_size=25, label_font_size=20, fmt="%.2e", color="black",
             position_x=0.1, position_y=0.8, width=0.8, height=0.1)
renderer = plotter.add_mesh(warped, show_edges=True, lighting=False,
                            cmap=viridis, scalar_bar_args=sargs,
                            clim=[0, max(uh.x.array)])
#Updating the solution and right hand side per time step
        loc_b.set(0)
    apply_lifting(b, [bilinear_form], [bcs])
    set_bc(b, bcs)
    # Update plot
    new_warped = grid.warp_by_scalar("uh", factor=1)
    warped.points[:, :] = new_warped.points
    warped.point_data["uh"][:] = uh.x.array
plotter.close()
file.close()
YOur bcs are not reflected in the code:
as both bcs are set to 0.
Thanks @dokken for your time.
Now let us modify the problem: f = 0, \ u_{D} = 1 at the right and top boundary. The initial condition is u(0, x, y) = 0.
Please tell me what this means?
Do I need to change the 0 value?
Thank you for your time and patience.
Here is my MWE :
import pyvista
t = 0  # Start time
num_steps = 100
# Define mesh
nx, ny = 50, 50
    return np.exp(-a * (x[0]**2 + x[1]**2)) - 1
u_n.name = "u_n"
def right(x):
def top(x):
bc_m_right = dirichletbc(PETSc.ScalarType(1.), boundary_dofs_right, V)
bc_m_top = dirichletbc(PETSc.ScalarType(1.), boundary_dofs_top, V)
file = XDMFFile(domain.comm, "2DdiffusionEquation_june30th_2024.xdmf", "w")
uh.name = "uh"
        loc_b.set(0)
    set_bc(b, bcs)
    # Update plot
plotter.close()
file.close()
but the results are not correct.
