Hi all,
I am working on solving a diffusion equation with a time-dependent diffusion tensor. For that, I am following the Diffusion of a Gaussian function demo, as well as the discussion in the similar thread Time dependent diffusion constant in dolfinx. However, because my diffusion coefficient is a tensor, I cannot use a simple trick from the previous post (D_.value[0]= 0.1*D) to reassign the value of the diffusion constituent and have to rewrite the tensor completely. As a result, the following re-assembly of the A matrix is taking a very long time on each timestep and I was wondering if there is a way to speed things up.
The example code is as follows (very minor edits to the original Diffusion of a Gaussian function demo). While this example still works quite fast although noticeably slower than the original, this approach results in an extremely large delay for the more complex problem that I am trying to solve.
from dolfinx import fem, mesh, io, plot
# Define temporal parameters
t = 0 # Start time
T = 1.0 # Final time
num_steps = 50
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
[nx, ny], mesh.CellType.triangle)
# Create initial condition
def initial_condition(x, a=5):
return np.exp(-a*(x[0]**2+x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
f = fem.Constant(domain, PETSc.ScalarType(0))
D = ufl.as_tensor(((1, 0), (0, 2)))
a = u * v * ufl.dx + dt*ufl.inner(D * ufl.grad(u), ufl.grad(v)) * ufl.dx
L = (u_n + dt * f) * v * ufl.dx
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = fem.petsc.assemble_matrix(bilinear_form, bcs=[bc])
b = fem.petsc.create_vector(linear_form)
solver.setOperators(A)
for i in range(num_steps):
print(t)
D = ufl.as_tensor(((1 - t, 0), (0, 2 - t)))
print('----> Assembling')
A = fem.petsc.assemble_matrix(fem.form(a), bcs=[bc])
with b.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b, linear_form)
fem.petsc.apply_lifting(b, [bilinear_form], [[bc]])
fem.petsc.set_bc(b, [bc])
# Solve linear problem
solver.solve(b, uh.vector)
uh.x.scatter_forward()
u_n.x.array[:] = uh.x.array
