Dirichlet BC on Mixed Elements
I am setting up a problem with MixElement() of 2 functions, the Dirichlet BC only applies to only one of the functions (one that corresponds to P1), how should I implement that? See the following code:
mesh    = IntervalMesh(20, 0, 1)
P1 = FiniteElement("CG", mesh.ufl_cell(), 1)
P2 = FiniteElement("CG", mesh.ufl_cell(), 1)
element = MixedElement([P1,P2])
def Dirichlet_Left(x, on_boundary):
    return on_boundary and x[0] < DOLFIN_EPS
bc    = DirichletBC(V, Constant(100.), Dirichlet_Left)
The last line gives this error:
RuntimeError:
*** Error: Unable to create Dirichlet boundary condition.
*** Reason: Expecting a vector-valued boundary value but given function is scalar.
*** Where: This error was encountered inside DirichletBC.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 15b823f2c45d3036b6af931284d0f8e3c77b6845
Use V.sub(0) or V.sub(1) in your DirichletBC, as shown in for instance: https://fenicsproject.org/olddocs/dolfin/latest/python/demos/stokes-iterative/demo_stokes-iterative.py.html
