Discontinuities at MPI partition boundaries with manual periodic MPC on large high-order curved mesh
I’m running a Poisson problem with periodic BCs in two directions on a high-order Lagrange space, and I’m seeing discontinuities (“lightning”) in the solution that align with MPI partition boundaries. Single-rank produces a smooth solution; running with 4 or 16 ranks introduces visible jumps. I’ve isolated the problem extensively and ruled out the standard suspects. A minimal reproducer (attached) on a unit cube does not exhibit the issue, so the question is what additional aspect of my real setup triggers it.
Setup
  • dolfinx 0.10, dolfinx_mpc 0.10.0 (contains PR #155 backsubstitution fix)
  • P4 Lagrange on a curved hex27 mesh from a turbine cascade CFD (PyFR), ~17M DOFs
  • Periodic in two translation directions (pitch + span)
  • Inlet/outlet: homogeneous Neumann
  • Single Dirichlet pin on a non-slave DOF to break the constant null space
  • Solver: dolfinx_mpc.LinearProblem with CG + bjacobi + icc
MPC construction (manual)
# slaves: locally owned dofs on x_max and y_max periodic boundaries
# masters: collected via allgather of all owned dofs near x_min OR y_min,
#          matched per-translation with KDTree
slaves_arr   = np.array(slaves_list, dtype=np.int32)   # local indices
masters_arr  = np.array(masters_list, dtype=np.int64)  # global indices
owners_arr   = np.array(owners_list, dtype=np.int32)
coeffs_arr   = np.ones(len(slaves_arr), dtype=np.float64)
offsets_arr  = np.arange(len(slaves_arr) + 1, dtype=np.int32)
mpc = dolfinx_mpc.MultiPointConstraint(V)
mpc.add_constraint(V, slaves_arr, masters_arr, coeffs_arr, owners_arr, offsets_arr)
mpc.finalize()
Master/slave detection reports max distance = 2.5e-14, 0 misses. Total 198,711 slaves after finalize.
Solve sequence (per dokken’s recommendation from thread 13241)
psi_h = problem.solve()
psi_h.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
mpc.backsubstitution(psi_h)
What I’ve verified
All checks below pass on every rank in parallel:
  1. psi_h.function_space is mpc.function_space returns True.
  2. For every local slave (all 198,711 across ranks), I compute
    max_i | psi_h[slave_i] - sum_j coeff_ij * psi_h[master_ij] |
    Result: 0.000e+00 on every rank. Backsubstitution is bit-exact.
  3. For 1000 ghost DOFs per rank, I compare the ghost value to the corresponding owned value on the owning rank (looked up via KDTree on allgathered owned coordinates). Result: 0.000e+00 on every rank. Ghost synchronization is bit-exact.
  4. Writing a Function(V) filled with 1.0 to a VTKFile and viewing in ParaView shows a perfectly smooth constant field — no partition-boundary artifacts in the output pipeline.
  5. Interpolating psi_h to a P1 space and writing that also shows the same discontinuities, ruling out high-order Lagrange visualization artifacts.
  6. The source term (interpolated from CFD data) is smooth in the visualization — no discontinuities. The discontinuities only appear in psi_h.
  7. The matrix diagonal is checked: slave rows have diagonal 1.000e+00 ± 1e-3 on all ranks. Non-slave diagonals vary across ranks but only in proportion to local cell size (METIS variation), which is expected.
  8. The Neumann/pin compatibility condition is enforced: ∫ f dV is computed before solve and the mean is subtracted from the source to satisfy ∫ f dV = 0 exactly. The discontinuities persist.
  9. MWE on a unit cube hex mesh with the same MPC construction logic (attached: mwe.py) produces a smooth solution at any rank count. The bug only appears in the production setup.
Symptom
The discontinuities (“lightning”) in psi_h:
  • Align with MPI partition boundaries (verified by overlaying a DG-0 rank field)
  • Are at magnitudes ~1e-4 in a field where typical values are ~1e-4 to ~1e-3 (i.e. they’re significant)
  • Become fewer/less visible with fewer ranks (n=4 vs n=16)
  • Were not present in the previous setup (Dirichlet at inlet/outlet, no MPC)
Question
Given the MWE does NOT reproduce the issue, but my production setup does, the key differences between them are:
  • Curved hex27 mesh (P2 coordinate element) from CFD data, vs. flat hex8 in the MWE
  • 17M DOFs at P4, vs. ~10k in the MWE
  • METIS partitioning of a thin, anisotropic domain (turbine blade passage), vs. cube
  • Edge DOFs: 519 DOFs lie on the intersection of pitch and span periodic boundaries (corner edges). The MWE has only a few. I tried registering these explicitly with a diagonal translation master (instead of relying on a chain through one of the single-translation masters), but this did not change the symptom.
Could anything in this list specifically interact with dolfinx_mpc in a way that breaks parallel consistency despite backsubstitution and ghost sync both being bit-exact? Or are there additional collective consistency checks I should be doing on the MultiPointConstraint itself before solving?
MWE
[Attach mwe.py — runs in seconds on a unit cube, smooth at all rank counts]
mpirun -n 4 stdbuf -oL python -u mwe.py
Any pointers welcome — happy to add additional diagnostics or share more of the production code.
Thanks!
MWE: dolfinx_mpc parallel periodicity issue.
Setup:
- Unit cube, hex mesh, P4 Lagrange (high-order matters)
- Periodic in x and y (two directions, like turbine cascade pitch + span)
- Neumann at z=0 and z=1, single Dirichlet pin to remove null space
- Periodicity via MANUAL mpc.add_constraint(...) with KDTree-based master/slave
  detection (not create_periodic_constraint_topological)
- dolfinx 0.10.x, dolfinx_mpc 0.10.0
Observation:
- Single-rank run produces smooth solution
- Parallel run (n=4, n=16) shows visible discontinuities ("lightning") in psi
  that follow MPI partition boundaries when visualized in ParaView
- MPC backsubstitution verification passes:
    max |slave - sum(coeff*master)| ~= 0 (machine precision)
  so backsubstitution itself is not the issue
- The function space of the solution is mpc.function_space (correct)
- ghostUpdate + backsubstitution are called explicitly as per Dokken's
  recommendation
Question: why do the partition-boundary discontinuities appear even though the
periodicity constraints are perfectly satisfied?
Run with:
    mpirun -n 1 python mwe.py        # smooth, reference
    mpirun -n 4 python mwe.py        # discontinuities at partitions
from scipy.spatial import KDTree
from dolfinx import fem, mesh
from dolfinx.mesh import locate_entities_boundary
from dolfinx.io import VTKFile
import dolfinx_mpc
comm = MPI.COMM_WORLD
rank = comm.rank
# 1. mesh
N_xy, N_z = 16, 4
msh = mesh.create_box(
    comm, [[0.0, 0.0, 0.0], [1.0, 1.0, 1.0]], [N_xy, N_xy, N_z],
    mesh.CellType.hexahedron,
tdim = msh.topology.dim
fdim = tdim - 1
msh.topology.create_connectivity(tdim, fdim)
# 2. function space
ORDER = 4
V = fem.functionspace(msh, ("Lagrange", ORDER))
if rank == 0:
    print(f"DOFs: {V.dofmap.index_map.size_global}", flush=True)
comm.Barrier()
if rank == 0: print("CP1: function space ready", flush=True)
# 3. periodic MPC setup (manual, KDTree-based)
def facets_at(axis, val):
    return locate_entities_boundary(msh, fdim, lambda x: np.isclose(x[axis], val))
pitch_slave_facets = facets_at(0, 1.0)  # x = 1 -> x = 0
span_slave_facets  = facets_at(1, 1.0)  # y = 1 -> y = 0
pitch_translation = np.array([1.0, 0.0, 0.0])
span_translation  = np.array([0.0, 1.0, 0.0])
dof_coords = V.tabulate_dof_coordinates()
imap = V.dofmap.index_map
n_local = imap.size_local
local_range_start = imap.local_range[0]
# slave dofs, locally owned only
pitch_slave_dofs = fem.locate_dofs_topological(V, fdim, pitch_slave_facets)
pitch_slave_dofs = pitch_slave_dofs[pitch_slave_dofs < n_local]
span_slave_dofs = fem.locate_dofs_topological(V, fdim, span_slave_facets)
span_slave_dofs = span_slave_dofs[span_slave_dofs < n_local]
span_slave_dofs = np.setdiff1d(span_slave_dofs, pitch_slave_dofs)
# gather all candidate master dofs (owned, near x=0 OR y=0) from all ranks
owned_coords = dof_coords[:n_local]
mask = (np.isclose(owned_coords[:, 0], 0.0, atol=1e-4)
        | np.isclose(owned_coords[:, 1], 0.0, atol=1e-4))
local_master_coords  = np.ascontiguousarray(owned_coords[mask])
local_master_globals = np.arange(n_local, dtype=np.int64)[mask] + local_range_start
local_master_owners  = np.full(mask.sum(), rank, dtype=np.int32)
if rank == 0: print(f"CP2: rank {rank} has {len(local_master_coords)} local masters, "
                    f"{len(pitch_slave_dofs)} pitch slaves, {len(span_slave_dofs)} span slaves", flush=True)
comm.Barrier()
all_master_coords  = np.vstack(comm.allgather(local_master_coords))
all_master_globals = np.concatenate(comm.allgather(local_master_globals))
all_master_owners  = np.concatenate(comm.allgather(local_master_owners))
comm.Barrier()
if rank == 0: print(f"CP3: allgather done, {len(all_master_coords)} total masters", flush=True)
master_tree = KDTree(all_master_coords)
comm.Barrier()
if rank == 0: print("CP4: kdtree built", flush=True)
slaves_list, masters_list, owners_list = [], [], []
for sl in pitch_slave_dofs:
    sc = dof_coords[sl]
    mc = sc - pitch_translation
    d, idx = master_tree.query(mc)
    if d > 1e-8:
        continue
    slaves_list.append(int(sl))
    masters_list.append(int(all_master_globals[idx]))
    owners_list.append(int(all_master_owners[idx]))
for sl in span_slave_dofs:
    sc = dof_coords[sl]
    mc = sc - span_translation
    if d > 1e-8:
        continue
comm.Barrier()
if rank == 0: print(f"CP5: matching done, rank {rank} has {len(slaves_arr)} slave-master pairs", flush=True)
comm.Barrier()
if rank == 0: print("CP6: mpc object created", flush=True)
comm.Barrier()
if rank == 0: print("CP7: add_constraint done", flush=True)
mpc.finalize()
comm.Barrier()
if rank == 0: print("CP8: finalize done", flush=True)
if rank == 0:
    n_total = comm.allreduce(mpc.num_local_slaves, op=MPI.SUM)
    print(f"total MPC slaves: {n_total}", flush=True)
# 4. single pin on a non-slave dof (rank 0 only)
if rank == 0:
    slave_set = set(mpc.slaves.tolist())
    candidates = [d for d in range(n_local) if d not in slave_set]
    pin_dof = candidates[len(candidates) // 2]
    pinned = np.array([pin_dof], dtype=np.int32)
    pinned = np.array([], dtype=np.int32)
bc_pin = fem.dirichletbc(np.float64(0.0), pinned, V)
# 5. Poisson with periodic source
u = ufl.TrialFunction(V)
f_src = ufl.sin(2 * ufl.pi * x[0]) * ufl.cos(2 * ufl.pi * x[1])
a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f_src * v * ufl.dx
problem = dolfinx_mpc.LinearProblem(
    a, L, mpc, bcs=[bc_pin],
    petsc_options={"ksp_type": "cg", "pc_type": "bjacobi",
                   "sub_pc_type": "icc", "ksp_rtol": 1e-10,
                   "ksp_converged_reason": None},
    petsc_options_prefix="mwe",
psi = problem.solve()
psi.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT,
mpc.backsubstitution(psi)
# 6. verify backsubstitution: slave == sum(coeff * master) ?
slaves = mpc.slaves
masters_adj = mpc.masters
coeffs_full, offsets_full = mpc.coefficients()
max_err = 0.0
for i in range(mpc.num_local_slaves):
    islv = int(slaves[i])
    mlist = masters_adj.links(islv)
    clist = coeffs_full[offsets_full[islv]:offsets_full[islv + 1]]
    if len(mlist) > 0:
        expected = sum(c * psi.x.array[int(m)] for c, m in zip(clist, mlist))
        max_err = max(max_err, abs(psi.x.array[islv] - expected))
max_err_g = comm.allreduce(max_err, op=MPI.MAX)
if rank == 0:
    print(f"MPC verification: max |slave - sum(coeff*master)| = {max_err_g:.3e}",
          flush=True)
    print("  (~0 => backsubstitution is correct)", flush=True)
# 7. output: psi + rank field for diagnostic
V_dg = fem.functionspace(msh, ("DG", 0))
rank_field = fem.Function(V_dg, name="rank")
rank_field.x.array[:] = float(rank)
psi.name = "psi"
with VTKFile(comm, "mwe_psi.pvd", "w") as vtk:
    vtk.write_function(psi, 0.0)
with VTKFile(comm, "mwe_rank.pvd", "w") as vtk:
    vtk.write_function(rank_field, 0.0)
if rank == 0:
    print("\nDone. Open mwe_psi.pvd and mwe_rank.pvd in ParaView.", flush=True)
    print("Expected: smooth psi. Observed (parallel): discontinuities at "
          "partition boundaries.", flush=True)
Why do you need this here? This should happen within solve:
Thank you @dokken for clarifying that the explicit ghostUpdate + backsubstitution after solve() is redundant since it’s already done internally.
I added those calls during diagnostics following advice in thread 12401 where they seemed needed in older versions. Removing them does not change the symptom — the partition-boundary discontinuities persist.
Setup recap (since this is the core question):
  • Poisson problem ∇²u = f on a curved hex27 mesh from CFD data (~17M DOFs, P4 Lagrange)
  • Two periodic translations (pitch + span), no Dirichlet boundary except a single pin
  • ~200k MPC slaves
  • 16 MPI ranks
  • Periodicity built via manual mpc.add_constraint(slaves, masters, coeffs, owners, offsets) because the slave/master pairs come from external CFD mesh data
What I tried after your reply:
I attempted to switch from manual add_constraint to the higher-level create_periodic_constraint_topological and create_periodic_constraint_geometrical, but both immediately crash with:
RuntimeError: Newton method failed to converge for non-affine geometry
This matches the issue from thread 13511 and thread 13421, where you suggested raising the pull-back Newton tolerance (PR #104). That tolerance does not seem exposed via the Python API in v0.10.0, so I’d need to patch and rebuild the C++ side — which is non-trivial in our conda-managed cluster environment.
The manual add_constraint path is therefore the only route that works for me (no crash). With that path, the solve converges, and all internal consistency checks pass on every rank in parallel:
  • u.function_space is mpc.function_spaceTrue
  • max_i | u[slave_i] - sum_j coeff_ij * u[master_ij] | = 0.000e+00
  • Ghost-owned-value consistency check (compare every ghost dof’s value to its owned counterpart on the owning rank, via KDTree on allgathered coords) → 0.000e+00 on every rank
Yet the solution still shows visible jumps along MPI partition boundaries when visualized in ParaView — confirmed to coincide with the partition seams by overlaying a DG-0 rank field, and the number of jumps scales with the rank count (2 jumps with n=2, 15 jumps with n=16).
My questions:
  1. Is there a way to expose the pull-back Newton tolerance via the Python API, so I could try create_periodic_constraint_topological on my curved mesh?
  2. Given that all the standard consistency checks pass on the manual add_constraint path, is there something subtle in the matrix assembly with that low-level API that could lead to partition-dependent results — even when the slave-master values are perfectly enforced?
Could you try to upgrade to dolfinx_mpc v0.10.5 which is on conda forge, as it exposes the tolerance option:
Update: working solution
Thanks to @dokken’s it worked now. Maybe for the others:
What fixed it
  1. Upgraded to dolfinx_mpc 0.10.5 (with openmpi 5.x). The tol parameter in create_periodic_constraint_topological was the key.
  2. Replaced manual mpc.add_constraint(...) with create_periodic_constraint_topological. With a raised tolerance of 5000 * np.finfo(np.float64).eps ≈ 1.1e-12, the Newton pull-back converges on my curved hex27 geometry where it previously crashed with “Newton method failed to converge for non-affine geometry”.
  3. Handled the corner DOFs (intersection of both periodic surfaces) with a diagonal mapping inside the first relation function, instead of trying to register them as a separate constraint:
TOL = 5000.0 * np.finfo(np.float64).eps
def pitch_slave_to_master(x):
    out_x = x.copy()
    out_x[0] -= pitch_translation[0]
    out_x[1] -= pitch_translation[1]
    out_x[2] -= pitch_translation[2]
    # edge DOFs (also on span-slave): apply span translation as well
    on_span = np.isclose(x[2], span_slave_z, atol=TOL)
    out_x[0][on_span] -= span_translation[0]
    out_x[1][on_span] -= span_translation[1]
    out_x[2][on_span] -= span_translation[2]
    return out_x
def span_slave_to_master(x):
    out_x = x.copy()
    out_x[0] -= span_translation[0]
    out_x[1] -= span_translation[1]
    out_x[2] -= span_translation[2]
    # exclude edge DOFs (handled diagonally by pitch_slave_to_master)
    on_pitch = <KDTree query returning dists < 1e-8>
    out_x[0, on_pitch] = np.nan
    out_x[1, on_pitch] = np.nan
    out_x[2, on_pitch] = np.nan
    return out_x
mpc.create_periodic_constraint_topological(V, pitch_mt, PITCH_TAG, pitch_slave_to_master, [], tol=TOL)
mpc.create_periodic_constraint_topological(V, span_mt, SPAN_TAG, span_slave_to_master, [], tol=TOL)
mpc.finalize()
  1. Removed the explicit ghostUpdate + mpc.backsubstitution after solve() — those are already done internally in dolfinx_mpc.LinearProblem.solve() in v0.10.x, as @dokken pointed out.
Result
Parallel runs (16 ranks, ~17M DOFs, P4 Lagrange on curved hex27) now produce smooth solutions with no partition-boundary discontinuities and no corner artifacts.
