Size-Dependent Boundary Artifact: Periodic-Dirichlet Boundaries
I am solving Laplace’s equation \Delta \phi = 0 on a box. The boundaries have values of 0 for the front y-face, back y-face, and bottom. \phi = 1 on the top. The x faces are periodic. The bottom face of the box is located at z = 0.
When the box has a height of 2, I see an edge artifact (negative value ~8.3e-5) from a single point on the edge parallel with the z axis, at ~z=1.5. It is on the upper, Dirichlet y-face, next to the lower, periodic x face.
However, when I run with a height zlen = 1, the artifact disappears and the lowest global value of potential is 0. I am using dolfin-x version 0.9.0 with conda. The program is ran with 1 processor.
# This demo solves Laplace's Eqn on a simple box
# - top potential = 1
# - bottom potential = 0
# - front and back y faces = 0
# - x faces are periodic
import dolfinx.fem as fem
from dolfinx.fem import Function
from dolfinx.io import XDMFFile, gmshio
from petsc4py.PETSc import ScalarType  # type: ignore
from ufl import (
    TestFunction,
    TrialFunction,
    dx,
    grad,
    inner,
    Measure,
import dolfinx_mpc
def create_box(xlen, ylen, zlen):
    # generate mesh
    # name the model
    gmsh.model.add("square")
    # Create box using occ
    # bottom centered on (0, 0, 0)
    # top centered on (0, 0, zlen)
    gmsh.model.occ.addBox(x=-0.5 * xlen, y=-0.5*ylen, z=0, dx=xlen, dy=ylen, dz=zlen)
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.2)
    gmsh.model.occ.synchronize()
    return
def add_groups(xlen, ylen, zlen):
    #add physical groups
    top = []
    bottom = []
    sides = []
    # add boundaries as physical groups
    boundaries = gmsh.model.occ.getEntities(dim=2)
    # loop over boundaries
    for boundary in boundaries:
        com = gmsh.model.occ.getCenterOfMass(boundary[0], boundary[1])
        if np.allclose(com[2], 0):
            bottom.append(boundary[1])
        elif np.allclose(com[2], zlen):
            top.append(boundary[1])
            sides.append(boundary[1])
    for qty in [top, bottom, sides]:
        #top added first, bottom added second
        gmsh.model.addPhysicalGroup(2, qty)
    # add entire domain to groups
    layers = gmsh.model.occ.getEntities(dim=3)
    gmsh.model.addPhysicalGroup(layers[0][0], [layers[0][1]])
    gmsh.model.mesh.generate(3)
    # save mesh to file
    gmsh.write("square.msh")
    gmsh.finalize()
    return
def assign_periodic_mesh(xlen, ylen, zlen):
    translation_x = [1, 0, 0, xlen,
                     0, 1, 0, 0,
                     0, 0, 1, 0,
                     0, 0, 0, 1]
    eps = 1e-5
    # Get left surface:
    sxmin = gmsh.model.getEntitiesInBoundingBox(
        xmin=-0.5 * xlen - eps,
        ymin=-0.5 * ylen - eps,
        zmin=-eps,
        xmax=-0.5 * xlen + eps,
        ymax=0.5 * ylen + eps,
        zmax=zlen + eps,
        dim=2,
    for i_x in sxmin:
        # Get the bounding box of the left surface
        xmin, ymin, zmin, xmax, ymax, zmax = gmsh.model.getBoundingBox(
            i_x[0], i_x[1]
        # Translate the bounding box to the right and look for surfaces inside it:
        sxmax = gmsh.model.getEntitiesInBoundingBox(
            xmin - eps + xlen,
            ymin - eps,
            zmin - eps,
            xmax + eps + xlen,
            ymax + eps,
            zmax + eps,
            2,
        # For all the matches, we compare the corresponding bounding boxes...
        for j_x in sxmax:
            xmin2, ymin2, zmin2, xmax2, ymax2, zmax2 = gmsh.model.getBoundingBox(
                j_x[0], j_x[1]
            xmin2 -= xlen
            xmax2 -= xlen
            # ...and if they match, we apply the periodicity constraint
            if (
                abs(xmin2 - xmin) < eps
                and abs(xmax2 - xmax) < eps
                and abs(ymin2 - ymin) < eps
                and abs(ymax2 - ymax) < eps
                and abs(zmin2 - zmin) < eps
                and abs(zmax2 - zmax) < eps
                print('x periodic success!')
                gmsh.model.mesh.setPeriodic(1, [j_x[1]], [i_x[1]], translation_x)
    return
def add_dirichlet_BCs(V, ylen, zlen):
    # front y face
    geo_dofs = fem.locate_dofs_geometrical(V, lambda x: np.isclose(x[1], 0.5 * ylen))
    bc_front_y = fem.dirichletbc(ScalarType(0.0), geo_dofs, V)
    # back y face
    geo_dofs = fem.locate_dofs_geometrical(V, lambda x: np.isclose(x[1], -0.5 * ylen))
    bc_back_y = fem.dirichletbc(ScalarType(0.0), geo_dofs, V)
    # bottom
    geo_dofs = fem.locate_dofs_geometrical(V, lambda x: np.isclose(x[2], 0.0))
    bc_low = fem.dirichletbc(ScalarType(0.0), geo_dofs, V)
    # top
    geo_dofs = fem.locate_dofs_geometrical(V, lambda x: np.isclose(x[2], zlen))
    bc_hi = fem.dirichletbc(ScalarType(1.0), geo_dofs, V)
    bcs = [bc_low, bc_hi, bc_front_y, bc_back_y]
    return bcs
def periodic_boundaries(bcs, xlen):
    def periodic_boundary(x):
        return np.isclose(x[0], 0.5 * xlen)
    def periodic_relation(x):
        out_x = np.zeros_like(x)
        out_x[0] = x[0] - xlen
        out_x[1] = x[1]
        out_x[2] = x[2]
        return out_x
    mpc = dolfinx_mpc.MultiPointConstraint(V)
    mpc.create_periodic_constraint_geometrical(V, periodic_boundary, periodic_relation, bcs)
    mpc.finalize()
    return mpc
### Main ###
# create mesh
# dimensions of box
xlen = 1
ylen = 1
zlen = 2
rank = MPI.COMM_WORLD.rank
if rank == 0:
# load in mesh
mesh, cell_markers, facet_markers = gmshio.read_from_msh(
    "square.msh", MPI.COMM_WORLD, gdim=3
# begin BCs
tdim = mesh.geometry.dim
V = fem.functionspace(mesh, ("Lagrange", 1))
bcs = add_dirichlet_BCs(V, ylen, zlen)
mpc = periodic_boundaries(bcs, xlen)
dx = Measure("dx", domain=mesh)
bilinear_form = fem.form(a)
# set homogeneous source term for Laplace Eqn.
f = fem.Constant(mesh, ScalarType(0.0))
L = inner(f, v) * dx
linear_form = fem.form(L)
A_org = dolfinx_mpc.assemble_matrix(bilinear_form, mpc, bcs=bcs)
A_org.assemble()
L_org = dolfinx_mpc.assemble_vector(linear_form, mpc)
dolfinx_mpc.apply_lifting(L_org, [bilinear_form], [bcs], mpc)
fem.petsc.set_bc(L_org, bcs)
# solver settings
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A_org)
ksp.setType(PETSc.KSP.Type.PREONLY)
pc = ksp.getPC()
pc.setType("lu")
pc.setHYPREType("mumps")
pc.setUp()
solution = Function(mpc.function_space)
ksp.solve(L_org, solution.x.petsc_vec)
processors = MPI.COMM_WORLD.size
name = 'solution_%i_procs'%(processors)
print("Writing solution to", name)
with XDMFFile(MPI.COMM_WORLD, name + '.xdmf', "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(solution)
I don’t have time to look through your code, but are you sure your problem is well posed? You have inconsistent boundary conditions resulting from discontinuities at the lines which are the intersection of your “front” and “back” boundaries with the “top” boundary.
I appreciate your quick reply. I think the discontinuous boundary conditions are ok. The general solution of \phi(x, y, z) \propto \cos(Ay) \sinh(Bz) (and constant in x) should give a unique answer and still satisfy the boundary conditions
You are missing a
mpc.backsubstitution(solution)
after solving the problem.
I attach a version that is compatible with 0.9.0 and 0.10.0 of DOLFINx.
try:
    from dolfinx.io import gmshio
except ImportError:
    import dolfinx.io.gmsh as gmshio
from ufl import (
    TestFunction,
    TrialFunction,
    dx,
    grad,
    inner,
    Measure,
import dolfinx_mpc
    # generate mesh
    # name the model
    return
    top = []
    bottom = []
    sides = []
    # save mesh to file
    gmsh.finalize()
    return
                     0, 1, 0, 0,
                     0, 0, 1, 0,
                     0, 0, 0, 1]
    eps = 1e-5
    # Get left surface:
        zmin=-eps,
        zmax=zlen + eps,
        dim=2,
    for i_x in sxmin:
            i_x[0], i_x[1]
            xmin - eps + xlen,
            ymin - eps,
            zmin - eps,
            xmax + eps + xlen,
            ymax + eps,
            zmax + eps,
            2,
        for j_x in sxmax:
                j_x[0], j_x[1]
            xmin2 -= xlen
            xmax2 -= xlen
            if (
    return
    # front y face
    # back y face
    # bottom
    # top
    return bcs
        out_x[1] = x[1]
        out_x[2] = x[2]
        return out_x
    mpc.finalize()
    return mpc
### Main ###
# create mesh
# dimensions of box
xlen = 1
ylen = 1
zlen = 2
if rank == 0:
# load in mesh
try:
except ValueError:
    mesh_data = gmshio.read_from_msh(
    mesh = mesh_data.mesh
    cell_markers = mesh_data.cell_tags
    facet_markers = mesh_data.facet_tags
# begin BCs
A_org.assemble()
# solver settings
pc = ksp.getPC()
pc.setType("lu")
pc.setUp()
After running the suggested code, including the mpc.backsubstitution(solution), the artifact is still present. I have included a Paraview output, with modified color scaling to reveal the artifact.
Thanks to you both. This artifact (shown above) occurs on my Apple Silicon Mac.
However, running my original code and dokken’s (with or without the mpc.backsubstitution(solution)) on a linux machine shows no artifact. I suppose this is machine dependent. I’ll develop on linux moving forward.
For posterity, my installs (same on each machine) are
conda create -n fenics-test python=3.13
conda activate fenics-test
conda install -c conda-forge fenics-dolfinx mpich pyvista
conda install conda-forge::dolfinx_mpc
conda install conda-forge::python-gmsh
with relevant versions
dolfinx_mpc                  0.9.3
fenics-dolfinx               0.9.0
Could you adjusting the tol parameter in: dolfinx_mpc — DOLFINx-MPC: An extension to DOLFINx for multi point constraints
to say 1e-8?
I upgraded to dolfinx_mpc 0.10.0 and tried different tol parameters between 1.0e-8 and 1.0e-2, without any change.
Very strange, I’ll see if I can reproduce it ( I don’t have a Mac, so will ask a colleague).
