Hello all,
I am working on a phase field problem. The formulation I use is :
[ref : Maurini and Farell ]
I got pretty good results with w(alpha) = alpha² but with w(alpha) = alpha, I met this issue :
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c: In function 'functionspace_form_libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746_0':
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1173:1: warning: parameter names (without types) in function declaration
1173 | static ufcx_function_space functionspace_Max(psi_plus) =
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1173:28: error: invalid storage class for function 'functionspace_Max'
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1175:1: error: field name not in record or union initializer
1175 | .finite_element = &element_703c39b3216cbd499bb1267d13b485382ccc3f67,
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1175:1: note: (near initialization for '(anonymous)')
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1176:1: error: field name not in record or union initializer
1176 | .dofmap = &dofmap_703c39b3216cbd499bb1267d13b485382ccc3f67,
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1176:1: note: (near initialization for '(anonymous)')
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1177:1: error: field name not in record or union initializer
1177 | .geometry_family = "Q",
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1177:1: note: (near initialization for '(anonymous)')
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1178:1: error: field name not in record or union initializer
1178 | .geometry_degree = 1,
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1178:1: note: (near initialization for '(anonymous)')
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1179:1: error: field name not in record or union initializer
1179 | .geometry_basix_cell = 4,
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1179:1: note: (near initialization for '(anonymous)')
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1180:1: error: field name not in record or union initializer
1180 | .geometry_basix_variant = 0
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1180:1: note: (near initialization for '(anonymous)')
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1187:11: warning: implicit declaration of function 'functionspace_Max' [-Wimplicit-function-declaration]
1187 | return &functionspace_Max(psi_plus);
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1187:29: error: 'psi_plus' undeclared (first use in this function)
libffcx_forms_d794fd15c146f0ff61fe6d1ac46d700b634b8746.c:1187:29: note: each undeclared identifier is reported only once for each function it appears in
File "/stck/lmersel/CODE_PROGRAMME/anaconda3/envs/fenics/lib/python3.10/site-packages/setuptools/_distutils/unixccompiler.py", line 117, in _compile
self.spawn(compiler_so + cc_args + [src, '-o', obj] +
File "/stck/lmersel/CODE_PROGRAMME/anaconda3/envs/fenics/lib/python3.10/site-packages/setuptools/_distutils/ccompiler.py", line 917, in spawn
spawn(cmd, dry_run=self.dry_run, **kwargs)
File "/stck/lmersel/CODE_PROGRAMME/anaconda3/envs/fenics/lib/python3.10/site-packages/setuptools/_distutils/spawn.py", line 68, in spawn
raise DistutilsExecError(
distutils.errors.DistutilsExecError: command '/stck/lmersel/CODE_PROGRAMME/anaconda3/envs/fenics/bin/x86_64-conda-linux-gnu-cc' failed with exit code 1
Does that related to this discussion here ? But the difference is that I am not using mixed space like the discussion mentioned and also the code worked on Fenics 2019.
My variational formulation on Fenicsx is
#---------------- Mechanical equation
residual = ufl.inner( sigma_amor(u, alpha, G , K0, ndim) , epsilon(v) ) * dx# - dot( tn, v ) * ds #residual
jacobian = ufl.derivative(residual, u, u_trial) # jacobian
#--------------- Phase Field equation
f_alpha = H_new*ufl.inner(beta, gk_prime(alpha)) * dx \
+ (Gc/(cw*lw)) * (beta*w_prime(alpha) + (2.*lw**2)*ufl.inner(ufl.grad(beta), ufl.grad(alpha))) * dx
J_alpha = ufl.derivative(f_alpha, alpha, alpha_trial) # jacobian
#---------------- RESOLUTION
t= 0.
tol = 0.001 # 1e-6
maxiter = 300
begin_tt = 1
it_time = begin_tt
for t in time_step[begin_tt:2]:
u_app.t = t
u_app_func.interpolate(u_app)
loading[it_time]= np.array([it_time,u_app.t])
print("\n================================================================")
print("\n -> Time increment: %d, Time: %.3g s, Ux_given: %.3g mm "%(it_time, t, u_app.t))
it_staggered = 0
res_H = 1.
err = 1.
print("\n ----- > Start Staggered Loop")
while (res_H > tol) and (it_staggered < maxiter):
it_staggered +=1
#----Step 1 : Displacement resolution
print("\n NRSolver for the displacement pb ")
print("_____________________________________")
bc_left = fem.dirichletbc( fem.Constant(msh, ScalarType(0.)), facet_left_dofs,V_u.sub(1))
bc_right = fem.dirichletbc( fem.Constant(msh, ScalarType(0.)), facet_right_dofs,V_u.sub(1))
bc_bottom = fem.dirichletbc( u_zero,facet_bottom_dofs, V_u)
bc_top = fem.dirichletbc( u_app_func, facet_top_dofs)
bcu = [bc_top, bc_right, bc_bottom,bc_left ]
#Build homogeneous bc
u_app_0 = TopLoad(t=0.)
u_app_func_h.interpolate(u_app_0)
bc_top_h = fem.dirichletbc( u_app_func_h, facet_top_dofs)
bcu_h = [bc_top_h, bc_right, bc_bottom,bc_left]
#Newton Raphson resolution
iter_u = newton_solver( u, res = residual, bcs = bcu,bcs_hom = bcu_h, jac = jacobian)
#----Step 2 : Computation of H energy history
Pel_pos_expr = fem.Expression(psi_plus(u,K0,G), V_H.element.interpolation_points)
psi_elastic_pos.interpolate(Pel_pos_expr)
H_new.x.array[:] = np.max((psi_elastic_pos.x.array[:], H_inc.x.array[:]),axis=0)
#----Step 3 : Damge resolution
print("\n NRSolver for damage pb")
bcalpha = [fem.dirichletbc( fem.Constant(msh, PETSc.ScalarType(1.)), facet_notch_dofs,V_alpha)]
bcalpha_h = [fem.dirichletbc( fem.Constant(msh, PETSc.ScalarType(0.)), facet_notch_dofs,V_alpha)]
iter_alpha = newton_solver( alpha, res = f_alpha, bcs = bcalpha,bcs_hom = bcalpha_h, jac = J_alpha)
H_gap = H_new.vector.array - H_old.vector.array
index_max,H_gap_max = np.argmax(H_gap), H_gap.max()
res_H = abs(H_gap_max)/ H_old.vector.array[index_max]
print("Staggered Iter:", it_staggered)
print("abs(H_gap_max)/ H_old.vector.array[index_max]", res_H)
#---- Step 4 : Update previous solution
u_old.x.array[:] = u.x.array[:]
alpha_old.x.array[:] = alpha.x.array[:]
g = gk(alpha_old,1.0e-6)
H_old.x.array[:] = H_new.x.array[:]
print("\n ----- > END Staggered Loop")
H_inc.x.array[:] = H_new.x.array[:]
# monitor the results
if comm.rank == 0:
print( "\nalpha_max:", (alpha.x.array.max() ))
print("\nIterationU and IterationAlpha: (%i,%i)"%(iter_u,iter_alpha))
print("\nElastic and surface energies : (%g,%g)"%(elastic_energy_scalar,surface_energy_scalar - surf_off_set))
it_time +=1
And the newton-raphson solver is :
def newton_solver(u, res, bcs,bcs_hom , jac, max_iter=100, rtol=1e-10, atol=1e-6 ):
#applied BC + homogenize BCs
fem.petsc.set_bc(u.vector, bcs)
bcs = bcs_hom
jac_form, res_form = fem.form(jac), fem.form(-res)
J = fem.petsc.assemble_matrix(jac_form, bcs = bcs)
J.assemble()
b = fem.petsc.create_vector(res_form)
delta_u = J.createVecRight()
for k in range(max_iter):
# Assemble the system for the Newton update with boundary conditions
with b.localForm() as loc_1:
loc_1.set(0)
b = fem.petsc.assemble_vector(res_form)
fem.petsc.apply_lifting(b, [jac_form], [bcs]) #,x0=u.vector, scale=-1.0)
fem.petsc.set_bc(b, bcs)#,x0=u.vector, scale=-1.0)
# Create CG Krylov solver and turn convergence monitoring on
solver = PETSc.KSP().create(MPI.COMM_WORLD)
pc = solver.getPC()
solver.setType('preonly')
pc.setType('lu')
solver.setConvergenceHistory()
# Set matrix operator
solver.setOperators(J)
# Compute solution
solver.setMonitor(lambda ksp, its, rnorm: print("Iteration: {}, rel. residual: {}".format(its, rnorm)))
solver.solve(b, delta_u)
# Check residual n°1
residual = J * delta_u - b
print(f"The relative residual is: {residual.norm() / b.norm()}.")
# Update the solution
u.x.array[:] = u.x.array[:] + delta_u.array[:]
print("norm(b) : ", b.norm())
if residual.norm() /b.norm() < rtol and k < max_iter:
break
raise RuntimeError("could not converge, norm_u {}, norm_delta_u {}".format(norm_u, norm_delta_u))
return k
Thank you for the help !
Best regards,
Lamia
